Old 02-13-2011, 10:48 AM   #76
Quasi1960
Quasi1960's Avatar
Oddometer: 409
Originally Posted by baldwithglasses
Could you heat the exterior race with your MAPP torch. You may have some success if you can drop some dry ice down the steerer tube. I'd think you want to take advantage of heat expansion/contraction.
Whaddya think?
Originally Posted by Beater View Post
I went there ... didn't do the cooling bit tho. I'll give it a try ... the science seems sound ...
This reminds me of a friend who worked for Rolls Royce Aero Engines at Filton in the UK. He was giving a colleague a lift to work because the guy couldnt get spindle out of the front wheel of his bike. They had tried heating and cooling as best they could but it was stuck fast. After a couple of days the guy with the problem comes out of work holding his rucksack very carefully and said to drive home very carefully and avoid any potholes in the road. When they arrived at his house he asked my friend into his garage where the offending wheel was supported between two saw horses. Reaching into his rucksack he takes out his thermos and proceeds to pour the contents down the hollow spindle. Within seconds it fell to the floor. Liquid Nitrogen is wonderful stuff.
R100 of indeterminate history and model.
Quasi1960 is offline   Reply With Quote
Old 02-13-2011, 11:31 AM   #77
Martian
Oddometer: 1,104
In the base of my lower triple, there were two small holes opposite one another. After heating the race, an appropriate size drift was used to tap the race off. It only has to go about an inch. YMMV.
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 02-13-2011, 08:12 PM   #78
Beater OP
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,532
While I REALLY wanted to try the liquid nitrogen route, I just couldn't make it happen.
So ... I simply removed most of the 'safety' guards, shields, and such from my bench grinder ... and went to town on it. I was able to expose the complete race to the wheel ... after about 5 minutes of grinding ... I heard a *loud* pop ... and I thought I had broke the cast aluminum triple ... but it turns out that the race was thin enough to fracture under the heat. Then it simply fell off the stem and onto the floor.
See the fracture? Cool, eh?
Next: The installation of a massive set of forks.
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 02-13-2011, 11:02 PM   #79
Quasi1960
Quasi1960's Avatar
Oddometer: 409
Who said violence never solved anything?
Old 02-14-2011, 07:22 AM   #80
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,584
nice job, Fred...
I can't remember how I got mine out. You putting the triple in the freezer? It helps.
Old 02-14-2011, 03:06 PM   #81
The Raven
The Raven's Avatar
Oddometer: 4,811
I actually had to do this today.....After fighting with drifts, cold chisels, slide hammers I eventually used a cutoff disk in the dremmel and went down enough to then use the small cold chisel and fractured the race. I somehow ended up breaking a side reflector though.....
Lacking a welder in the shed and refusing to by a bucket of hardware for $40 from airhead tool suppliers I just left the outside races in place. The new bearings work well in them with no notchiness so in they stay.
The Raven is offline   Reply With Quote
Old 02-14-2011, 03:55 PM   #82
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,215
If you're talking about the outer races in the steering neck of the frame, you can get them out easily with a pair of holes drilled 180 degrees apart and a suitably sized drift or prick punch.
Seal the drilled holes from the outside with a dab of silicone if you're concerned about the new bearings becoming contaminated.
It's not generally considered good practice to mix old and new bearing surfaces. Tolerances and machined surfaces on modern production bearings are quite remarkable. One of the wonders of modern mfg'g.
Old 02-14-2011, 07:43 PM   #83
Beater OP
Beater's Avatar
Oddometer: 3,532
The triple went in the freezer the moment the race fell off. Today went to Chattanooga with the fam ... Rock City, and Ruby Falls ... then dinner near the aquarium. Loads of fun ... little girls screaming ... huge fun.
But on return to the house ... the post man brought me a present. Check out the Renthal bars.
Next: Installation!
Old 02-14-2011, 08:09 PM   #84
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,609
That's some serious offroad machinery. You'll need harcore riding gear that suits this beast. How about we draw Fox logos on a t-shirt with some markers?
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 02-19-2011, 05:39 PM   #85
Beater OP
Beater's Avatar
Oddometer: 3,532
Slowly but surely ... progress is being made. Promise. The triple is on. New bearings. A few extra washers.
Old 02-19-2011, 05:42 PM   #86
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,986
That lower is on right? seems like negative offset from the photo, heh
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 02-19-2011, 05:42 PM   #87
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,644
Am I just a Wacky Bongo Boy, or is the lower on backwards?
crazydrummerdude is offline   Reply With Quote
Old 02-19-2011, 05:44 PM   #88
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,986
BOOM you owe me a beer.
Old 02-19-2011, 05:44 PM   #89
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,644
Edit: Yeah, I guess it's on correctly. The stops wouldn't work the other way. Freaky..
Old 02-19-2011, 05:49 PM   #90
Beater OP
Beater's Avatar
Oddometer: 3,532
That's a riot. Luckily the lower triple came pre-assembled ... so the steer tube only went in one direction. Because I would have MADE that mistake.
Times are GMT -7.   It's 10:14 PM.
