Old 04-12-2011, 07:48 AM   #181
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,608
Wow. At least now we know what's possible. I wonder if he was able to save some weight with that swingarm too.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 04-12-2011, 08:33 AM   #182
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,964
Seems crazy, thats really light. But if the forks are half as light, thats 25 POUNDS. Half battery and starter would add to another 15. Swingarm seems like it got slightly heavier, as did the frame, with extra material.
I read somewhere else that the /5 frames were stronger than the later ones. Another case of internet research turning up completely contradictory evidence.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 10-03-2011, 06:55 AM   #183
Beater OP
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,522
So for the first time I felt good / confidnet enough in the Dobber to take her a few miles from home to some power line trails. Immediately I remembered my youth riding a neighbors YZ80 through the woods. The perma-grin is still on my face. And I am soooooo sore it's not even funny. This 40 year old is whipped ... but ready to do it again.
There is a list of little maintenance things I have to do ... but one of my learnings for the time was that I was littlerally standing on the tail pipe. the ball of my foot was on the peg and my heal was resting comfortably on the pipe. So ... it looks like I need another set of pegs back there. The 22mm bar that's on it (a Slash 2 bar ) is a bit loose in the clamp. I like it though ... anyone know how to tighten that up? The left side Mikuni is not functioning correctly ... I need to rebuild it. Know where I can get a VM32 rebuild kit?
I also will put on the new oil pan ... I hit the current one going over a log .... Anyway the solution is a sump extension and a steal plate for the bottom ... I already have all the parts ... so that's next too.
The Cow in her natural environment (as you can see, she's been grazing):
A little bit of a closer view:
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater screwed with this post 10-03-2011 at 08:58 AM
Beater is offline   Reply With Quote
Old 10-03-2011, 06:58 AM   #184
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,419
Fun thread, awesome bike.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 10-03-2011, 07:09 AM   #185
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,608
Let's make the footpegs longer. It'll get you a wider stance and pull your feet away from the pipes. Have you come up with any good ideas on how to alter that brake pedal when the pegs get moved? It's aluminum isn't it?
Old 10-03-2011, 07:29 AM   #186
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,572
Yep, it's aluminum. Did you not go with Fred to brake the Dobber in? I think he's was going to just attach something with fasteners to the pedal.
Fred, where did you end up riding?
Old 10-03-2011, 07:38 AM   #187
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,608
I had to work. My neighbor needed a lot done to her house and she's a professor at the school of business at Georgia State. Yes, I'm blatantly kissing butt to get a Letter of Recommendation.
Old 10-03-2011, 09:01 AM   #188
Beater OP
Beater's Avatar
Oddometer: 3,522
Me and a friend (the guy I sold the '76 R60/6 to) went just southwest of where you live ... Found a series of interconnecting trails (mostly singletrack) going off of a rail line and some powerlines.
You know ... I was shocked at that stock R60. He put some dual sport tires on it and the damn thing could hang. It went just about everywhere I did. It really proved itself on the narrower stuff .... hopped logs ... amazing.
Old 10-30-2011, 03:55 PM   #189
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,608
Butt.
I mean, bump
Old 11-20-2011, 01:05 PM   #190
Beater OP
Beater's Avatar
Oddometer: 3,522
Al right. Been a while .. but I think I've fixed my 'bashplate' problem.
This was originally an RT so ... it never came with a G/S or GS style bash plate. So ... I began thinking. I was reading Anton's site when I read this ...
"HPN makes this two-part oil pan which uses a flat bottom plate (left) and this forms the engine's 'bash plate' with nothing else required. It's very strong and is used on every rally bike engine."
So ... I thought ... why don't I make my own?
I found a guy on ibmwr.org selling a sump extension. He emailed me a pic and the piece was BEEFY. It was at least a 1 cm thick all the way around, and 3 cm tall. By my rough calculation, it looked like it would hold about as much oil as the short (70-80) oil pan.
So I bought it.
Then I was talking to some of the metal workers at work about the project. One, a Harley rider, who thinks I'm crazy anyway, laughed and told me he'd make a bottom plate for free but I had to ride the bike to work once it was done. No problem. So I gave him an old oil pan and he asked if 1/4 inch STAINLESS steel was OK to use. No problem ...
It is a bit heavy though ...
That's about 5.6 pounds for those of you playing the home game.
I had to fashion a drain plug for it. So I went to Homer's and found a brass 1/2 drain plug fitting. I also got a 3/8 diameter proximity switch magnet. This thing is STRONG. I drilled out the inside of the brass fitting to recess the magnet.
I then scored big the inside of the drilled out plug so that the JB Weld would attach to something. I put about 1/2 mL of JB Weld into the bottom of the plug, then pressed the magnet in with a vice. The excess JB Weld 'squirted' out and then I allowed it to set.
After an hour or so, I began assembling the monstrosity.
And then I put it on.
To the 'full mark' on the dip stick, it holds right at 2 liters (changed oil and filter).
When I showed the finished product to the guy who made the plate, he got all excited and said he'd do another one, and this time he would recess the heads of the allen bolts. Good idea ... I've already hit a log with it, and nothing happened ... and I do mean nothing. The bike landed hard (intentionally, ) right on the oil pan, and when I got home, I hosed it with water ... I was really half expecting to sheer one of the heads off.
Anyway ... The Dobber is living up to its dirt intentions.
Old 11-20-2011, 01:08 PM   #191
Beater OP
Beater's Avatar
Oddometer: 3,522
Butt.
I mean, bump
Don't Weld With Brad
Old 11-20-2011, 01:31 PM   #192
ADK
____
Oddometer: 8,243
Eh?
Wouldn't countersunk screws be a better idea than exposed nuts?
ADK is offline   Reply With Quote
Old 11-20-2011, 01:34 PM   #193
Beater OP
Beater's Avatar
Oddometer: 3,522
Yep. That will be for version 2.0. But ... I did hit a large log and the exposed bolt heads did not sheer ... but it is a worry. The guy that made the plate said he'd recess the bolt heads next time.
Old 11-20-2011, 03:33 PM   #194
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,698
Why not some 3/8 aluminum plate instead of the SS and save some weight?
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 11-20-2011, 05:01 PM   #195
Beater OP
Beater's Avatar
Oddometer: 3,522
I'm with you ... I asked about that ... but it was simply a matter of audience. Those guys I was talking to were stainless steel welders. For v2.0 I will try to get them to do the Aluminum ... but I think 3/8 in aluminum would be perfect ... I also think that 1/8 in Stainless steel would be fine ... and that might be where I go from here ... and then get them to weld on 4 fins ..
Times are GMT -7.   It's 08:57 AM.
