Old 01-12-2011, 06:38 AM   #1
hank0614 OP
TurtleGuy
Oddometer: 15
Cylinder Overboring - R90S Add'l Question
Thanks for all the replies. My friend has one question: where is the spigot measured to determine whether it is a small 97mm or a large 99mm spigot? Is it at the base or the largest point where it enters the engine case? As the bike was built in 10/75 he may be at the point of change over where BMW was using up what small spigot cylinders were left in inventory.
Thanks again!
Hank
'72 R60
'95 K75S
hank0614
Hank '72 R60/5 "Schildkroete"
'95 K75S "Shall Remain Nameless"
hank0614 is offline   Reply With Quote
Old 01-12-2011, 08:47 AM   #2
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
As I mentioned before, if it is a 10/75 production, it should be the large spigot.
I also mentioned that the diameter of the pushrod tubes is also a determining factor.
The 18 mm diameter is for the large spigot, the 16 is for the small spigot.
Pretty easy to tell.
16mm is close to 5/8"
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Times are GMT -7.   It's 02:59 PM.
