Old 01-19-2011, 08:40 PM   #1
alister102 OP
alister102's Avatar
Oddometer: 259
Airhead airbox cover plate
Has anyone made one of these covers and willing to share instructions?
Best,
Aric
alister102 is offline   Reply With Quote
Old 01-19-2011, 09:42 PM   #2
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,788
Looks a lot like a Chinese blueprint to me
Old 01-19-2011, 09:56 PM   #3
mfp4073
mfp4073's Avatar
Oddometer: 2,420
Three different bolt/nuts....looks like sloppy work to me..
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 01-19-2011, 11:13 PM   #4
elite-less
As above, so below
elite-less's Avatar
Oddometer: 543
Ha! Noticed that as well. Isn't this the mild-custom r90s thats been on ebay?
elite-less is offline   Reply With Quote
Old 01-20-2011, 01:07 AM   #5
bikecat
bikecat's Avatar
Oddometer: 1,117
Why the need for a central filter when the carbs are fed by pods?
Interesting ..........
bikecat is offline   Reply With Quote
Old 01-20-2011, 01:10 AM   #6
Houseoffubar
fine beer sampler
Oddometer: 1,788
That one is for the crankcase breather.
Old 01-20-2011, 05:27 AM   #7
rufusswan
rufusswan's Avatar
Oddometer: 962
One allen head & one acorn nut. So that's what they call ARTY?
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 01-20-2011, 05:44 AM   #8
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 544
Just measure the back of your engine and fold accordingly. Use a thin gage of aluminum and don't crease the corner too sharply, or it will crack. If you can't bend it, your local sheet metal shop can do it.
Put the folded piece in place on the engine and traced the curve with a marker, then cut to fit.
Jon-Lars screwed with this post 02-12-2012 at 12:55 PM
Jon-Lars is offline   Reply With Quote
Old 01-20-2011, 05:57 AM   #9
alister102 OP
alister102's Avatar
Oddometer: 259
Hello Jon-Lars! Thanks, I thought you might chime in-
Old 01-20-2011, 12:17 PM   #10
DaveBall
DaveBall's Avatar
Oddometer: 1,163
Looks easy enough to do. Just don't ride it in bad weather. Pumping water and dirt thru these engines doesn't do them any good.
DaveBall is offline   Reply With Quote
Old 01-20-2011, 12:21 PM   #11
nella
nella's Avatar
Oddometer: 403
I'm not sure I follow you on this. Are you saying the cover would cause a problem or are you commenting on velocity stacks on the carbs?
Scott
nella is offline   Reply With Quote
Old 01-20-2011, 12:32 PM   #12
supershaft
because I can
Oddometer: 9,116
I assume he is talking about the air filters.
I have set up more than a couple of crankcase breather setups and the setups I see above would cause a potentially dangerous oily mess in my experience. Those setups will very quickly have oil dripping all over the bike including your tires! At least if you rev them and ride them hard!
I have mentioned this fact before and some have claimed that it is not the case but I still don't see any photos of bikes with some miles on them. In my experience, they have to be positioned just so or speeds above about 90mph will have the slipstream wicking oil ALL over the back of the bike including the tires!
If I wasn't CAREFULLY running my vent out the back, I would have a catch tank but remember that even the catch tank has to be vented so keep an eye on that as well. That's my advise if you plan on riding the thing.
Old 01-20-2011, 12:39 PM   #13
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,629
Originally Posted by Jon-Lars View Post
What's with designing it with that sharp bend?
Do you think the cover would be water-tight?
crazydrummerdude is offline   Reply With Quote
Old 01-20-2011, 02:11 PM   #14
nella
nella's Avatar
Oddometer: 403
I rigged a catch tank with a breather on mine. I'm going to modify it a bit more when I get around to it. I've ridden it hard and checked and only have a fine mist of oil in it.
Scott
Old 01-20-2011, 02:13 PM   #15
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 544
Yeah, Supershaft, riiiight.
I remember you, from another forum. Still posting over there?
Times are GMT -7.   It's 06:22 AM.
