Thread Tools Rating: Thread Rating: 5 votes, 4.60 average. Display Modes
Old 01-21-2011, 07:06 PM   #16
CaptTeach
Oddometer: 209
I've got one of these - I figured to just boost the HP of the stock engine which is really not that hard to get 90-100hp out of one.
Mine kinda stalled as more customer projects came into the shop. Need to finish up the body work and then do the Lizard Skin and paint the interior. I have already cut the bamboo for the floor and the camper cushions are done. Other mods to come include custom bumpers, elevation change up about 2in and proper sized all terrain tires to fill the holes.
Looking forward to seeing how yours comes along
CaptTeach
96 Heritage Softail Classic
89 XT 600
71 CB 200 Cafe Racer
70 CL 100
63 Sporty XLCH
CaptTeach is offline   Reply With Quote
Old 01-21-2011, 07:31 PM   #17
emerson.biguns
All idiot, no savant
emerson.biguns's Avatar
Oddometer: 10,446
Originally Posted by DireWolf
You have very long hairy big toes.
Originally Posted by Inane Cathode
This is the good side, the other is barf green:
What year is the GPZ?
emerson.biguns is offline   Reply With Quote
Old 01-23-2011, 04:10 PM   #18
Inane Cathode OP
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
In the shots pictured you might find the following:
1983 gpz (just rebuilt the motor, not mine)
1976 rd400 (just sold this to my brother to finance the Pokey Project)
1981 tt500
1965 caprice coupe/4door (also not mine)
1967 ct90 (just put a new piston in it, but i got something goofy in the reduction box so it binds)
Update, dateline The Woods, temperature:20f wind:~20mph
The garage, as it were:
The motor is installed, sort of. It's up against the trans, the splines are meshed, but no nuts are on yet.
I had a hangup with one of the heater lines it took me a bit to find. I cut the hose off and bent the top line down about half an inch. I had to remove the EGR valve, it stuck out too much. Theres no way to rig it so the egr can stay, so i'll be making (40 dollars for a block off plate, lol) a plate to cover it.
I want to leave the throttle body as it is because i'd rather not go through the nightmare of the alternator versus the iac again. I also would like to see if i can run an a/c compressor as a regular compressor, just flip a switch and it'll start pushing air. Hmm.
Anyhow, i'll have to zip the nuts down, then go to work on making the motor mounts hook up to the frame. I'll be using the stock hangers on the frame, and the stock motor mounts on the engine. Maybe some square stock going up to the mount, to the other side, then back out to the other mount.
The motor is probably the physically hardest part. Nothing real tricky about it, line it up, push it in. I had an issue with the ramps being too high, so i had to jack up the right side, take the ramp out, and set it down on a jack stand thats about 9 inches lower. That did the trick :)
(thanks to joz on advrider for lending me his atv jack. worked perfectly just the way i hoped it would :))
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 01-23-2011, 07:50 PM   #19
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,862
Glad the ATV/Bike jack did its job. Looks like a great project! I love your 'garage'! Looks a bit drafty.
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is offline   Reply With Quote
Old 01-23-2011, 10:39 PM   #20
250senuf
250senuf's Avatar
Oddometer: 2,333
Nice "garage" I C. Been there done that; done with that!
250senuf is offline   Reply With Quote
Old 01-24-2011, 03:06 AM   #21
STROMVADER
STROMVADER's Avatar
Oddometer: 2,100
I see you have an old Yammie U7E in the background. I have one too!
You only LIVE once. Make it COUNT.
F*CK CANCER
Godspeed Dad! RIP 1944-2010
STROMVADER is offline   Reply With Quote
Old 01-24-2011, 11:06 AM   #22
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Almost, it's a qt50
_______
Pokey The Wunderbus
The VEEP Project
Old 01-28-2011, 03:39 PM   #23
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Did some more pokeylogical related activities today:
First off, nuts are tightened now the engine is supported by the trans mounts (temporary of course). The nut for the starter bolt took 15 minutes by itself to do up. No other way to arrange that i suppose but damn.
Took the stock exhaust, stripped the heat shields (and suspiciously asbestos-but-not-actually off of it. Then i whacked the exhaust off the flanges, shortened each piece where it goes onto the flange by about an inch and a half, shortened the bottom leg. This brought the exhaust up under the transaxle, plenty of clearance, and provides a handy and well oriented flange to build the rest of the exhaust off of. I thought i had a clever idea using a zip tie as a nut :B
Finished product: One pokey exhaust manifold!
_______
Pokey The Wunderbus
The VEEP Project
Old 01-29-2011, 08:54 AM   #24
MZcountryboy
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
That is looking like it will work out pretty good. I would put a new t-belt and w/pump on that subie motor before you button it all up.
I never really could understand how folks could drive those things around with so little power. The last one I saw around here had oregon plates, and a sticker on the back that said:
"The road is long and this bus is slow,
so if you need to pass me,
go, man, go."
I've got a customer with a vanagon converted to VW 2.0 inline 4cyl power.
I've also seen a vanagon syncro with a pontiac fiero v6 in it, man did that sound so sweet. (also the best use of a fiero I've ever seen!!!)
MZcountryboy is offline   Reply With Quote
Old 01-29-2011, 04:08 PM   #25
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Did astonishingly little in a long period of time today:
Made these thingies for the mustache bar
Then i made some of these plate thingies
Then i boxed them in (white with flux dust)
They go together like this (have to make another little piece to go between the mounts, it'll be a three piece deal, cant make it one piece with the way the motor mount studs are pointed
Then i found a new and exciting way to break a cheap drill
Meh, i got more than $20 worth of use out of it, i'll just exchange it tomorrow :)
_______
Pokey The Wunderbus
The VEEP Project
Old 01-30-2011, 07:44 PM   #26
Joz
Joz's Avatar
Oddometer: 1,862
Lookin good, but did you actually weld your engine mount bracket to the shock?
Old 01-30-2011, 07:47 PM   #27
jdiaz
Oddometer: 32,225
Don't forget to take the fuel tank out and have it dipped while the engine bay is empty. Maybe even throw a new fuel gauge sender in there.
jdiaz is offline   Reply With Quote
Old 01-30-2011, 09:02 PM   #28
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Just a trick of the eye.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 01-31-2011, 04:01 AM   #29
CHANGELING
Oddometer: 301
I really loved and miss my old Type 2 twin sliding door bus. If it had been 4x4 and had this kind of motor I would have put up with welding up the rusty front beam every two years
CHANGELING is offline   Reply With Quote
Old 01-31-2011, 09:42 AM   #30
airgord
What am I doing out here!
airgord's Avatar
Oddometer: 845
Meh, i got more than $20 worth of use out of it, i'll just exchange it tomorrow :)[/QUOTE]
Had two of those, now I have one, save the parts from the broken one because they WILL come in handy!
Riff Raff 2011
airgord is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 02:24 PM.
