Old 05-29-2012, 10:28 AM   #211
Beater OP
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,583
Originally Posted by Kai Ju View Post
Another option are button heads, with their rounded profile it doesn't really matter that they stick out some.
Great build, BTW
I thought about that ... Good point KJ.
We're getting very close to another giant step. I spent the weekend camping with my girls ... and drawing suspension diagrams in the dirt ... and after a little math ... We've identified the right shock and where to put it (using the existing frame shock mount).
At this point you should have protective eyewear ready.
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 05-29-2012, 10:31 AM   #212
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
All the world's greatest design work was done with a stick drawing in dirt. I commend you.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-29-2012, 12:39 PM   #213
Beater OP
Beater's Avatar
Oddometer: 3,583
It felt right. It is an Airhead after all. Using a CAD program seemed contradictory to the design philosophy.
Old 05-29-2012, 12:59 PM   #214
igormortis
igormortis's Avatar
Oddometer: 1,402
OK, Im ready.
igormortis is offline   Reply With Quote
Old 05-29-2012, 01:01 PM   #215
tdrrally
tdrrally's Avatar
Oddometer: 3,456
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 05-30-2012, 04:45 AM   #216
sithndman
sithndman's Avatar
Oddometer: 126
Do we need to alert the DFD?
1978 R80/7
sithndman is offline   Reply With Quote
Old 05-30-2012, 04:54 AM   #217
Beater OP
Beater's Avatar
Oddometer: 3,583
Not yet. But do keep them on speed dial.
Old 05-30-2012, 06:10 AM   #218
tdrrally
tdrrally's Avatar
Oddometer: 3,456
the transformation has started
Old 06-13-2012, 05:50 AM   #219
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
big box from nashville has arrived. waiting for an update...
bmwblake is offline   Reply With Quote
Old 06-16-2012, 06:43 AM   #220
Beater OP
Beater's Avatar
Oddometer: 3,583
Yes sir. I have a pretty new subframe from a GS organ donor. Know that she gave her parts so that others may live.
Old 06-16-2012, 08:21 AM   #221
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,611
By the way....some COMMIES were playing "tag" near your place of business. Careful.....
Old 06-17-2012, 03:51 PM   #222
Beater OP
Beater's Avatar
Oddometer: 3,583
HA! Strange ... that park is 200 yards from my house.
Anyway, so I was installing the lengthened swingarm. It was being very finicky about the placement ... finally when I got it 'optimized' by moving the swing arm back and forth in the frame trying to find which place gave me the most clearance and swing ...
I wound up with 6" of swing and at both ends something impeded the swing at both ends. The swingarm was lengthened by 4" ... There should have been much more swing. This seemed wrong ... so I attached the shaft to the transmission and spun the shaft so that whatever was rubbing inside would hopefully make a mark.
So ... I need to make a tool. And I need to use the welder (don't ask why).
So I spend several hours in the hardware store, and I know that the transmission flange has a 1.5 inch lip to it, and the final drive end is 2 inches diameter ... and I need to reach inside it. Then I find the washer isle ... I know that I can lay them on top of each other ... weld it ... Then I can drill some holes ... and weld two nuts on ... I can make this:
And what do you know ... it worked.
The snap ring that was used to put this together is the wrong one ... it was very close to failure. We'll replace it with the right one.
So .. I get it apart.
And I look inside ... and there's the rub.
SO ...
Old 06-17-2012, 03:57 PM   #223
hardwaregrrl
ignore list
Oddometer: 7,611
Did you buy a welder???
Old 06-17-2012, 04:10 PM   #224
Beater OP
Beater's Avatar
Oddometer: 3,583
Brad's
Old 06-17-2012, 05:19 PM   #225
hardwaregrrl
ignore list
Oddometer: 7,611
Pretty neat set up you made....glad you've got it figured out.
Times are GMT -7.   It's 01:29 AM.
