Old 01-31-2011, 09:29 AM   #1
mrlarner OP
Oddometer: 43
KTM 17mm axle 26mm wheel
Hey guys,
I'm wanting to stick a newer 26mm front wheel on a 98 640a with a 17 mm axle. Does anyone make a 17 to 26mm spacer? Can I use a bigger bearing, maybe one that has an inner diameter of 20mm, so I can use a 17 to 20 mm spacer? Or is there a way to bump up my axle size without a new front end?
Weighing my options here. Thanks for any input!
mrlarner is offline   Reply With Quote
Old 01-31-2011, 09:37 AM   #2
kubiak
Oddometer: 4,829
Originally Posted by mrlarner View Post
Hey guys,
there are bearing spacers i used to run a 17mm axle to a 20mm bearing. i got them from motion industries in fresno, california. hope this helps!
kubiak is online now   Reply With Quote
Old 01-31-2011, 09:59 AM   #3
jonnyw
Oddometer: 585
20 to 26
THERE ARE COMPANIES(zipty racing?) MAKING THE 20 TO 26 CONVERSIONS ALREADY. Sorry had caps on. Maybe you can get a 20 mm axle and use these spacers. You should be able to find bearings to fit(00-03?) Might be cheaper/easier to find another wheel.
jonnyw is offline   Reply With Quote
Old 01-31-2011, 10:01 AM   #4
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,608
cjracer used to make a special axle to fit 20mm wheels.
with that and a 20 to 26mm adapter you could fit them.
I inquired about it, as I got an other 640 ('00) with 17mm axle but he hasn't made any lately due to lack of demand...
check with him see if he would do a run, I could be interested in one.
KTM 950 ADV '05.5
KTM 690 '10
christian is offline   Reply With Quote
Old 01-31-2011, 05:20 PM   #5
rz35027
rz35027's Avatar
Oddometer: 236
I would be interested in those adapters also.....
rz35027 is offline   Reply With Quote
Old 01-31-2011, 05:27 PM   #6
mrlarner OP
Oddometer: 43
I like the sound of this.
Also, I wonder what the problems would be using a bearing with an outer diameter that fits in the 26mm hub, but an inner to fit a 17 or 20 mm axle. Are bigger bearings bad?
But anyway, a 17 to 20mm axle might be the joint.
Old 02-01-2011, 09:41 AM   #7
christian
christian's Avatar
Oddometer: 2,608
I PMed Cjracer again, let's see if he chime in this thread.
KTM 950 ADV '05.5
KTM 690 '10
Old 02-11-2011, 01:19 PM   #8
katumo_jtb
bogus journeyer
Oddometer: 458
Add me to the list of people interested in a 17mm to 20mm axle conversion.
Edit: MrLarner, you can't simply swap bearings because the hubs changed. There is no 20mm ID bearing with the right OD to fit the early hubs (I checked). At least there isn't a standard sized bearing, you could have some custom made I guess. And even if you could find bearings to fit the axle, they wouldn't be the right width to fit the stock spacers, so you'd have to make new spacers.
katumo_jtb is offline   Reply With Quote
Old 02-14-2011, 12:04 PM   #9
mrlarner OP
Oddometer: 43
Figured as much, tho cutting a spacer is heaps easier than machining a new axle.
I think I'm going to put some effort into machining the step-up axle myself (unless cjracer comes through ) if I can get my hands on a 20mm hub. I'll let you guys know if it turns out.
Old 02-14-2011, 12:56 PM   #10
christian
christian's Avatar
Oddometer: 2,608
I am in contact with cjracer, and we are looking into it.
Making a spacer for 20mm wheels is not reasonable, spacer would be too thin - the axle is a possible solution but cost might be high.
So an idea is to make spacers for 26mm wheels to fit on 17mm axle.
I am guessing, people with bike with a 17mm axle don't have wheels yet, so we could be shopping for 20mm or 26mm. 26mm seems more common 03+ RFS/2stroke. Also cost would be drastically less for just spacers.
So a quick poll,... are people interested dead set on 20mm... or a 26mm spacers for 17mm be just as good.
I am fine with 26mm wheels - please let us know.
Questions:
1- Do you have extra wheels already? if yes, what axle size?
2- how much are you willing to pay for an 20mm axle?
3- How much are you willing to pay for 26mm spacers?
my answers:
1- Do you have wheels already? if yes, what axle size? NO WHEELS YET
2- how much are you willing to pay for an 20mm axle? $100
3- How much are you willing to pay for 26mm spacers? $50
Thank you
KTM 950 ADV '05.5
KTM 690 '10
Old 02-14-2011, 02:17 PM   #11
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,756
http://www.ktmcyclehutt.com/ktm-part...tment=bigbikes
wrk2surf is offline   Reply With Quote
Old 02-14-2011, 02:18 PM   #12
christian
christian's Avatar
Oddometer: 2,608
point being? we are trying to make it work for 17mm axle bike...
Originally Posted by wrk2surf View Post
KTM 950 ADV '05.5
KTM 690 '10
Old 02-14-2011, 08:56 PM   #13
rz35027
rz35027's Avatar
Oddometer: 236
2) $0
3) $50
Old 02-14-2011, 09:09 PM   #14
wrk2surf
wrk2surf's Avatar
Oddometer: 6,756
mis understood those are for adapting a 17mm to 26 drop outs.. good luck
Old 02-18-2011, 02:17 AM   #15
nanno
Oddometer: 273
Why don't you just check the outer bearing diameter or the DIN-No. on the bearing and just get a new set of wheelbearings. 17mm inner diameter is definitively a std. DIN-bearing (as is 20mm inner-diameter)
Cheers,
Greg
Let the world change you and you can change the world - Che Guevara
nanno is offline   Reply With Quote
Times are GMT -7.   It's 03:44 PM.
