Old 03-22-2012, 01:52 PM   #196
blaine.hale
blaine.hale's Avatar
Oddometer: 3,220
Update! Update! Update!
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 03-26-2012, 11:12 AM   #197
Beater OP
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,539
I'd like to thank a new friend in Canada for his wonderful donation ... Alastair .. You rock.
And for the mock up ...
I WAS going to use the shock mount on the final drive ... but there really isn't a good shock out there with a 21" length (eye to eye). So ... It looks like I will need to weld on a mount on to the new lengthened swingarm. For eveyone out there .. the swingarm appears to have been lengthened by 4". This makes it VERY close to the length of a GS ..
I swapped a snazzy /2 handle bar for the GS bar Blaine had ... now I'm also into lengthening the bar controls so they will fit the new GS bars ... Adding about 5 inches of wire to each side. The clutch cable and carb cables were already to long ... let's hope they are way to long
I also have found a set of dual plugged heads from an '81 RS ... complete with Dyna coils and ignition booster. They will be used with the cylinders and pistons from that very beast. The Dobber will be a dual plugged 1000cc BEAST.
The Engine from that 81 RS had locked up due to the $2,000 oil ring problem ... one of the connecting rod barings ceased the rod to the crank shaft. As weird as this is ... when we took it apart the crank shaft really didn't have a mark on it ... so I gave it to Brad, and he's currently using it as his engine. Everyone wins!
I'm still looking for that Spoke hub from a GS or a later R bike ... anyone have a lead on one, let me know! I also think I'm going to need a different triple ... but let's get this one riding first
Thanks, Fred
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is online now   Reply With Quote
Old 03-26-2012, 01:16 PM   #198
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,609
Lemme know when you want to weld on the shock mount. I've got some steel that ought to work out too.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-26-2012, 02:54 PM   #199
Beater OP
Beater's Avatar
Oddometer: 3,539
This coming weekend. I have Jenna's welder ...
Old 03-27-2012, 10:42 AM   #200
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,584
You haven't used it yet?? Do you have a 8x1.5 bottom tap? Hey brad can you help me with sag when I get home?
Old 03-27-2012, 01:25 PM   #201
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,609
I can't do it today. Maybe this weekend?
Old 03-27-2012, 02:47 PM   #202
Beater OP
Beater's Avatar
Oddometer: 3,539
I have Friday morning off ... Anyone wanna make some sparks?
Old 03-27-2012, 03:21 PM   #203
hardwaregrrl
ignore list
Oddometer: 7,584
I'm in Detroit right now. I might be home Friday??
Old 05-04-2012, 11:56 AM   #204
Beater OP
Beater's Avatar
Oddometer: 3,539
THIS WEEKEND. I gotta get this done. Staring at the Dobber up on a lift like this is making me drool.
Old 05-04-2012, 12:44 PM   #205
hardwaregrrl
ignore list
Oddometer: 7,584
Why oh why do you always want to play when I have to work.... Guess you won't be going to the spring fling next weekend....??
Old 05-26-2012, 07:36 AM   #206
tdrrally
tdrrally's Avatar
Oddometer: 3,421
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is online now   Reply With Quote
Old 05-26-2012, 09:21 AM   #207
sithndman
sithndman's Avatar
Oddometer: 126
The waiting....
1978 R80/7
sithndman is offline   Reply With Quote
Old 05-27-2012, 05:14 PM   #208
tdrrally
tdrrally's Avatar
Oddometer: 3,421
Do i have the only dual shock rt?
Old 05-28-2012, 09:37 AM   #209
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
Yep. That will be for version 2.0. But ... I did hit a large log and the exposed bolt heads did not sheer ... but it is a worry. The guy that made the plate said he'd recess the bolt heads next time.
Another option are button heads, with their rounded profile it doesn't really matter that they stick out some.
Great build, BTW
Kai Ju is offline   Reply With Quote
Old 05-29-2012, 06:53 AM   #210
tdrrally
tdrrally's Avatar
Oddometer: 3,421
from this
to this
Times are GMT -7.   It's 09:15 AM.
