Old 01-22-2011, 07:24 AM   #1
wpbarlow OP
Oddometer: 11,510
Triumph Tiger 800XC front wheel question
Does anyone know for sure if the 19" front wheel from the more street oriented Tiger is a direct swap in for the 21" on the XC?
I eyeball measured things at the show last night and it looks like it should.
Thanks.
wpbarlow is offline   Reply With Quote
Old 01-22-2011, 09:33 AM   #2
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
Thanks.
I don't know anything, but I'm going to say no, it won't be a direct swap.
G.
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 01-22-2011, 09:55 AM   #3
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,788
For what it's worth, I seem to recall reading somewhere that someone at Triumph addressed the question of putting Tiger 800 cast wheels on the XC, and they strongly discouraged it because of its effect on steering geometry. Keep in mind the XC already has very steep rake; putting a smaller front wheel on will drop the front end and make the rake even steeper.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 01-22-2011, 10:06 PM   #4
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,269
--mark
Interesting comment on the rake. Check this out:
BMW F650GS DAKAR 29.2 (degrees of rake)
SUPER TENERE 1200 28.0
KTM 990 26.6
BMW R1200GS 26.2
BMW F800GS 26.0
DUCATI MTS1200 25.0
TIGER800 23.7
TIGER800XC 23.1
BUELL XB12X ULYSSES 22.0
Yep, it's steep to begin within.
Speculating on the back of an envelope:
Moving from a 21 inch to a 19 inch wheel should be an equivalent of a 1 inch (25.4mm) reduction of fork length at the axle?
If so, applying the rule of thumb that 10mm fork length change is a 0.5 degree rake change (more or less), a 25.4mm fork equivalent reduction would take this bike to a rake of just about less than 22 degrees?
If that is true, what are the effects on bike handling?
Quicker steering (more direct effect from steering to wheel turn), less stability at speeds?
I should let the experts chime in. I'm way out of my field of knowledge here.
Lion
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR screwed with this post 01-23-2011 at 11:46 AM
Lion BR is offline   Reply With Quote
Old 01-23-2011, 03:38 AM   #5
dfishman
dfishman's Avatar
Oddometer: 173
Well my 17 that replaced the 21 on my XR650R helped so much I slid my tubes up another 1/4" to even decrease it more.I would say it would change it but it is NOT going to be a radical change.
dfishman is offline   Reply With Quote
Old 01-23-2011, 11:45 PM   #6
randel
randel's Avatar
Oddometer: 318
Why would someone use 19" cast wheels for 800XC? It's much cheaper to buy Tiger800 instead?
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 01-25-2011, 06:29 AM   #7
markbvt
Oddometer: 2,788
Quite a few of us were initially thinking that it would be nice to get the cast wheelset for the XC and keep it shod with street tires, while keeping knobbies on the stock spoked wheels -- this way we could quickly swap wheelsets depending on what kind of riding we'd be doing.
--mark
Old 01-26-2011, 06:32 PM   #8
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
The other issues are possible differences in rotor and brake caliper lining up from XC vs. Road version. An adapter could be fab'd , no idea how it might affect handling. I'm sure someone will try it at some point.
I'm with Mark. I'd rather find a cast, tubeless, 21" front to run a street tire, or just a spare stock front wheel. Keep the original XC spoked wheel with a knobby mounted up. Whatever.
Old 03-01-2011, 05:30 AM   #9
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,897
My eyeball rule suggests that the rears are a straight swap (they certainly mount the same size tyre) and that would be the way to go if I got an XC because most punctures I've had in the past 20 years have been in the rear.
For the front, you've gotta wonder if an R100GS wheel (with an extra disc) will go in. Keeps the 21" but is tubeless. Or, the wheel from the new Super Tenere.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger screwed with this post 03-01-2011 at 05:54 AM
blacktiger is offline   Reply With Quote
Old 03-01-2011, 07:17 AM   #10
markbvt
Oddometer: 2,788
If your primary concern is the wheel being tubeless, not its diameter, it would be a lot easier to just send your stock wheel to a specialist like Woody's to be sealed.
--mark
Old 03-01-2011, 10:36 AM   #11
Adv Grifter
Oddometer: 6,128
The new Yamaha Super Tenere' wheel is also a possibility. Pretty trick system. Don't know who makes it ... most likely either DID or Excel ...
It uses a trick raised center bead where spokes fasten in, but it's a tubeless wheel. Should be very stout off road ... looks good too.
I'd bet someone could adapt it to the Tiger 800 or maybe whoever makes it would make one to fit the Tiger? I'd bet they'd sell hundreds.
The Tiger 800 needs these wheels!
Old 03-01-2011, 11:11 AM   #12
TAMPAJIM
Oddometer: 494
Looks like it may collect mud, sand, pebbles and other stuff.
__________
Jim
TAMPAJIM is offline   Reply With Quote
Old 03-01-2011, 01:29 PM   #13
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,933
Yea Barlow, what he said, of course you could just step up to the...........
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 03-02-2011, 08:19 PM   #14
numbat
Oddometer: 82
Trick wheels eh?
Strait pulls, like the BM's have used for more than a decade.
numbat is offline   Reply With Quote
Old 03-02-2011, 09:14 PM   #15
Adv Grifter
Oddometer: 6,128
Yamaha are not using the tubeless Behr Cross spoke perimeter design as used on BMW GS's. Not even close to the Yamaha design. The GS Behr wheels are notorious for being soft ... easily dented off road. See Woody's Wheel Works and ask him how many GS riders have swapped stock Cross Spoke Behr wheels for the Japanese Excel wheels he sells.
I'm guessing the Super Tenere' uses Excel wheels ... not Behr.
Any bets they'll be very hard to dent? ... unlike the butter soft Behr product.
Times are GMT -7.   It's 02:51 AM.
