Old 02-28-2011, 09:05 PM   #16
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
How about Intake .452 lift w/duration 254
Exhaust .435 lift w/duration 250
tahoeacr is offline   Reply With Quote
Old 02-28-2011, 09:59 PM   #17
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,055
forgive the stupid question but what's the pink stuff?
Old 02-28-2011, 10:03 PM   #18
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
assembly lube. Im not sure what brand BillyD uses but I use Redline, post valve adjust.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 02-28-2011, 10:45 PM   #19
BillyD OP
BillyD's Avatar
Oddometer: 635
Now that's more like it....
At what clearance? Timing?
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD screwed with this post 03-01-2011 at 07:17 AM
BillyD is offline   Reply With Quote
Old 03-01-2011, 11:14 PM   #20
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Webb cams builds them for someone racing in Europe. They couldn't tell me if it would clear the pistons without valve relief. Then I bought a Husaberg and lost interest in my 990.
Old 03-02-2011, 04:49 AM   #21
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,462
Sorry for another stupid question but what's wrong with using clean engine oil?
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 03-02-2011, 07:40 AM   #22
BillyD OP
BillyD's Avatar
Oddometer: 635
Assembly lube is typically used when assembling a new motor, but if you already have it on hand, there is no reason not to use it when playing around with a motor that has already been run in. And, yes, this is Redline assembly lube.
Bill
Old 03-02-2011, 09:48 AM   #23
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,136
Excellent work BillyD! Now I need to get busy with the 950 measuring. I wonder if they are going to be any different.... My brother seems to think that the EFI designed cams are going to be more mild and different overlap (less) that a carb'd bike. Time will tell on this one and who owes who a beer.
Nice chrome header on that banned three wheeler!
If the 990 cams are milder than the 950, I wonder whether the 950 cams would work in a carbed 990. Fit? Enough clearance? Better performance? Hmmm....
The reason I wonder is that I already have a set of 950 cams sitting on the shelf, and my 990 is already carbed.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-03-2011, 01:17 AM   #24
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,118
there is no answer to that right now. Send your cam's to billy and we'll know it!
Billy, keep up the good work and hope you find a set of SD and 950 cams!
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 03-03-2011, 10:35 AM   #25
catalina38
Contrarian
Oddometer: 1,601
In another thread there is info about 2009+ 990 cams are SD cams. So could there be three different cams? 950, early 990 and 2009+ 990 ADV/SD?
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 03-03-2011, 02:11 PM   #26
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
SD cams in Adventures
I wonder with which ECU would SD cams run with? 950Adv or 990Adv '07 or SD or 990Adv '10?
Old 03-03-2011, 08:57 PM   #27
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Jeremiah Johnson: [Jeremiah and Bear Claw hunt elk] Wind's right, but he'll just run soon as we step out of these trees.
Bear Claw Chris Lapp: Trick to it. Walk out on this side of your horse.
Jeremiah Johnson: What if he sees our feet?
Bear Claw Chris Lapp: Elk don't know how many feet a horse has!
Modern terms: ECU don't know how big the loabs are.
Plus, you cannot change the ECU mapping to the SD. You would have to try the 10 Adv.
Old 03-03-2011, 08:59 PM   #28
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
All 950's run the same cams(SM, SE or Adv.) There are four different cams for the 990.
But really, with the problems I had getting a good set of cams out of KTM(three different sets came scored and chipped) it would be better and faster to go aftermarket.
Old 03-03-2011, 10:12 PM   #29
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
So Tahoeacr, would it be a better bet to have the 950 cams welded and ground to spec? Or are the 990 parts cheaper than the shop labor?
I wondered about LC8 cams for a long time and never guessed that the 950 lobe specs were xr/klr in proportion...
snowhawk jockey is offline   Reply With Quote
Old 03-04-2011, 12:00 AM   #30
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
note that the currently measured cams are NOT 950, but the 990 ADV
Times are GMT -7.   It's 01:43 AM.
