Old 01-31-2011, 08:50 AM   #1
JNRobert OP
Breaking Wind
JNRobert's Avatar
Oddometer: 9,730
Hole in the Fuel Tank - how to repair?
What's the best way to patch a small hole (it's about the size of a number 6 nail) in a gas tank? It's in an area that doesn't need to be painted as it's covered by plastic fairing parts.
Epoxy? Weld? some special concoction? (I'm hoping epoxy is the answer)
Crusader of Slack
JNRobert is offline   Reply With Quote
Old 01-31-2011, 09:59 AM   #2
ivantheterrible
Oddometer: 560
How did the hole get there? The reason I ask, i have found that if it's rust, then the metal around the hole isn't very strong and needs to be looked at as well. As to the repair, I prefer to braze it, but I hope others will say good things about epoxy also!
ivantheterrible is offline   Reply With Quote
Old 01-31-2011, 10:33 AM   #3
JNRobert OP
Breaking Wind
JNRobert's Avatar
Oddometer: 9,730
No rust. Accidentally punched a hole with a sharp object. It's small and no other damage and its a new tank.
Crusader of Slack
Old 01-31-2011, 11:14 AM   #4
Speedo66
Transient
Oddometer: 6,684
I repaired a large hole in a car gas tank (lowered BMW, high manhole) with a product called Marine-Tex (the gray version for metals). You can find it in most marine product (boat) stores. http://www.jamestowndistributors.com...rine-Tex+Epoxy
It was still holding years later when I sold the car.
JB Weld and dedicated 2 part epoxy gas tank repair products were tried first, they all leaked.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is online now   Reply With Quote
Old 01-31-2011, 11:17 AM   #5
fast4d
Oddometer: 2,277
tank is steel, alum or plastic?
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 01-31-2011, 11:47 AM   #6
JNRobert OP
Breaking Wind
JNRobert's Avatar
Oddometer: 9,730
Steel
Crusader of Slack
Old 01-31-2011, 11:47 AM   #7
JNRobert OP
Breaking Wind
JNRobert's Avatar
Oddometer: 9,730
I'll check it out.
Crusader of Slack
Old 01-31-2011, 11:53 AM   #8
RVDan
RVDan's Avatar
Oddometer: 2,585
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 01-31-2011, 03:01 PM   #9
JNRobert OP
Breaking Wind
JNRobert's Avatar
Oddometer: 9,730
RVDan, does Seal All work - have you used it?
Crusader of Slack
Old 01-31-2011, 03:09 PM   #10
Beezer
Oddometer: 5,648
I would solder it with an iron & regular (lead/tin) plumbing solder. I have done this a bunch & it works good. Marine Tex is OK, Proseal is what we use to seal aircraft fuel tanks. My experience with Sealall is .....ahhh, mixed results.
Beezer is offline   Reply With Quote
Old 01-31-2011, 05:20 PM   #11
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,186
Originally Posted by Beezer View Post
I would solder it with an iron & regular (lead/tin) plumbing solder. .
For a small hole this is your absolute best bet. If you clean it and flux it correctly you'll never any problems with it.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 01-31-2011, 05:42 PM   #12
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,084
I have patched such holes with sheet metal screws and rubber washers and never had a leak. Way less hassle than any other method.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 02-01-2011, 07:04 AM   #13
TheOtherBart
TheOtherBart's Avatar
Oddometer: 1,910
The little CM200 I picked up last summer had a couple of holes filled with sheet metal screws and rubber washers and they leaked like crazy.
I replaced them with pop rivets (to fill the bulk of the hole) with a little drizzle of that SealAll over them to, well, seal everything up. Worked like a charm, absolutely no leaks.
The SealAll has a thinner consistency than I expected. It's like warm honey. I'm not sure how it would work to patch a hole like that without something (like a rivet) in the hole first.
TheOtherBart is offline   Reply With Quote
Old 02-01-2011, 07:18 AM   #14
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,246
i have used seal all - it does work. it's the cheapest easiest fix - it's not permanent, but i've had it work for a few years at a time.
if the tank shows other signs of deterioration just seal the whole thing with caswell - put some duct tape over the holes so the sealer seals the holes. let it dry for a few days, remove duct tape and your tank is good as new.
current bikes
stainlesscycle is offline   Reply With Quote
Old 02-01-2011, 07:50 AM   #15
2speed
Puching adventurer
2speed's Avatar
Oddometer: 848
Solder or braze, it's the best way and you will never have to wonder when the fuel formulation changes whether it's going to eat away the epoxy or rubber.
Loud intakes save lives!
2speed is offline   Reply With Quote
Times are GMT -7.   It's 01:39 AM.
