Old 04-07-2013, 09:46 AM   #76
Dracula
Deus ex machina
Dracula's Avatar
Oddometer: 1,620
Originally Posted by Guy Young View Post
Vic, his bike has right around 77K on it.
... he seems to have a tendency to really slip the clutch when starting out.... whether it be at a stop light or whatever. He really brings up the engine RPM and feathers the clutch (IMHO - excessively) to get under way.
Thanks much for responding. On the GS during the years I find no need to rev the engine above 2,000 rpm to get started. Maybe even less. And I keep slippage time to a minimum, either engaged or disengaged for street riding. It just feels right this way. The motor has so much torque that it will not bog down and can be lugged without problems. Can also start in 2nd gear without much issue if needed.
Only time slippage seems necessary is if doing trick uphill starts. Or if trailing rear brake in some tight turns. Off road may involve different techniques but other than uphill or deep sand starts and tight turns can't think of other cases. Seems slippage at slow clutch rotational speeds is what will put allot less wear. Some say it is better to keep stock clutch as it was designed as sacrifice wear item vs. other more expensive transmission parts.
Thanks for posting your work, will follow along to see the project through.
Best,
Vic
I have personal opinions, but don't agree with them.
North Carolina To Albuquerque via California
NY to Alaska and back
Dracula is online now   Reply With Quote
Old 04-07-2013, 10:22 AM   #77
Guy Young
Guy Young's Avatar
Oddometer: 8,498
Best,
Vic
Am looking forward to seeing this thing to completion too. My apologies for not being as detailed and organised as jdub did in his original write-up. Once my hands get greasy, the Powershot doesn't get used until I'm at a convenient stopping point.
The GSA's owner also has these in his stable: '07 BMW R1200 GSA (one I'm working on), '05 Honda CRF230F, '62 Ducati 200 Elite, and a '61 BMW R50/2. I've ridden with him all all of them, and he uses the same slippage routine to get rolling. I really can't comment on the CRF230F. I was the one slipping the clutch on my KLR on some of the God-forsaken places he led me to. I was (and still am) nursing the mental image of busting my collarbone up in MT several years ago, and some of the places we went had my anal sphincter puckering big time. Never thought I'd get out of there fully intact with all limbs still functioning.
Regardless, we'll keep the pix coming as we move forward.
'07 BMW R1200 GSA,'05 Honda CRF230F,'62 Ducati 200 Elite,'61 BMW R50/2
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Old 04-09-2013, 12:19 PM   #78
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,359
Rode over to my friend George's shop Picked up a nearly new clutch for 1/3rd of new.
Old:
New and old:
New:
Next it goes back in as soon as I receive the new seal for the leaky motor.
For anyone needing BMW motorcycle work, george is the best!
Jim
PS
Beemers Uber Alles
9248 Mike Garcia Drive
Manassas VA 20109
(571) 318-2472
Old 04-09-2013, 01:14 PM   #79
Makkan
Oddometer: 5
How did you bleed the brakes? Almost finished now..
Makkan is offline   Reply With Quote
Old 04-09-2013, 02:06 PM   #80
Lensgrinder
Oddometer: 1,323
When I did mine I used a "Mighty Vac" which worked fine.
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is offline   Reply With Quote
Old 04-09-2013, 05:55 PM   #81
JimVonBaden
"Cool" Aid!
Oddometer: 53,359
I haven't quite gotten there yet, but likely will do the same.
Jim
Old 04-12-2013, 08:15 AM   #82
Makkan
Oddometer: 5
Mighty vac? Never heard of a thing like that but it seems handy. Can i use the good old method of pulling the brake and opening the vent as well, the same as i do on cars? And what about the ABS thing under the tank where i disconnected the brake lines? Does it not need venting or is that not a part of the system? A little oil from the brake lines got out when i disconnected them and now the rear brake is not working at all
The bleding screw was broken at my rear brakes but a new one is on its way from germany
Old 04-12-2013, 11:01 AM   #83
JimVonBaden
"Cool" Aid!
Oddometer: 53,359
That usually works just fine. The Mighty Vac just makes it work faster, or when you get a vapor lock.
Jim
Old 04-12-2013, 07:22 PM   #84
TXjames
High Sider
TXjames's Avatar
Oddometer: 1,091
Thankfully BMW went back to a system that is easy to bleed. As JVB mentioned, the conventional method works just fine. But if you do still have issues, the folks at GS911 added a function that allows you to cycle the ABS module to remove any trapped air. I played with it after I split my bike in two and it seemed to work as described. Although I didn't actually have issues after a conventional bleed. I suspect you won't need it either. But be sure to keep dirt out of the ABS system while you have the lines open. I purchased some rubber plugs from the hardware store to jam in there while servicing then cleaned thoroughly before reassembly.
Roll The Bones V - No premature incinerations. Oct 24-26, 2014.
http://www.rollthebonesrally.com/
TXjames is offline   Reply With Quote
Old 04-14-2013, 03:21 PM   #85
JimVonBaden
"Cool" Aid!
Oddometer: 53,359
Finished the clutch change on my friend's BMW R1200GS:
Jim
JimVonBaden screwed with this post 04-22-2013 at 07:53 PM
Old 04-14-2013, 05:18 PM   #86
Dracula
Deus ex machina
Dracula's Avatar
Oddometer: 1,620
Originally Posted by JimVonBaden View Post
Thanks Jim!
From this picture it looks as if with gearbox in place there is an open area above the clutch so it can be inspected and perhaps even lube the splines. Maybe I am not seeing it right, I never took my GS apart that far.
Best,
Vic
Old 04-14-2013, 07:48 PM   #87
JimVonBaden
"Cool" Aid!
Oddometer: 53,359
Thanks Jim!
Best,
Vic
There is a cover at the top of the gearbox that comes off. However, you need to remove the frame to get to it, so you may as well remove the gearbox and do a proper inspection.
Jim
Old 04-14-2013, 09:01 PM   #88
Dracula
Deus ex machina
Dracula's Avatar
Oddometer: 1,620
Jim
I see. Wondering how much longer I can postpone this. My GS has 85,000 miles but the clutch feels as good as it always did. I use the clutch quite normally for a dry clutch and am not sure how long they are expected to last and if they give signs of fatigue or just fail.
Best,
Vic
Old 04-14-2013, 09:11 PM   #89
KMC1
There is no spoon.
Oddometer: 2,561
This is a terrifying thread.....damn.... I really (really, really) do not want to get this deep into mine.
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 04-15-2013, 05:31 AM   #90
JimVonBaden
"Cool" Aid!
Oddometer: 53,359
Best,
Vic
The R1200 series appears less prone to damage of the splines than the 1150 series, so if you are riding normally, not excessively slipping the clutch, and have no shifting issues, I would not sweat it and ride. Most will never find the point that caused this teardown.
Jim
Times are GMT -7.   It's 01:16 PM.
