Old 01-19-2011, 07:51 PM   #16
Switchblade315
Switchblade315's Avatar
Oddometer: 5,776
if I'm not mistaken the kill switch will have to drop the coil to ground to kill the motor as it does on the 400ex I'm not sure how that's wired. the key actually cuts all fire to everything with you turn it off that's why it will kill the motor and the switch will not. it's just a matter of getting your wiring right.
Switchblade315 is online now   Reply With Quote
Old 01-20-2011, 06:10 PM   #17
booger1 OP
booger1's Avatar
Oddometer: 928
Thanks, I did not know that, I'll look into that this weekend. Otherwise the bike runs great.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 01-20-2011, 06:52 PM   #18
Cloud9
I was HERE?
Cloud9's Avatar
Oddometer: 1,882
Nice work! I like the XR400 and might have bought one if they had came with e-start and were available new in '08. Instead I went with the XR 650L and I really have a great time on it. I know the forks on the 400 are better than the 650 but I went with a set of WP forks off of a Husaberg, the difference even on the road was instantly noticeable and off-road increadible. So if you get a chance to do upsidedown forks I highly recommend it.
Cloud9 is offline   Reply With Quote
Old 01-20-2011, 07:12 PM   #19
booger1 OP
booger1's Avatar
Oddometer: 928
I had a set of rm 125 usd fork setting around for a few yrs. I just lost the motivation for trying to put them on. I may revisit that though. I'm trying to talk a guy at work into a 650l, he is stuck on the idea of a dr650, but as long as he gets somthing to ride.
Old 01-27-2011, 04:43 AM   #20
Bronco Driver
Bronco Driver's Avatar
Oddometer: 177
Electric Start
When mine was done we used an EX400 crank,balancer,wiring harness,rectifier regulator,cdi, switch,battery box ,etc.All in XR cases.
I also did gold valves and springs.
After riding it the first time --I sold my 650L.
As for the 440 kit ,I went back to the stock cylinder, 10.5:1 piston and a Megacycle stage one cam. I prefer this configuration.
2006 XR650R with too much stuff.
Bronco Driver is offline   Reply With Quote
Old 01-30-2011, 10:06 PM   #21
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,690
nice and good job!
NSFW is offline   Reply With Quote
Old 01-31-2011, 06:55 AM   #22
TooSlow4U
2 Wheel Wonder Rider
TooSlow4U's Avatar
Oddometer: 1,090
Thanks for posting/documenting this...
I am having the magic button envy issue with my '98 XR400 too. I have been looking for an '05 or newer 400EX donor quad for the swap though. The e-start will be handier than a pocket on a t-shirt, for sure! The added bonus of the "retreat" option, that you get with '05 & newer, will make the package just that much more with enjoyable.
TooSlow4U is offline   Reply With Quote
Old 01-31-2011, 07:00 AM   #23
booger1 OP
booger1's Avatar
Oddometer: 928
That would be good, reverse.
Old 01-31-2011, 07:17 AM   #24
Tukata
ADV Demo Rider
Tukata's Avatar
Oddometer: 1,487
I just don't want to add all the weight
That's why i'm selling the XRL
Yes, I'd love to try
What ever happens to be in the stable at the current time.
H-ADV in fabrication
Tukata is offline   Reply With Quote
Old 02-18-2011, 06:54 AM   #25
booger1 OP
booger1's Avatar
Oddometer: 928
A update.
I burned up a cam and a rocker arm.
I don't think I'm getting enough oil to the top end. I put a new cam and set of rockers in and let it run for a little. Looks kinda of dry. Looked in manuals to see if there was a way of testing oil pressure, but not finding anything, I removed the oil filter and turned the motor over and oil does come out. The only thing I could find in a manual was it looks like the cam chain brings the oil up to the cam and then oil goes through the center of the cam and oil comes out in the little holes supplying the rockers with oil.
But if I have oil pressure, why is the oil not getting to the cam?
Anybody have any ideas?
Old 02-18-2011, 08:07 AM   #26
texsurfer
Oddometer: 239
is the donor engine sitting at the same angle as in the EX? maybe the pickup is different and changed angle starves it at times?
texsurfer is offline   Reply With Quote
Old 02-18-2011, 11:32 AM   #27
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
The oil for the cam comes up the right side of the motor into the cavity to the right of the cam. The right cam bearing seal holds the oil in the cavity and the oil goes through the center of the camshaft to the holes on the lobes and journals.
Possibilities:
-The right side cam bearing was installed without the seal. This would cause the oil to go through the bearing instead of into the cam.
-There's a bit of gasket, sealant, or other crap in the oil passage that goes up to the head from the pump. This passage crosses several gaskets, so there are several places to screw it up.
-You've got a stock cam with the decompression/kickback parts removed. In that case, there's an unused oil hole that needs to be blocked in order for the oil to get to the rest of the cam.
-You've got a Hotcam, which has the quality that's typical of cheap performance parts.
Luke is offline   Reply With Quote
Old 02-18-2011, 11:41 AM   #28
Wattner
Wattner's Avatar
Oddometer: 5,428
Possibilities:
Is there a small aluminum spacer in the sidecover that must be installed for the oil to make it up into the head? If I am not mistaken there is, and without it, you get what you got, and that really sucks!!!!
Wattner screwed with this post 02-28-2011 at 02:53 PM
Wattner is offline   Reply With Quote
Old 02-18-2011, 07:27 PM   #29
Switchblade315
Oddometer: 5,776
hey i'm saleing my 98 xr4 motor if you want an extra for parts. I'll sale it cheap.
Old 02-19-2011, 07:53 AM   #30
Bronco Driver
Oddometer: 177
If the oil filter is mistakenly installed backwards will cause the same rocker,cam,etc. problems.No oil to the top end.
Times are GMT -7.   It's 07:24 PM.
