Old 02-09-2011, 12:51 PM   #16
sp4ce
Orange Invader
sp4ce's Avatar
Oddometer: 431
Originally Posted by matrixadventure View Post
I have just joined, so this post might be a bit late...
My '08 Adv S also had a weeping problem and I had it replaced with an aftermarket Magura unit for +/- $60 plus a lot for the oil.
It works fine.
Got a part number or any other identifying information
sp4ce is offline   Reply With Quote
Old 02-09-2011, 01:00 PM   #17
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Here is Magura's Website on this:
http://www.powersports.magura.com/pr...p-0120576.html
Not much help with any Technical information.
AdvGa is offline   Reply With Quote
Old 02-11-2011, 01:32 PM   #18
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Here's a Finished Front view with the DoubleTake Mirror installed on the Right:
AdvGa screwed with this post 02-11-2011 at 02:49 PM
Old 02-12-2011, 07:17 AM   #19
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,339
That was a helluva project and well done!
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 02-12-2011, 08:30 AM   #20
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Thanks Chuck.
I just had to determine Other Options on this important device other than a choice of Just 1 item that seems to me, has some sketchy quality issues.
It took less fabrication than I had anticipated and well pleased with the results. Helpful to be able to See and anticipate the Fluid Level so I won't get caught off guard again.... especially while you are taking trips in those remote areas.
Hope this post is able to help others with some Viable Options should they come to this fork in the road.
Old 02-12-2011, 08:51 AM   #21
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,339
Is there a moderator in the house? Do you agree this should be added to the Orange Crush Thread Index at the top of the page?
Old 02-12-2011, 08:58 AM   #22
elias
elias's Avatar
Oddometer: 290
Hope this post is able to help others with some Viable Options should they come to this fork in the road.[/QUOTE]
Please tell me that this thing works. iam tired of riding back home without clutch. had also such problems. the reservoir came with the clutch or is it yours? about the chock plate, you only tieded it?
elias is offline   Reply With Quote
Old 02-12-2011, 09:10 AM   #23
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Yes it works....rode 1/2 a day with it yesterday.
Note: I think the Stock Magura is a 9.5 or 10mm Cylinder, this unit is a 16mm Cylinder (notice Diameter Sizes in the Side by Side Pic) and takes less travel to get the job done.
The Reservoir (20 CC Unit Shown) , does not come with the unit,
but sold in a Universal Kit with different sizes. I purchased this one in a rush and probably could have found a Smaller Size...but it works fine. Pending what Master you get, they have the Reservoir Kit options usually on the same page.
Hope this helps.
AdvGa screwed with this post 02-18-2011 at 12:46 PM
Old 02-13-2011, 09:12 AM   #24
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Elias,
The Old Clutch Master Cover/ w/Choke Trigger Mechanism (Chock Plate), I kept in place by putting 2 Screws w/Nuts/Washers in the Existing Holes and Ran a Wire under the New Master from Screw to Screw w/BlueLoctite (See the Choke Plate Bottom View Picture on Previous Page). This holds it in place and used Some Velcro Underneath the platch to assist holding it in place.
Hardly ever use the Choke anyways...but it is there when the need arises.
Old 02-18-2011, 10:24 PM   #25
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Here is the Lever/Plunger Side of the OEM Clutch Master Cylinder View:
The Cotton Swap from inside cylinder shows remnants of aluminum wear.
Below it, is the 9 month old Plunger/Spring from the Rebuild Kit.
Old 07-24-2011, 02:05 PM   #26
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Originally Posted by AdvGa View Post
...View with Clutch Master Removed: (I elected to UnSolder the Brown/Yellow Wire to the Clutch Switch (disabled it anyway at the Kickstand), since did not want to remove the whole Cable)
Update this process. SOLDERED the Yellow & Brown Wire together so one can Start the Bike in GEAR.
After a few thousand miles... still working like a champ.
Old 07-24-2011, 03:18 PM   #27
Deviant666
Present
Deviant666's Avatar
Oddometer: 535
Well so that you don't feel alone, I have changed two MCs so far and I'm a little shy of 22k miles. My bike is a 2009, and sees a lot of heavy traffic (hence many slipping clutch cycles). Now, I'm currently in Belgium, far from home (Greece) and I noticed oil "mist" on the lever joint which tells me that this one's about to go bad too. Since I'll be passing from Austria, I'll make sure that I get a new one under warranty (last month of it actually) and give em a nice shake about this specific yet very easy to address problem. Since I reach the KTM factory I'll be shifting clutch-less as much as possible. On the bright side, my very trusty mechanic in Greece told me that the Superduke MC is much better (and more expensive) and will solve the problem (he said permanently)...We'll see.... BTW I'd be happy to ask anything you guys want while visiting the sacred KTM sanctum...Cheers..
Deviant666 is offline   Reply With Quote
Old 07-24-2011, 04:14 PM   #28
AdvGa OP
AdvGa's Avatar
Oddometer: 1,320
Devian,
Good Luck with your trip.
The Adventure 950 OEM is a Magura is a 8, 9.5, or 10mm Cylinder, where my upgrade brings it to a 16mm with much less travel and better build...IMHO.
I think the SuperDuke OEM is Brembo 16mm Radial or an upgrade:
http://www.ktmtwins.com/ktmtwins-rc8...ial-clutch-kit
This is why I went with the Accossato Radial 16 RCS which is basically the same thing here in the States:
http://www.solomotoparts.com/product...5&cat=0&page=1
AdvGa screwed with this post 07-24-2011 at 04:39 PM
Old 07-25-2011, 02:36 PM   #29
Subutai
Oddometer: 555
'10 R here and I think my master is weeping/misting around the reservoir cap, which is retained with two screws. Currently keeping an eye on it. It doesn't show liquid, but it doesn't seem to collect any dust around the cap/looks abnormally clean.
Subutai is offline   Reply With Quote
Old 07-26-2011, 12:17 AM   #30
Dale950
Dale950's Avatar
Oddometer: 978
Mine's been leaking for quite some time , put two kits through it , been thinking of having the master re sleeved in Stainless .
This place looks like they be worth talking to , shame there not in Oz
http://www.resleeve.com/sleeving.htm
Dale950 is offline   Reply With Quote
Times are GMT -7.   It's 10:19 PM.
