Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 01-28-2011, 02:30 PM   #1
moron OP
alright guy
moron's Avatar
Oddometer: 1,149
Sandbags in pickup trucks
So I HAVE to know: If you put sandbags in the back of your 2WD pickup for traction should you
1) Put them directly over the rear axle
OR
2) Put them as close to the rear of the bed as possible because you gain a leverage advantage which results in more effective weight on the tires
Yes I'm no Archimedes
said about me: Even Christ would not want to be your brother in Christ.
Jump kisses in the night
moron is offline   Reply With Quote
Old 01-28-2011, 02:37 PM   #2
ginslung
It'll take.
ginslung's Avatar
Oddometer: 234
Centered over the axle is ideal, but anything helps. I use 50lb bags of garden soil instead of sand - spring comes and you can dump it in the garden or on the lawn.
Edit: Ran across this thing awhile back - interesting idea. http://www.shurtrax.com/
ginslung screwed with this post 01-28-2011 at 02:50 PM
ginslung is offline   Reply With Quote
Old 01-28-2011, 02:38 PM   #3
D R
Oddometer: 527
The best location may vary based on your pick-up truck. For my two-wheel drive Ford Ranger, placing them all the way up against the tail gate seems to work best for me.
D R is offline   Reply With Quote
Old 01-28-2011, 02:42 PM   #4
lunchmeat
MLI
lunchmeat's Avatar
Oddometer: 297
Depends on the vehicle and the weight up front too. Too much weight or too much leverage and you loose braking ability and steering off the front. Worse case scenario the front wheels just slide instead of grabbing traction and the rear follows the front into the ditch.
Cognito ergo armatum sum.
lunchmeat is offline   Reply With Quote
Old 01-28-2011, 02:43 PM   #5
Ratski
Ratski's Avatar
Oddometer: 764
If you put it as far back as you can, you will effectively remove some weight from the front of the truck.
I built a frame to keep mine over the axle. Just some 2x4's and some wood screws, I has 280 lbs of sand in there, in the back of my 95 S-10 it works good.
Ratski is offline   Reply With Quote
Old 01-28-2011, 06:09 PM   #6
Mgbgt89
Mgbgt89's Avatar
Oddometer: 1,715
Putting weight in the very back works well, but all that weight behind the axle can really slingshot the ass end around, which is fun, as long as you expect it. Over the axle works best for traction while still keeping the handling somewhat neutral.
Mgbgt89 is offline   Reply With Quote
Old 01-28-2011, 06:14 PM   #7
stretch160
stretch160's Avatar
Oddometer: 635
I put 120 lbs behind the axle on my 02 S10 and found it not only improved traction but the ABS functions much better with some extra weight back there.
stretch160 is offline   Reply With Quote
Old 01-29-2011, 04:31 AM   #8
Richy
Richy's Avatar
Oddometer: 515
I used to use water softener salt in my El Camino, over the axle.
Richy is offline   Reply With Quote
Old 01-29-2011, 05:09 AM   #9
randyo
randyo's Avatar
Oddometer: 1,807
? explain better
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 01-29-2011, 05:38 AM   #10
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,527
& w/ a clean bed
At one time I made a 6" I/D pipe & put extra tow chain inside it. Press in friction incerts at both ends. Took off the stock bumper & weld the renforced mounting brackets to the pipe; bolt the pipe bumper back in place.
Kept my bed clear for the "blue astro turf", it matched my girl friend's eye.
That's right she had just one.
Wolfgang55 is offline   Reply With Quote
Old 01-29-2011, 07:40 AM   #11
Snowbird
Oddometer: 639
Definitely over the axle, not behind it... providing you consider steering important.
Snowbird is offline   Reply With Quote
Old 01-29-2011, 08:42 AM   #12
corzapp
Every ride an adventure
Oddometer: 33
Living in Minnesota my whole life I always like to keep it up against the cab most of the time but moved back to over the axle during snow storms and out to the tailgate if you get stuck.
corzapp is offline   Reply With Quote
Old 01-29-2011, 11:11 AM   #13
Zerk
DILLIGAF
Zerk's Avatar
Oddometer: 3,204
I have wondered this too. Agains the cab, I think would be the worse place.
You want the want on the rear tires. So does having it all the way back create a lever?
I just don't worry that much and throw it back there.
Actually I haven't carried weight in a long time. Its to much of pain to get out when I want to haul something. When I was younger I used to put cement blocks, but then they would get frozen to the bed, same with sand.
Letting it fill up with snow, provides some weight.
My truck is 4wd, I just don't like putting in 4 all the time.
Berserker
In my travelling heart, there's an urge to see
foreign lands and alien birds, hear stories that no ones heard-D.A.D.
Helmets are like rubbers, you know you should wear one, but its so much better when you don't-Me.
Zerk is offline   Reply With Quote
Old 01-29-2011, 02:06 PM   #14
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
my friend did the same thing. works perfect to add 280lbs right where you need it.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 01-29-2011, 02:34 PM   #15
Uglyprimate
UglyPirate
Uglyprimate's Avatar
Oddometer: 6,944
More important about where you put it is HOW MUCH you use.
Very few people use enough. 300-400 is good, put some towards to front to increase the turning ability on the front wheels.
I always shovel the driveway into the bed of the truck with the first snow. It's free and unloads itself when no longer needed.
"Beauty sleep?" Bitch, you don't need a nap, you need to HIBERNATE!
Uglyprimate is offline   Reply With Quote
Times are GMT -7.   It's 12:12 AM.
