Thread Tools Rating: Thread Rating: 6 votes, 4.67 average. Display Modes
Old 01-20-2011, 09:43 AM   #1
Inane Cathode OP
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
Pokey the Wunderbus!
I think i should just start a build thread on my project here instead of bugging people in the regional forum ><
Pokey is a 1976 vw westfalia camper with a blown up motor. Or, partially blown up. Cylinder 3 has almost zero compression (i got it to 4 psi once!). Pokey will be getting a 2.2l sohc subaru motor this winter/spring. The goal is to get it done, tested, and take it on a road trip up to montana this summer. Theres lots of work ahead, but i would like to think i know what i'm doing (what is that saying of best laid plans?).
I've done this sort of thing once before, last summer, when i pulled the anemic 1600 air cooled lump out of my beetle (poor quality ignition parts roasted one of the cylinders, completely my fault) and stuffed in the same engine pokey will be getting. I learned a few things along the way with that, so this time around it should be a bit easier.
Anyhow, this will just be a pictures-with-text type of thing and i'd be happy to answer questions, comments, concerns, and threats along the way.
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 01-20-2011, 09:44 AM   #2
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
The first few posts will be from a build thread i have going on another forum, so please excuse the improper tenses :)
Alrighty well i talked to KEP and they say that as long as i use the 200mm clutch i can use the 200mm flywheel with any transmission. The bellhousing/input shaft confusion was just that. The input shafts are the same, but the bellhousing is larger to accept a larger flywheel. I opted to go with a 200mm kit with a much stronger pressure plate as there are far more options as far as pressure plates and clutch disks go.
Here's some pictures of the beast:
Ubiquitous interior shot:
Sure is slow driving on THREE CYLINDERS!?
This is the good side, the other is barf green:
And of course the lowly japanese lump that'll push it around some day:
_______
Pokey The Wunderbus
The VEEP Project
Old 01-20-2011, 09:45 AM   #3
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Woo! I got my harness, ecu, and exhaust manifold today. I got the harness the old fashioned way and tore the entire thing out without cutting anything (except obviously not engine stuff, namely the umbilical going back to the rear of the car).
That is ALOT of work, although the car was already mostly taken apart (steering wheel off, dash loosened). I had to take the dash out (unhook all the wires from it) take out the dash support frame (big piece of steel going left to right that stiffens the car) the heater blower (nice unitized construction, i might use that for my heater) evaporator core and box, heater core and box.
So now i have about 40 pounds in wiring i have to pare down to whatever is running the engine, shouldnt be too hard. Alot easier (technically not physically) than what i did with the Volksaru (i cut the computer harness, and the engine harness, and put them together later).
I'll get my camera going, this bundle of wires is pretty impressive.
Edit: Got some pictures
_______
Pokey The Wunderbus
The VEEP Project
Old 01-20-2011, 09:46 AM   #4
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Fat trimmed
Lean retained :)
_______
Pokey The Wunderbus
The VEEP Project
Old 01-20-2011, 09:47 AM   #5
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Update!
Did some more work with pokey today. More fat trimming:
This motor is absolutely gigantic. I could live in the engine compartment after the engine is removed:
In fact i think i might just do that:
Hmm, something is missing i just cant quite put my finger on it:
That is all, have a good day.
_______
Pokey The Wunderbus
The VEEP Project
Old 01-20-2011, 09:57 AM   #6
El Guero
V4 Whore
El Guero's Avatar
Oddometer: 9,727
I have had dreams about going on goofy adventures in a Westy and you may have figured out how to remove the major bummer of such an undertaking Is the VW to Subi conversion common or straightforward at all?
El Guero is offline   Reply With Quote
Old 01-20-2011, 10:08 AM   #7
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,212
Please don't take this wrong, but isn't that a lot of trouble to go to for a vehicle that seems to have rather bad case of Tinworm? I mean, I could see it if you were working with a rust-free barn or garage find, but it seems to me you could just as easily have named him Rusty.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 01-20-2011, 10:52 AM   #8
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
The biggest aim of the project is to have a functional camper/daily driver type bus. Even if i had a completely functional in every way brand new stock motor in there, it still wouldnt be functional. God bless the guys that can deal with 60hp in a 3600 pound truck but for the terrain around here that's just begging to be rear ended.
Its hard to tell some times if its straight forward, i think it's pretty straight forward and actually not that hard at all in a carving-an-elephant sort of way. Theres nothing really tricky about it that i can tell. For example: There is no cooling system, so you have to build one. But a cooling system is just a series of tubes and a radiator, with a fan coming on when it needs to.
The sub thing transformed my beetle from a godawful slow dont-take-it-on-the-interstate and maybe-it'll-start-today sort of vehicle to a 7% grade at 70mph, starts-when-it's-4* out sort of vehicle. I've put 15k miles on the beetle so far and have only had obvious problems (radiator mount wasnt good enough, rubbed a hole in the radiator, old crappy rad hoses developed leaks, things like that).
It's pretty common elsewhere (aus, uk, etc) and more so with watercooled vanagons (i like the bread loaf shape myself). The good thing is theres /lots/ of space to work with with a bus, i can tuck the rad lines up under the floor, computers have spaces to live in and so forth.
Meh, it is what it is i suppose. It's kinda hard to find any rust free buses, especially in my price range. If its rust free its restored, and if its restored i couldnt afford it. Rust is something i can fix along the way if i want. The rest of it is in pretty good shape (does need new seats, brake work) so I think it's worth it :)
As far as the extent of rust is concerned its not too bad actually. Both front dog legs (the little joggy thing under the front doors) need to be replaced (one is bent actually), part of the body rail under the not-sliding door side needs to be replaced, part of the lower B pillar, and i think a little section under the front apron. Theres nothing structural at all, and the vast majority of the flat panels are rust free, i think theres one blistery spot. When i got it, i made absolutely sure the frame and pan were rust free, they are. Body panels are easy to replace, frame pieces not so much (at least safely). It does need paint though, obviously! I'm thinking desert tan (flat) or something along those lines.
_______
Pokey The Wunderbus
The VEEP Project
Old 01-20-2011, 12:36 PM   #9
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
I wax and wane on the idea of fixing mine up or just selling it as is.
crazydrummerdude is offline   Reply With Quote
Old 01-20-2011, 12:43 PM   #10
DireWolf
Knees in the Breeze
DireWolf's Avatar
Oddometer: 13,336
You have very long big toes.
DireWolf is offline   Reply With Quote
Old 01-20-2011, 01:11 PM   #11
A-Bone
Indubitably
A-Bone's Avatar
Oddometer: 12,746
A-Bone is offline   Reply With Quote
Old 01-20-2011, 03:47 PM   #12
swede7000
Regular user...problem???
swede7000's Avatar
Oddometer: 1,641
Nice!
My neighbor is a bit of a VW junky (mildly... something like 6 bugs, 2 ghias, a station wagon, a thing, and a westfalia)! Last summer he picked up a clean westy and did the subary conversion. Seemed simple enough (he bought a whole swap kit somewhere?). I think it has somewhere over 200hp and runs soo smooth. Good luck with yours!
karl
swede7000 is offline   Reply With Quote
Old 01-21-2011, 08:42 AM   #13
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,212
Cool. Good to hear it.
-Chris
Old 01-21-2011, 02:50 PM   #14
airgord
What am I doing out here!
airgord's Avatar
Oddometer: 845
Do those Subaru swaps allow for A/C?
Riff Raff 2011
airgord is offline   Reply With Quote
Old 01-21-2011, 04:57 PM   #15
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,584
Good for you! Years ago I put together two halves of a 74 and 75 Westy to build my family a nice camper. The one that ended up being the parts car came with a Buick V6 in it that had 5 radiators and 3 heater cores placed inside and under the bus. Thankfully it didn't run when I bought it. I ended up with a nice, very slow stocker - automatic tranny too!
I'll be watching your posts.
Tom
madeouttaglass is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 09:19 PM.
