Old 01-19-2011, 01:35 PM   #1
BillyD OP
BillyD's Avatar
Oddometer: 635
KTM 990 Cam Timing Specs
I did a search and reviewed the service CD, but to no avail...
Can anyone point me to cam timing specs for the 990 Adventure?
Specifically, I'm looking for timing clearance and open/close degrees. Lift would be nice too, but not required.
Thanks.
Bill
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD is offline   Reply With Quote
Old 01-19-2011, 05:39 PM   #2
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Good luck on that. I couldn't get that info out of KTM. My Yamaha manuels have it for them but try to get anything out of KTM is impossible. I finally measured it but I can't find were I wrote it down. My bad memory remembers about .333 intake lift and duration was less than 212. Exhaust duration something like 242. If you need this you probably need exact figures so this isn't any good for ya. Found the specs on the cam I'm running now. Lot of room for more lift.
tahoeacr is offline   Reply With Quote
Old 01-19-2011, 08:14 PM   #3
BillyD OP
BillyD's Avatar
Oddometer: 635
Hmmmm, if full timing specs aren't readily available, would you happen to remember where the lobe centers should be set?
Bill
Old 01-19-2011, 08:51 PM   #4
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,103
Pretty easy to check next time you do a valve check.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 01-19-2011, 10:15 PM   #5
nomad guy
A legal alien
nomad guy's Avatar
Oddometer: 848
its good to see you are back on this forum, haven't seen your posts for very long time
Cheers
Guy
04 KTM ADV 950S GO!!!!!
09 KTM 690 ENDURO R
nomad guy is offline   Reply With Quote
Old 01-20-2011, 07:12 AM   #6
BillyD OP
BillyD's Avatar
Oddometer: 635
True, but that alone will only tell me what they are which might not necessarily be what they should be...
This falls into the "Trust, but Verify" catagory.
Bill
Old 01-20-2011, 08:55 PM   #7
BillyD OP
BillyD's Avatar
Oddometer: 635
Interesting how only the rear intake cam has a blue dot. All other cams have an orange dot... I wonder why this is so?
Front Exhaust
Front Intake
Rear Intake
Rear Exhaust
Bill
Old 01-20-2011, 08:59 PM   #8
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,585
QC shift markings?
In general we know that 990 SD cams will fit and run in the 990 ADV heads. I think that there are several 950 engines running 990 SD cams too (flanny i think is running SD cams in his 950 ADV)
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 01-20-2011, 09:32 PM   #9
BillyD OP
BillyD's Avatar
Oddometer: 635
Maybe I have one cam from each: 950, 990A, 990SD, and RC8.
Bill
Old 01-21-2011, 02:42 PM   #10
K2m
....58....
K2m's Avatar
Oddometer: 2,239
I'm running 07 SD cams in my 04'S'
Also 39 FCR's with TPS, and copy's of Africa Queen extractors.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 01-21-2011, 05:26 PM   #11
nomad guy
A legal alien
nomad guy's Avatar
Oddometer: 848
does anyone have the the sd cams on a 950 with the regular carbs ?.
btw i think the sd cams are the same cams as all the newer 990s.
Cheers
Guy
09 KTM 690 ENDURO R
Old 02-27-2011, 08:28 PM   #12
BillyD OP
BillyD's Avatar
Oddometer: 635
Hey, what is this, a KLR???
What do the KTM 990 Adventure, a Honda 3-wheeler from the late 1980’s and the lowly stock Kawasaki KLR 650 all have in common?
They all use almost exactly the same cam profiles…
CAM LIFT (in)
DURATION AT .040"
LOBE CENTER
OPEN
CLOSE
STOCK KTM 990 ADVENTURE CAMS
INTAKE
0.354
224
103
atc
9
btc
35
abc
EXHAUST
0.354
223
101
btc
32
bbc
11
atc
HONDA ATC-200X, TRX-200SX (1986—1988)
INTAKE
0.355
222
106
atc
5
btc
37
abc
EXHAUST
0.355
222
106
btc
37
bbc
5
atc
KAWASAKI KLR-600 single (1984—1986) and KLR-650 (1987—1992)
INTAKE
0.345
227
EXHAUST
0.355
222
Source: MegaCycle Cams and Poster measurements.
In other words, the cams in the 990 Adventure are very mild in almost every aspect. Compared to cams used in many motorcycles today, the 990 Adventure cams have short duration, little overlap and do not much valve lift. The design is even more pedestrian than those used in mid-1980’s universal Japanese motorcycles.
Procedure
I measured cam timing at .040” (1mm) valve lift since this is what MegaCycle Cams and most Japanese motorcycle manufacturers use as their standards.
Since I didn’t have the right shims to set lash to zero, I measured timing and lift using running lash and with lash set to .040”. When using running lash, I deducted the running lash from .040" to obtain the correct checking lift. For example, if the running lash was .006", I checked opening and closing points at .034" valve lift (.040" minus .006" = .034"). To double check the results, I then set the lash as close as possible to .040” and checked opening and closing points just as the lobe contacted the valve bucket.
To get consistent readings, I had to remove three cams while measuring one. With a total of only eight lobes on four cams for two cylinders, valve spring pressure causes the motor to suddenly rotate forward each time any lobe went over center and start to close.
Also, to get consistent closing point readings, I had to temporarily replace the spring-loaded cam chain tensioners with solid pieces snugged down to take up any cam timing chain slop. The force exerted by the cam lobe as the closing point would over power the spring-loaded tensioners and induce as much as 4 degrees crank variation.
Conclusions
By all measures, the stock KTM 990 Adventure cams are very mild. They are low lift, short duration cams. Other motorbikes that have very similar cam specs the lowly KAWASAKI KLR-600 single (1984—1986) and KLR-650 (1987—1992) and the CPSA-banned HONDA ATC-200X, TRX-200SX (1986—1988).
Figure 1. Psst, Hey Buddy, Wanna Race?
BTW, these cam specs are also very close to another off-road monster, the Honda XR200.
Bill
BillyD screwed with this post 03-27-2011 at 07:16 AM
Old 02-27-2011, 08:51 PM   #13
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,585
Excellent work BillyD! Now I need to get busy with the 950 measuring. I wonder if they are going to be any different.... My brother seems to think that the EFI designed cams are going to be more mild and different overlap (less) that a carb'd bike. Time will tell on this one and who owes who a beer.
Nice chrome header on that banned three wheeler!
Old 02-27-2011, 09:30 PM   #14
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,229
Hey Bill, my stock 990 cams are paperweights! Good sleuthing
Love those SD cams.
cyborg is offline   Reply With Quote
Old 02-27-2011, 09:31 PM   #15
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,585
Hey Clif, did you replace the buckets at the same time as putting in the SD cams or leave'm and run it?
Times are GMT -7.   It's 11:56 AM.
