Old 01-10-2011, 05:42 AM   #1
hank0614 OP
TurtleGuy
Oddometer: 15
Cylinder Overboring - R90S
A friend of mine has begun the process of restoring his 1975 R90S (built 10/75). He was advised that both cylinders required a .20 over re-bore, and he acquired the appropriate pistons along with other required parts in a single purchase several years ago prior to any machine work. One cylinder cleaned up nicely, the other did not. He now has a .20 over piston looking for a cylinder. He has two potential donor sets of cylinders available, one from an R60/6 and one from an R90/6.
The question is: can a cylinder from either set be re-bored to .20 over the R90S spec and be used on the R90S? Alternatively, if he can acquire an R75/6 cylinder, can it be used?
He would prefer to use an R60 cylinder, since it comes from the remains of a parts bike. The R90 set is from a bike that is a fairly minimal project that he would prefer to keep intact.
Any advice or observations would be greatly appreciated.
Hank
’72 R60/5
’95 K75S
Hank '72 R60/5 "Schildkroete"
'95 K75S "Shall Remain Nameless"
hank0614 is offline   Reply With Quote
Old 01-10-2011, 09:17 AM   #2
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
Okay, here ya go.
The bike is a 10/75 production, which makes it a 76 bike not a 75, which means it has the large bore spigots and the 18mm diameter push rod tubes rather than the 16mm.
The cylinder used has to be of the same era, basically from 9/75 to 8/80.
If the R90/6 jug has the same size spigot and pr tubes, use that one.
The R60 jug will not have enough meat in it as the walls are around 5.5mm thick or so at the thinnest point and a bore size of 73.5mm. You are trying to go up to 90.5mm. Do the math.
Another option if the R90/6 jug is a no-go is to use an R80 jug.
They went into production in the middle of 1977 so there is no issue with the spigot being too small.
There is just enough material in there to go to the second overbore, provided the boring person knows how to and has the correct jig for the jug.
The walls are also about the same thickness at the thinnest point.
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 01-10-2011, 11:16 AM   #3
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
besides the immediate issue... I love seeing pics of chopped up parts cutaways.
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 01-10-2011, 06:36 PM   #4
djkilmer
Oddometer: 16
Curious about the prospect of using the 750cc jugs as well for a 900, I have a mint set of R90S pistons that I want to use on my current project and was planning on using my stock 750 jugs and boring them to the 900 specs, will they work as well?
djkilmer is offline   Reply With Quote
Old 01-10-2011, 08:58 PM   #5
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
Don't count on it.
I don't have a dead R75 cylinder to split.
Anyone else wanna donate?
www.wirewerkes.com
Old 01-11-2011, 04:43 AM   #6
PaulRS
Dutch fool
Oddometer: 679
I had my 75 (16 mm tubes) bored to 90 std a few ages ago without any trouble.
Still holding after years of (ab)use.
Paul.
Geht net, gibbet net.
PaulRS is online now   Reply With Quote
Old 01-11-2011, 09:10 AM   #7
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
Paul.
Wow, that means that you possibly have 1.5-2mm of wall thickness in there, unless the R80 jug was just a bored out R75 from the factory.
Nice to know it isn't distorting.
www.wirewerkes.com
Old 01-11-2011, 11:28 AM   #8
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,245
I think hte OP wants to bore to 90 2nd over though and wonder if that would be a different kettle of fish?
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 01-12-2011, 10:34 AM   #9
djkilmer
Oddometer: 16
Thanks for letting me jump in on this thread with a few questions of my own, will someone mind giving me the O.D. of the 900cc cylinder, the top where it mates with the head, thanks!
Times are GMT -7.   It's 03:30 PM.
