12-16-2011, 06:54 AM
#151 |
Unwounding
Oddometer: 4,326
They have been great about replacing them, I'm just tired of having to go thru it over and over again. Getting to a race the morning after the bike ran great and having it fail to start because of the battery stinks. My friend raced the Nationals on a SXf450 and started having the mechanic bring an extra battery to the starting gate as the same stuff was happening to him! I'm sick of the racing pulse and boiling blood pressure at the starting lines. The Burg wasn't as bad the oter day, I just got fully suited up for a cold weather ride and "click-click". At least I wasn't 3 hours drive and $150 in fuel and entry fees deep for that one!
12-16-2011, 07:22 AM
#152 |
i have had my shorai for about a year now, half of that time the bike was apart and the battery sitting in the garage unused. After putting the bike back together the battery worked right away, if anything it performed admirably. It lasted through the priming of my vacuum fuel pump. I am very happy with it. No problems here!
2007 KTM 990 Adventure |
12-16-2011, 07:35 AM
#153 |
pass the catnip
Oddometer: 7,565
So the lesson seems to be if you live in cold climates and ride in the 30s and below Shorais are a pita. Otherwise they're great. Just bought two, glad I live where it rarely gets below 0...
12-16-2011, 07:43 AM
#154 | |
Oddometer: 41
If I am looking for a quick get away I would bring a car with a driver and have him keep the engine running
Alex - 06 FZ1 Certifiable MSF Instructor MishaCycles, Inc. OEM parts and accessories MishaCycles on Facebook |
12-16-2011, 08:32 AM
#155 |
Oddometer: 73
Cyborg, I am planning to implement your battery monitoring solution, since I'm especially concerned about eventual high temperatures that could spell disaster, and I was wondering: did the sensory rig own current draw required you to install it on switched power?
'07 G650 XCh (and '04 recumbent bike) |
12-16-2011, 11:30 AM
#156 |
[/QUOTE]If I am looking for a quick get away I would bring a car with a driver and have him keep the engine running
12-16-2011, 02:06 PM
#157 |
Oddometer: 41
Today I had to go and help out running gymnastics tournament that my son is going to take place tomorrow. It was around 29 when I left the house and about 31 on the way home. Both times bike has started from the first time. I did plug my Powerlet heated liner in for a couple of min before starting it.
12-16-2011, 05:25 PM
#158 |
Unwounding
Oddometer: 4,326
I was picking up a new lead acid at my KTM dealer and we shared our stories about these new tech lightweight batteries. He has had the same problems I have, nearly missing the main at a local arenacross too. He is sticking with lead acid in cooler temps. He also fried his Ballistic Battery by trying to jump start the bike. Shouldn't have happened but the case got super hot, battery is toast.
Now I'm used to moving these Shorais around, the weight of a regular 7 series really caught me off guard but better it always works than what I've been dealing with. |
12-16-2011, 05:56 PM
#159 | |
Potius Sero Quam Numquam
Oddometer: 4,398
alpi, I ended up pulling out the wireless battery monitor after I found the Shorai battery holds its charge very well. The monitor stuff was a bit too delicate for all the road slime that gets in there from daily commuting all year on the 990, especially in the rain. No I didn't have the sense system on switched power because it drew so little. |
12-21-2011, 06:15 PM
#160 | |
Oddometer: 73
01-03-2012, 10:16 AM
#161 | |
Calvin
Oddometer: 383
It has been almost a year since you installed the new battery. What are your thoughts on the battery? Besides the weight difference would you buy it again? |
01-03-2012, 05:13 PM
#162 |
Oddometer: 1,862
I have the bigger battery in my bike and it works great in SOCAL for the last 8 months or so. They are going to be my go to battery.
steve
04 CRF230F 06 CRF250x 08 KTM990 ADV/ABS Black 09 KTM 530 EXC |
01-04-2012, 11:10 AM
#163 |
Oddometer: 7,889
I installed a Shorai last August in my SE. Hasn't been real cold until recently.
13 degrees last night, 23 degrees now. Last ridden 12/30 and not on battery tender. The bike is kept in an unheated/uninsulated shed. First time I hit the starter all I got was a click 2nd time maybe 1/2 revolution and then click 3rd time same 4th time maybe a full revolution and then click 5th time same 6th time a few revolutions than nothing I let it rest about 30 seconds 7th time stronger/more revolutions then clicking I let it rest for another 30 seconds 8th time spun fast and started right up After running for a few minutes (just to reach 4 bars) I turned it off and put the battery tender on-- it went to blinking (indicating charging but battery at 80% or more) in about 10 seconds; so the battery was hardly depleted.
Walter Barlow |
01-04-2012, 03:02 PM
#164 | |
Isn't that dangerous?
Oddometer: 1,222
EastSideSM: '06 950SM Black, '01 Honda RC51 |
01-04-2012, 04:25 PM
#165 | |
Oddometer: 7,889
That worked ok when it was in the 30's, b ut I wanted to try something different because I was mindful of what was opined about the light/electrics not drawing enough to warm things up, yet possibly depleting the battery. I'll try it that way again when it's colder.
Walter Barlow |
