Old 11-29-2011, 03:48 AM   #106
toniton
toniton's Avatar
Oddometer: 22
Thanks! I like the ones attached on the 690
KTM 690 Enduro R
toniton is offline   Reply With Quote
Old 12-15-2011, 09:45 AM   #107
GS simp
GS simp's Avatar
Oddometer: 112
Just got mine sorted, i am very pleased with the outcome.
GS simp is offline   Reply With Quote
Old 12-15-2011, 09:46 AM   #108
GS simp
GS simp's Avatar
Oddometer: 112
Another
Old 12-15-2011, 10:40 AM   #109
GS simp
GS simp's Avatar
Oddometer: 112
another
Old 12-29-2011, 03:56 PM   #110
markozero
Oddometer: 9
hi! anyone has tried the difference between the two Hellas lights, the comination of Hellas with HID and the full HID ?
maybe there are video or photos that show the difference betwee different light power
I need to know if the Hellas are good enought for night driving
many thanks
markozero is offline   Reply With Quote
Old 12-31-2011, 03:55 AM   #111
Ian B OP
Fairing Manufacturer
Oddometer: 482
many thanks
We really should get around to showing the difference on our website !
Anyway, just as a guide, the Hellas are definately good enough for night riding and depending what bike you have, the standard halogens are 2-3 times brighter than stock. The biggest reason for the HID's is actually electrical power consumption. The HID's use half the power ( 35w) and push out about 50% more than the halogens. For this reason HID low beam ( which remains on all the time) and halogen hi is the most popular combo.
HID's can be easily be added at a later date if desired.
Hope this helps.
Cheers Ian
www.britanniacomposites.com
Ian B is offline   Reply With Quote
Old 12-31-2011, 07:12 AM   #112
markozero
Oddometer: 9
Hope this helps.
Cheers Ian
Hi Ian, thanks for your answer
I have a KTM 690 enduro R but with Dottori rally light spoiler. I have also changed the original light with KTM, 690 enduro standar light (bigger but not so effective).
I believe your suggestion regarding combo should be best choice but I have some doubt regarding HID because I don't like to have more electric things (like switch , etc ) ...you know what they say: if there isn't , will not be break ever
I'm seriuosly thinking to purchase your Lynx but I have some question for you before order:
- could be possible to have ABS dash predrilled to install quickly the oem instrument without any wire modification?
- I have not understood well how the dash must be mounted on the triple clamp...have you a couple of photos were I can get a look?
I guess the dash use the same bolt to fix the riser on the clamp but not sure
- I think to make too hole in the dash to mount GPS, instrument, etc could weaken the dash...isn't it? I have to be sure that the vibrations during off riding and the weight of accessories (GPS,oem instrument...) cannot break the ABS
lastly how much time to have the Lynx from the order? how much the airmail shipping to Rome, Italy?
thanks
Marco
Old 12-31-2011, 10:38 AM   #113
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,093
Marco - I also own a 690 Enduro, and have equipped it with a Lynx. I will say that you won't have any problems with the ABS dash breaking - it's 5~6mm thick, and quite strong. To mount the OEM instruments and the GPS, I suggest that you trace the outlines of both parts on paper, and transfer the mounting hole locations to the paper by rubbing the edge of a pencil over the holes. Then you can position the instruments and GPS as you see fit. Don't forget to leave room to operate the locking mechanism on the GPS cradle -- I had to shift mine downward by 1 cm because I couldn't get my fingers on the locking lever.
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is offline   Reply With Quote
Old 12-31-2011, 11:11 AM   #114
Ian B OP
Oddometer: 482
Marco -- Yes, the dash fitting is very straight forward and the wiring is all plug 'n play now, so no wiring for you to do except your GPS.
The dash on the 690 fits straight onto the front face of the top triple sharing the 3 bolt holes that your indicator bracket uses.
email me at britanniacomposites@shaw.ca for more info and shipping rates.
Ian
Old 01-01-2012, 07:41 AM   #115
markozero
Oddometer: 9
Ian
I have taken off the oem indicator repositioning another smaller model ...but I guess can use the hole of oem
Indicator to fit the dash, isn't it?
Old 01-01-2012, 08:15 AM   #116
markozero
Oddometer: 9
thanks! good suggestions!
Old 04-06-2012, 05:10 PM   #117
SeanVancouver
SeanVancouver's Avatar
Oddometer: 6
I ordered mine last week in orange with black decals, HID low beam and halogen high beam. Ian says it's ready and I can't wait to get it installed. Will post pix when done.
2010 690 Enduro R, FMF Q4
[FONT=Arial]Mefo Explorers,/FONT]
Al skid plate, Giant Loop bags
Britannia Composites Lynx fairing-HID/ Halogen
SeanVancouver is offline   Reply With Quote
Old 04-07-2012, 09:12 PM   #118
SeanVancouver
Oddometer: 6
Picked it up today!
What's in the box:
Before:
After:
Install took me about three hours. I could have done it faster but it was a lazy, sunny Saturday so... It went together really easily but the bolts in the lower triple clamp are a bit of a bear to get to.
Huge improvement in wind protection on the road and no downside off road. I need to get it out at night to really try out the lights. There is a slight 'buzzing' vibration at some engine speeds which is likely due to a wiring connector touching the inside of the fairing. I had to remove the rubber grommets from the turn indicator mount and there is a bit more vibration in them than before so I may add a bit of rubber back in. Minor annoyances more than anything else. Overall, I'm really happy with it.
Old 04-08-2012, 05:53 AM   #119
markozero
Oddometer: 9
I have mounted Lynx on my KTM 690 enduro R and I'm really satisfied of it
Britannia has developed a great and affordable solution to permit riding and traveling in very hard off road condition
especially in Italy where you have often to drive in extreme enduro situations
This is my bike with Lynx
Old 04-14-2012, 05:50 PM   #120
Motomochila
Mechanically Inept
Motomochila's Avatar
Location: N 34 22.573' W 118 34.328' Jes North of LA a few.
Oddometer: 520
Here's my Lynx. I must have gotten one of the first designs that mounted under the bar clamps. WTF? So I had an aluminum plate fabbed up to fit the issue. Far better mounting, and a lot sturdier. Still room for my roll chart once the new one shows up.
KTM- Brand spankin' new in 2013- a fresh outta the box 2008 EXC450R, 2009 690 R Adventure Conversion BMW- 2012 GTL 1600-sweet, 2011 R1200GS Adventure Honda- 2000 XR650R- 2006 XR650L- Yamaha- 1972 XS750 Tracker, 1971 RC5- BSA- 1945 M20, The newest member to my stable Kawasaki-NOT Are you kidding
Motomochila is offline   Reply With Quote
Times are GMT -7.   It's 11:45 PM.
