Old 01-23-2011, 02:21 PM   #1
AlanCT OP
The Byronic Man
AlanCT's Avatar
Oddometer: 3,470
Ural ignition
I just noticed that I have the 2 piece interruptor. It has not caused any trouble, but it is just a matter of time so I am going to order a 1 piece.
While I'm at it, I am thinking of getting either:
A. a spare Type V in case mine dies, or
B. a complete points setup to keep as a backup (anyone know where to get one?)
A Ducati ignition or Power Arc are too expensive for me right now. What say ye?
"You wouldn't be riding a motorcycle if you weren't an optimist."
- Matthew Crawford
2005 Ural Tourist, 2000 Kawasaki W650
IBA #23064
AlanCT is offline   Reply With Quote
Old 01-23-2011, 02:36 PM   #2
windmill
windmill's Avatar
Oddometer: 4,084
Points don't have the "advantages" of electronic ignition, but can last a lifetime and is a very inexpensive option for a "backup".
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 01-23-2011, 04:45 PM   #3
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,421
Ducati I believe is the manufacture of the new ing system.
Specially made to up grade the Ural.
But many are still using the original system w/o an issue.
Wolfgang55 is offline   Reply With Quote
Old 01-23-2011, 05:46 PM   #4
AlanCT OP
The Byronic Man
AlanCT's Avatar
Oddometer: 3,470
Yes, but it is hundreds of dollars. I am looking for cheap backups in case my Type V fails.
- Matthew Crawford
IBA #23064
Old 01-23-2011, 06:56 PM   #5
Sidecardoug
Pleasantly pleasing
Sidecardoug's Avatar
Oddometer: 1,796
You're mixing up two possible problems. If the two piece interrupter comes apart, it will not read right. The fix there is a new (or spare) interrupter. If the Type 5 module fails, you have to replace it. That's a separate problem. I think, could be wrong, that a points system will be work around for either failure. I have had a Type 5 fail. It does so without warning and you're dead in the water until you replace it.
The best lack all convictions, while the worst
Are full of passionate intensity.
Sidecardoug is offline   Reply With Quote
Old 01-23-2011, 07:01 PM   #6
AlanCT OP
The Byronic Man
AlanCT's Avatar
Oddometer: 3,470
Oh, I know it's two separate issues. Actually, I have no ignition problems at all. Replacing the interruptor is a preventative measure, and getting a (cheap) backup for the Type V is just some extra insurance/peace of mind.
- Matthew Crawford
IBA #23064
Old 01-24-2011, 10:42 AM   #7
heindlengineeringura
svman00
heindlengineeringura's Avatar
Oddometer: 123
New Type V is not available, so if it goes, you would have to replace it with either the new duc, powerarc, or go back to points.
I would switch the rotor out before you have problems with it. You could also remove the current two piece rotor and weld it to keep it from spinning.
Heindl Engineering, LLC
Ural Dealer in SouthWest Ohio
(937) 787-3686
Heidenau Tires
http://www.heindlengineering.com/Onl...enau_tires.htm
sales@heindlengineering.com
heindlengineeringura is offline   Reply With Quote
Old 01-24-2011, 04:10 PM   #8
AlanCT OP
The Byronic Man
AlanCT's Avatar
Oddometer: 3,470
I sort of like the idea of old school points, and I may keep my eyes open for a used Type V. A new Ducati or Power Arc is a bit too much money just to install it as a preventative measure.
- Matthew Crawford
IBA #23064
Old 01-24-2011, 09:23 PM   #9
Ivan Rider
Ivan Rider's Avatar
Oddometer: 598
I worried about the Type III ignition failing on my first Ural 11 yrs. ago and bought a points kit to carry. After 10 yrs of carring it I finally took it out of tool box un-used. I still have it somewhere but It will not fit my New Ural as they no longer drill and tap the front of the engine case to mount it. I recently saw some Point Kits on E-bay.
'78 BMW R100/Ural sidecar, '99 Ural Patrol
'03 BMW R1200CLC Solo & Ural sidecar Rig
'06 Honda Big Ruckus Solo & Sidecar Rig,
'08 Ural Retro, '10 Ural ST Solo
http://www.flickr.com/photo s/ivanrider/
Ivan Rider is offline   Reply With Quote
Times are GMT -7.   It's 11:32 PM.
