08-27-2012, 02:10 AM
#46 | |
Oddometer: 427
If you put the kill switch on and nothing happens, the pump is not producing the necessary pressure to feed the fuel injection system. Either bad electrical connections of clogged filters but i'm more inclined to the first option then faulty pump.
Growing old is mandatory... growing up is optional! ![]() Raid de L'Amitié 2011 RR (link) 690R & 990Adv |
08-27-2012, 05:45 AM
#47 | |
Turkey
Oddometer: 106
09-04-2012, 07:39 AM
#48 |
Positating the negative
Oddometer: 73,681
Okay, I've moved all the Dr. Bean's posts to vendors. Please use this thread for all sales of fuel pump kits. Thanks.
"So what you gonna do when the novelty is gone.."-- Joy Division Same as it ever was 2010 Latin America Route |
09-06-2012, 01:47 PM
#49 |
Oddometer: 5,191
I bought this pump from these guys on flea bay.
KTM 950 R Superenduro '06-08' Fuel Petrol Pump Type 2 | eBay Firstly yesterday when I ordered it, was 79 quid...today 95 quid. This pump is not a direct replacement for the SE. The pipes for the fuel line are for 16mm 8/16 fuel pipe and the orientation is 180 degrees different. So you have to re-plumb the T piece with a straight bit of pipe and shorten the hose with the snap connector, thought it was hard disconnecting the fuel line on the SE!!!...well try now.... You can’t spin the pump around cos the breather nozzle won’t fit up against the tank because of the design of the mounting plate on the tank. They drop ship from this company. http://www.hilevel1.co.uk/cpg14/menu.php Have to say she's running much better...the dip mid throttle has gone..so pump was on its way out. |
10-14-2012, 07:36 PM
#50 |
Long way to go
Oddometer: 1,112
Fuel pump removal
Getting ready for the Dr Bean upgrade. Looking through the shop manual I didn't see anything on the fuel pump removal.
Any trick for getting to the connector for the fuel pump wires? Last ride before the upgrade, and my bike died 2 miles from home.
Everybody's on the run |
10-15-2012, 02:52 AM
#51 | |
Oddometer: 45
Laying on my back soldering, it was ok. If You have acces to a lift It will be easier though |
10-15-2012, 11:38 AM
#52 | |
Dr_Bean
But I think you have to remove the left-tank if you do not want to remove the original (1xuse) hose-clamps on the pump. For me it is difficult to tell, because I modified my 950adv so much that most of these things are different (I have a home made bashplate, fuelfilter in the line and battery, starterrelais and regulator below the seat-bank). http://forum.lc8.nl/modules.php?set_...view_album.php |
10-18-2012, 08:06 PM
#53 |
Long way to go
Oddometer: 1,112
Mission accomplished
With a little help from Dr Bean
