Old 11-08-2011, 03:52 PM   #586
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,424
Originally Posted by Stagehand View Post
Wow!!! That is pretty incredible!!!! I mean, I know you're good...but daym!
Old 11-08-2011, 04:02 PM   #587
petefromberkeley
Oddometer: 3,292
SO I made a bracket for the rear brake lever, today. It needs work, I'm going to make another one thats built just a little bit differently. But I think the theory works, so far.
Me weld pretty someday.
This picture reminds me to check the stud that you are mounting that bracket to. I have always tightened the shit out of that nut when putting the shock on, but (and you may be aware of this- I don't check here that often) one of our guys here recently had a prettty bad crash when that stud failed and just what you would think would happen happened.
Nine mile skid on a ten mile ride. Hot as a pistol but cool inside.
petefromberkeley is offline   Reply With Quote
Old 11-08-2011, 04:16 PM   #588
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,498
That stud has always stood out to me as a glaringly bad idea. Something that takes that much load, in a swing arm with so many bearings that are prone to knock, using a piece of steel pressed into cast aluminum and put in simple shear? Yikes.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-08-2011, 04:59 PM   #589
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,493
I know about Shaft's crash, and its odd. I'm trying to look up the shear strength for an M8 stud or whatever it is, just to have an idea in my head. I know as a rule of thumb, we in the staging business use a minimum 3/8" if there's going to be a human on it, so the thing is bigger by a little than that...ANYhow it would be the second failure I've heard about this stud if I heard about another one other than shaft's.
Despite the stud's possible dubiosity, the brake bracket gets almost no force one way or the other, I think. It shouldnt add much if anything to the bolt's shear load, I dont think, is what i'm trying to say. Please tell me if you think different!
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 11-08-2011, 05:38 PM   #590
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,493
Go look at it, Dan, I would be curious about your opinion.
That bike is a grin machine, aint it
Old 11-08-2011, 05:52 PM   #591
danedg
Horizontally Opposed
Oddometer: 6,616
225 today...3 tags....
The /2 would have cut me in half...lengthwise...
danedg is online now   Reply With Quote
Old 11-09-2011, 07:46 AM   #592
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,493
You arte too kind, really. Its really more a question of who has participated the most. I made three rallies last year, most guys only made one or two. No disrespect to Jim H, he is a great rider, but I am technically faster than him on the dirt. (He's primarily a street racer) but he went to Rally Tennessee, and was the only competitor, (!) and since it was technically a long enough race that under the rules, its a double-score rally, he got two first place points. Add to the fact that he then participated in both RWV and BRS and he accumulated enough points... same as me, sort of. Lots of faster guys, they're just not showing up
Racing is kinda funny like that. It only really proves that you happened to be the faster of the choices that showed up that day.
Nevertheless, I REALLY want to get back into the thick of it and twist teh grip with purpose.
Old 11-09-2011, 06:33 PM   #593
igormortis
igormortis's Avatar
Oddometer: 1,358
Don’t sell short the value of showing up. Gotta do that to be able to finish. Gotta finish to score points.
igormortis is offline   Reply With Quote
Old 11-09-2011, 07:51 PM   #594
MoMan
PigPen
MoMan's Avatar
Oddometer: 666
Well, I'm unemployed and have lots of garage time...wifey happy I'm out of the house
I found that if a brake cable in ANY configeration is mounted above the pivot points of the swing arm, it will cause the brake cable to pull in, i.e. apply the rear brake when the suspension is being compressed. It might only do this when your suspension is fully compressed...but that's not a good time coming off a jump or going through a rough section to apply the rear brake I've been working on a home-made bracket that bolts between the rear shock and the existing brake cable mount at the bottom of the final drive. This will bend the cable up to the upside-down brake arm while the pivot point is below the pivot point of the swing arm.
If I'm still unemployed at the time, I'll think about joining the Airhead Racing Team for the next Sandblast Rally.
I've not had a chance to try it out in practice, yet, but I will say the lever and cable are both currently bent from hitting in the rocks when it was down, precipitating me turning it upside down
Man I wish I had more days in the garage I just dont want to be unemployed to do it
It could be that the purpose of your life is only to serve as a warning to others.
MoMan is offline   Reply With Quote
Old 11-09-2011, 07:55 PM   #595
hardwaregrrl
ignore list
Oddometer: 7,424
Start saving your pennies....it's 260 bucks for rally fee and then you need a licsence. Yikes!
Old 11-09-2011, 09:46 PM   #596
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,493
I'll make sure you have a sticker if you do
I wonder if this is the reason the brain trust in the BMW world hasnt embraced this simple idea. Maybe its because the forward point is below the swingarm pivot? If it was directly in line with it it should work, regardless... I just cant figure the way it shouldnt work, unless the actual distance when its run over the swingarm just gets too long.
Touratech makes a doohicky like the one I think youre describing.
Old 11-09-2011, 09:47 PM   #597
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,493
To finish first, first you must finish. Or first you must be Finnish, haha, depending on the racing youre talking about.
Old 11-09-2011, 09:52 PM   #598
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,488
+1. that rocks! And you did on an air-cooled bike. Anybody can win...but can they win with style
Man I want to get in to racing. That looks like soooo much fun. My aunt gave me a truck (busted fuel pump. $200 & 6 hours and I got a 4x4!) so the G/S isn't my only form of transportation anymore. I've had nothing but a bike for 6 years. I reeeaaally appreciate being able to drink a cup of coffee while I'm going down the road I'll strip the racks and fairing off and I'll be looking to get a small tank. Of course, that's dependent on me getting a job and money :( Even then I may not be able to get off work. I might be one of those guys at the bottom of the list because they could only make it to one race.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 12-11-2011, 12:23 PM   #599
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,493
Hey I won a bunch of gear at the BMW MOA Trials, and it finally all came in
A Klim Latitude suit, from Klim,
a pair of SIDI Rain boots, by MotoNation
and an Arai XD3 helmet. by Aria.
Also fully responsible is Ian Schmeisser, of MOA fame, and the world. thanks man.
Stagehand screwed with this post 12-11-2011 at 03:04 PM
Old 12-11-2011, 01:06 PM   #600
Beater
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,252
I'm guessing that you are getting that little girl amazement/shock/disapproval look. I know it well. I'm typically on the receiving end of it.
PS - CONGRATS!!!!
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is offline   Reply With Quote
Times are GMT -7.   It's 05:17 PM.
