Old 01-21-2011, 09:01 PM   #31
BicyclebBob
Oddometer: 31
BicyclebBob is offline   Reply With Quote
Old 01-21-2011, 09:08 PM   #32
robtg
Oddometer: 675
Originally Posted by crazydrummerdude View Post
There is no single annealing temperature for a material.
Would you care to explain?
robtg is offline   Reply With Quote
Old 01-21-2011, 09:16 PM   #33
fishkens
Further...
Oddometer: 5,148
Oh my, I never expected this to go on this long. I've always been satisfied with the stock arrangement (low expectations ).
So, humor this ignorant poster, please.
Has anyone drilled and brazed a small spigot onto the exhaust somewhere and run the breather hose to it?
That would avoid sending the crankcase effluence through the carbs and also avoid long hoses, filters, etc. spewing oily mist all over the bike, etc. Frankly, those mini-filters (and resulting misty mess) coming out the cover plate just don't look very elegant.
Would it result in a smokey exhaust? I have no idea. That's why I ask. Seems like it might be a way to avoid the downsides of the two most common solutions (carbs or hoses/filters).
Fact based statements (or WAGs...or assessments of my sanity) welcomed.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 01-21-2011, 09:21 PM   #34
edray
cascadian
Oddometer: 224
nicely done..
bicycle bob; very nice.. very nice..
edray is online now   Reply With Quote
Old 01-21-2011, 09:27 PM   #35
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,629
Theoretically, it could be many things. If you have limited resources, I don't see the need to shoot for a particular temperature; anything that allows recrystallization and controlled cooling.
Not to be confused with heat treating, though.
crazydrummerdude screwed with this post 01-21-2011 at 09:37 PM
crazydrummerdude is offline   Reply With Quote
Old 01-21-2011, 09:45 PM   #36
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Just do it the way Triumph did, Run a hose out along the rear fender and spray down vehicle behind you with your unwanted oil vapors!
RVV
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 01-21-2011, 09:54 PM   #37
robtg
Oddometer: 675
Have you ever annealed any aluminum and actually checked the temp?
You may want to google "aluminum annealing temperature".
Old 01-21-2011, 11:20 PM   #38
M37cdn
Oddometer: 42
For annealing aluminum I always just mark the metal with a sharpie pen then heat with a propane torch until the sharpie mark disappears...Of course you could just use some 5052 marine aluminum that gets stronger when you bend it.
M37cdn is offline   Reply With Quote
Old 01-22-2011, 12:17 AM   #39
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,629
No. I think the point my PUI self was trying to get at was; I am under the impression that different alloys have different "annealing temperatures," and that the process isn't just a flash of heat. It's a controlled process that generally takes place over hours/days and I don't remember anyone saying what alloy it is. For a given alloy, though, what is a better method for a home shop than the torch?
For some reason, I only locked onto the "700" part of your response, but if you have a good resource that lists the "aluminum annealing temperature," I'm always willing to learn. I have access to 3 annealing ovens where I work, but I've never been the one using them..
crazydrummerdude screwed with this post 01-22-2011 at 12:41 AM
Old 01-22-2011, 01:54 AM   #40
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,669
Originally Posted by supershaft View Post
I have set up more than a couple of crankcase breather setups and the setups I see above would cause a potentially dangerous oily mess in my experience. Those setups will very quickly have oil dripping all over the bike including your tires! At least if you rev them and ride them hard!
+1
Same experience here
Rob Farmer is offline   Reply With Quote
Old 01-22-2011, 11:59 AM   #41
supershaft
because I can
Oddometer: 9,116
CCD, sometimes I wonder if you have an aversion to good, experienced advise?
The number "400" stuck out to me. That IS one number, not one hundred of them! I suspect that if 400 degrees did it the exhaust side of our heads would start to droop after a while.
supershaft is online now   Reply With Quote
Old 01-22-2011, 12:27 PM   #42
robtg
Oddometer: 675
Read this..... http://www.tinmantech.com/html/alumi..._continued.php
Old 01-22-2011, 02:48 PM   #43
fishkens
Further...
Oddometer: 5,148
Old 01-22-2011, 05:46 PM   #44
supershaft
because I can
Oddometer: 9,116
Always willing to learn? Eventually maybe? Like I have said to CDD before, that IS better than some! This is a perfect example at what I am getting at. He accuses robtg of something someone else is doing AND that someone else isn't making near as much sense as robtg while he is doing it!
All is well that ends well but why go through that?
Old 02-08-2011, 02:03 PM   #45
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,492
....so what's the final verdict here? Sounds like the long Triumph-style hose out the back fender that supershaft describes is the best and simplest aternative.
I was F'n arouund with my stock airbox last night (1981 flat filter). It has a Uni filter. After only ,200 clicks I was surprised by the oil inside. Granted the Uni may be part to fault, and I think it could make a better seal, as I noticed oil on the rear of the tranny that had drained out the reed.
So, I'm using the breather plumbing and rigging it to exit at the reed valve hole at the back of the air box and going to run a hose as described, up and out the back of the tail section.
Did this on my R100GS and never had a prob...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is online now   Reply With Quote
Times are GMT -7.   It's 09:53 AM.
