Old 02-04-2013, 11:20 AM   #31
beek-02
blazing a trail
beek-02's Avatar
Oddometer: 113
Co2 becomes liquid under certain pressure, think it's around 700 psi. Not sure if shock head pressure could hit that during use but if it did I would think it could make some weird things happen.
Sent from my SCH-I535 using Tapatalk 2
"Opinions are like a$$holes. Everybody's got one and everyone thinks everyone else's stinks."
beek-02 is offline   Reply With Quote
Old 02-04-2013, 11:28 AM   #32
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,199
CO2 might not work so well if you ride in really cold temperatures. At that pressure it can liquify if it gets really cold- zero degrees F sort of thing. That probably won't hurt anything, the shock just won't work quite right until it warms up.
If that bothers you, use air. It works fine. The only hard part is getting the pressure right if you use a regular air chuck, an MTB shock pump is perfect for this.
Luke is online now   Reply With Quote
Old 02-04-2013, 09:34 PM   #33
Desert Silver
Desert Rat
Oddometer: 13
Originally Posted by bmwktmbill View Post
Desert,
My guess is that N is more stable temperature wise than CO2.
The shock gets hot.
Some Tire shops might have N in a tank if you ask around.
bill
Ya I know, I'm just going to use the Co2 for one short ride and then switch over to N2. My main concern is CO2 screwing up the reservoir in some way. I don't want to invest in the N2 until I'm sure the shock is working ok. I can probably get it filled at Noleen for a small amount of money. It's to bad they don't make N2 cartridges like they do Co2 cartridges. It was actually very easy to get the pressure right with the Co2 tire filler. I would use just plain old air but I haven't been able to get my silka bike pump sealed up enough to pressurize the shock that high.
Desert Silver is offline   Reply With Quote
Old 05-02-2013, 12:53 PM   #34
picklito
Oddometer: 1
For the WP 4681, this thread is by far the best How-To on the net! Thanks.
As many of you may know, the WP4681 also comes on lots of the linkage MX bikes '94-older, before KTM's brief use of Ohlins. Thanks to this thread, I have found that many of the small service parts listed here work for that shock as well. Things such as O-rings, dust seals and so on. It's tough to find an exploded view of that earlier shock, and many of the original part numbers have been updated to what's shown here. Searching for the old part numbers doesn't get very far! So the part numbers listed here are very helpful. The seal head was updated to what is pictured in this thread around '91 on the MX bikes. My older stuff has a multi-piece seal head that is not nearly as good. Although I have not yet needed to, it may be possible to swap in this later stuff if we also use the matching end cap.
picklito is offline   Reply With Quote
Old 06-26-2013, 08:18 PM   #35
sellmeyer
Oddometer: 410
question to followers of this thread
I've posted a comparison thread [here]
I'm wondering if the shock featured in this post is similar enough to my own mystery shock for me to order the parts that Tseta lists in his original post?
I'd appreciate some feedback on my thread.
-thanks
Sellmeyer
sellmeyer is offline   Reply With Quote
Old 06-26-2013, 09:54 PM   #36
bmwktmbill
Traveler
Oddometer: 5,195
Sellmeyer,
http://wpracingusa.com/
Call them.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Times are GMT -7.   It's 09:22 AM.
