Old 06-16-2013, 10:38 AM   #1
patrkbukly OP
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 990
Drainplug Pics
Hi,
does anyone have a picture of their transmission magnetic drainplug that I can see to compare what I have on mine by chance???
Here is mine.
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 06-16-2013, 10:54 AM   #2
100RT
100RT's Avatar
Oddometer: 664
The tranny drain plug should have black or gray muck that you can rub between your fingers and not feel anything gritty or sharp. Gently shake that plug in a jar of gasoline or solvent to see what is really stuck on it.
Whats the bike,year, mileage etc.
100RT is offline   Reply With Quote
Old 06-16-2013, 11:07 AM   #3
regomodo
Oddometer: 185
Mine usually looks like black grease but its a suspension of filings in oil. Yours has chips in it, not normal.
79 BMW R45 Cafe
82 Suzuki DR125
02 Suzuki RM 250
regomodo is offline   Reply With Quote
Old 06-16-2013, 11:11 AM   #4
Plaka
Brevis illi vita est
Oddometer: 4,588
Originally Posted by Patrick C Buckl View Post
Hi,
Here is mine.
No, because I can't photograph through my scopes. I usually waft a little brake cleaner across it to get the oil off then put the whole plug under a scope at 70X.
Many very inexpensive (>$10) scopes will do fine but you do want over 50X and 70X is quite good. You can see stuff like chromed flakes, bearing bits, metal that is rolled or crushed vs. sheared or fractured, etc.
At 1X someone elses drain plug can look just like yours (fuzz is normal at some mileage) yet tell a very different story under magnification.
Old 06-16-2013, 11:22 AM   #5
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,322
Show & tell
Patrick-
pics, yes. online photo account,no.
is that a paste or is that shards?
Paste-OK.
Shards- not so much...not the end of the world, just another adventure!
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 06-16-2013, 11:28 AM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,190
That does look like slivers of metal. It usually does look like that. But the substance is soft and when squished between the fingers turns to powder. If the stuff on the drain plug is gritty and/or feels like bits of sand then you have much more serious problems.
---Albert Einstein
Old 06-16-2013, 02:21 PM   #7
Kai Ju
Kai Ju's Avatar
Oddometer: 1,817
what model/year bike
The debris looks like it came out of a kick start transmission. Is it ? At least that's what the stuff looks like coming off the kick starter gear and quadrant.. If so, stop using the kick starter.
Kai Ju is offline   Reply With Quote
Old 06-16-2013, 03:06 PM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,190
Bike is a 1993 R100 GSPD. See the thread about "nipples" else where on this page.
---Albert Einstein
Old 06-16-2013, 03:27 PM   #9
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,100
If the metal has never ever been cleaned off the magnet seeing bits of metal would not surprise me. I'd clean it off and check it again after a bit of hard running.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 06-16-2013, 05:11 PM   #10
Plaka
Oddometer: 4,588
Originally Posted by Bill Harris View Post
That should have been mentioned in the first post, otherwise any reply here is a waste of time.
mmm...agree on the mention, but if you restrict your comments to nfo that is model independent...
I'm trying to buy spark plugs. The brainless wonder behind the counter starts, without exception, by asking what model it is for. it Takes a loooong time before I can get him to just look up the spark plug number I have so he can get the store stock number and find it on their shelves. Twice the BW had to get a manager to show him how to do it.
OP asked a silly question, and that poorly. if I show him my drain plug and it either looks a lot like his or a lot unlike it, what will he know? Nothing. So I addressed a better question he didn't ask, "What's this stuff on my drainplug". Left out all the details.
Old 06-16-2013, 05:38 PM   #11
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 489
You ask for photos.................You got it!
1992 GS
50k miles
Images were taken before a trani rebuild, circlip install & higher 5th gear.
There was one bad bearing.
It probably would have done a few more miles.............but why?
Good Luck...........................................
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Old 06-16-2013, 05:47 PM   #12
ME 109
ME 109's Avatar
Oddometer: 2,572
Tranny out, open it up.
It can't get better, only worse,
Fix it before other damage occurs.
Imo
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 06-16-2013, 06:00 PM   #13
Plaka
Oddometer: 4,588
Imo
Finally! The obvious emerges: entropy exists.
But how fast it wears is something else. Opening it up when you can't read a drain plug...I'd say that could accelerate the wear quite a bit.
Just my .02 mind you.
Old 06-16-2013, 06:19 PM   #14
ME 109
ME 109's Avatar
Oddometer: 2,572
What can't be read about that plug?
Bad shit is happening in there.
However, if he doesn't ride the bike it won't wear any further.
Old 06-16-2013, 07:15 PM   #15
patrkbukly OP
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 990
Thanks Britt
1992 GS
50k miles
That is exactly what I needed to see, that looks about same as mine so I need to get shopping or rebuilding.
Thank you.
Mae West
Times are GMT -7.   It's 07:28 AM.
