Old 03-17-2013, 02:11 PM   #6736
bikewise
Oddometer: 3
scenic spin today
To all you waiting on your new lc, they are awsome. Got mine friday, thunder grey with wire wheels. Engine is far more responsive and faster revving than previous engine making it feel far stronger than the figures suggest. No hint of instability except the bike will wheelie of the throttle alone in the first 3 gears. The screen is superb and I am 6 foot. The seat seems good too, my only gripe is the notchy gearbox, but i'm hopeful it will free out. This bike really ticks all boxes, I have done a few light off road trails and it gives great confidence. So touring, commuting, scratching, offroad. This bike has it all covered. In a word wow
bikewise is offline   Reply With Quote
Old 03-17-2013, 02:19 PM   #6737
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by mrjon View Post
OK, up to just over 500 miles on the LC now, it's in for the run in service and hopefully Akra can shortly, if it's arrived in stock.
I've just been out for my first night run with the new LED lights, not far, only a few miles.Yes, the LED give a brighter crisper light than the previous models where the light falls, but personally I'd like the low beam to throw a little further. I found down a dark narrow country lane ,which I knew quite well the low beam was good for about 35-40 mph. The high beam lights up the road well and allows for posted speed limit cruising no problem.
My only complaint is the same one I have with the K16's night ability, it's all very well having these new fancy lights, but like on the K16 the handle bar controls aren't illuminated so you don't know what buttons are where.
A word of warning, don't try and change engine modes in the dark as unless you are 100% sure you know you have the right button or there's a good chance you can hit the engine kill switch rather than the engine mode switch.
This has happened to a few K16 owners, myself included.
Come on BMW, illuminate your switch gear !
Here is the low/dipped beam
Thanks for posting, but man the throw on that low beam is disappointing...I think worse than my camhead halogen. I sure hope that it is the picture quality or that the level can be adjusted.
EJ_92606 is offline   Reply With Quote
Old 03-17-2013, 02:32 PM   #6738
mrjon
Oddometer: 120
It's better than the previous model, in that the throw is probably the same distance but the light is a lot crisper and more natural, the full beam is more than adequate.
Future..on order-BMW GSA LC,
Present..BMW R1200GS LC, K1200R-SPORT, R1200S,HP4
Past.. BMW R1150GSA,R1200GSA,R1200GS,R1200RT,K1600GT
mrjon is offline   Reply With Quote
Old 03-17-2013, 02:32 PM   #6739
MaxReving
MaxReving's Avatar
Oddometer: 257
Adjusting LED headlight: User manual page 74
Max :-)
MaxReving is offline   Reply With Quote
Old 03-17-2013, 02:35 PM   #6740
paulW
Oddometer: 143
I always tweak both of mine a little higher - more noticeable in daylight, more effective when riding at night. They always seem to be set too low from new, just like speedometers always have to read high??
paulW is offline   Reply With Quote
Old 03-17-2013, 03:00 PM   #6741
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Thanks a lot for your feedback on the LED's and the pictures!
As far as the pictures go, I'd say its something that can only be captured with your own eyes because they totally depend on camera settings. BMW/LED module supplier have the proper charts comparing LED vs. H7, I'd be curious to see them.
tallguy-09 screwed with this post 03-17-2013 at 04:29 PM
tallguy-09 is offline   Reply With Quote
Old 03-17-2013, 03:22 PM   #6742
Cycling101
Oddometer: 65
Max :-)
Page 70 in the US Rider's manual.
Cycling101 is offline   Reply With Quote
Old 03-17-2013, 04:08 PM   #6743
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,171
...lights...
Well your beams definitely need adjustment (your dealer SHOULD have done it).
They point too low.
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 03-17-2013, 04:27 PM   #6744
mrjon
Oddometer: 120
To be honest this was the first time I've been out at night and seen the throw, I'll have a look at adjusting them tomorrow, but you are right tallguy the camera didn't capture a lot of what was illuminated.
Re the over reading spedo I noticed both the analogue and digital readouts were the standard 10% over compared to the GPS speed.
Old 03-17-2013, 04:28 PM   #6745
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
They point too low.
For sure, it's pointing too low.
Should look like this, everything on. Low-Beam, High-Beam, Accessory LED's (good large sensor camera)
HID low-beam, 2x3600lumens accessory LED's on dimmer/High-Beam override. One must love Canada for the lack of TUV.
In Germany "Race-control" would impound this on the spot (no type approval)...
Old 03-17-2013, 04:55 PM   #6746
MaxReving
MaxReving's Avatar
Oddometer: 257
Question regarding switching riding mode while riding. Riding modes can be switched while riding as long as you pull the clutch and twist the throttle back to idle position. If you have installed the coding plug then the fifth riding mode "Enduro Pro" is also available. Installing the coding plug will engage the memory function.
Is it true that you can also switch into "Enduro Pro" mode while riding and thereby disable the ABS function on the rear wheel while riding ?
Anybody got the coding plug installed and tested this feature ?
Max :-)
Old 03-17-2013, 04:57 PM   #6747
Montauk
Oddometer: 280
Seat height: (ground to lowest point of seat)
Low seat: 820/840 mm
Standard seat: 850/870 mm
High seat: 870/890 mm
Rallye seat: 880 mm
Arch length: (ground-across-seat-to-ground)
Low seat: 1820/1870 mm
Standard seat: 1890/1940 mm
High seat: 1940/1990 mm
Rallye seat: 1920 mm
The Rallye seat is much more narrow than the standard seat and therefore the arch length is less than the standard seat in high position.
Max :-)
Max can you explain me when BMW lists two sizes per seat, are they referring to the rider and passenger or they are referring only to the rider's but measurement at the front and the back of the rider's seat? Thanks.
Montauk is offline   Reply With Quote
Old 03-17-2013, 05:01 PM   #6748
NLS
NLS's Avatar
Oddometer: 3,171
All seats are adjustable to two heights (except rally seat).
This was also the case with 04-12 GS.
(but not in angle like 13 GS... although "unofficially" I still did it on my 07)
NLS
My Blog
Old 03-17-2013, 05:05 PM   #6749
NLS
NLS's Avatar
Oddometer: 3,171
Max :-)
Waiting for an owner to reply, I'd say it probably CAN be selected.
You point at a potential "dangerous" situation, yet owners of Enduro Pro SHOULD be knowledgable enough and experienced enough and careful enough, to not go into such a situation and handle it properly even if they do.
It's not something you do by mistake.
NLS
My Blog
Old 03-17-2013, 05:06 PM   #6750
Montauk
Oddometer: 280
And here is the hi/full beam, to be fair I could actually see quite a bit further than is shown on the photo, which has only picked up the throw of the light onto the road, hedges ,trees etc could clearly be seen a lot further down the road than shown in the photo.
Why is there a color difference between the two lights? Is it camera thing or there is infact a color temperature difference. When standing far and looking at the LC lights, how do they look, does the low beam shows split zone due to middle plastic.
As EJ mentioned, I too am disappointed, and hoping that it is due to camera, otherwise it would be hard to console myself.
Montauk screwed with this post 03-17-2013 at 05:20 PM
Times are GMT -7.   It's 06:00 PM.
