Old 03-20-2013, 12:53 AM   #6901
oz97tj
oz97tj's Avatar
Oddometer: 819
As far as I know, at least here in the states, everyone who "ordered" a bike long ago did nothing more than make that agreement with their dealer. As of last week, ordering still wasn't available through BMW. This just means those people who "ordered" were put on the waiting list early and then their dealer would be sure the bike they wanted would come in as soon as possible. With that said, according to my dealer all the first bikes are pretty random. I was even told today if I actually ordered, I'd be about 2.5 months out. However, they also stated many of the next bikes coming in will be fully optioned so a order wasn't exactly needed. I put down my $500 to get in line for a bike that fits my requirements, but this isn't ordering. That's still likely 6 weeks out.
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 03-20-2013, 01:16 AM   #6902
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,167
Originally Posted by RedLeg View Post
Guess I'm just not seeing the big woopty doo on the led lights. I mean Starbucks isn't open at midnight so who needs the damn LED lights? Cool factor yes, wait another two months for one..nope.
Actually they are better according to tests on other vehicles.
Mine has everything but the LED's and Tire Pressure monitors, so I think I'll take it as is.
That is the reason you don't like them.
(the same reason you would not like 12GS '13 at all if you didn't buy one)
Have fun with the new bike. :)
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 03-20-2013, 01:36 AM   #6903
Moronic
Moronic's Avatar
Oddometer: 1,688
Curious post on the fork-top fix
Came across this curious post while perusing an Italian language Multistrada forum. There was a thread from someone who had test-ridden the new GS, which drew this contribution from another poster on what had been holding up GS deliveries. I will quote the relevant bit, in google translation:
'... only the magazine IN MOTO had the courage to make things clear. "Choosing to use a fork 37 mm (instead of 41) is the source of all evil ... engineers and testers have had to deal with problems of stability of the vehicle, caused by excessive flexibility of the fork ... to solve the problems of handling it was necessary to to make changes "on the run". Specifically, the "evil" of GS is hiding in the area of the top plate of the steering, which the model 2013 is fixed to the fork tube with two aluminum end caps that screw on the rods themselves ... because of the vibrations, you unscrew the fork caps and in the worst case the top plate can be disconnected from the steering fork. In these cases, the pilot no longer has control of the bike ... in Monaco have redesigned the new fork legs, which are mounted and punched in place of those currently present on models already products ... therefore, in contrast to what have wrongly said and written in many, the change is not a "detail", rather it is a complex operation which involves the removal of the Telelever and a delicate punching ... " '
The material between the double quotes is claimed to be from the magazine article. Bear in mind that this is in translation, and also that the poster appears, from other comments in the post, to be somewhat sceptical with respect to BMW.
Bear in mind also that the report merely elaborates on what has already been reported and cited in this thread, for example at Motorrad online here.
Apologies if these details came out earlier - I have not read all recent pages. And of course, the In Moto report (the mag title too is translated - did they mean the Spanish title En Moto?) might not be accurate. If not, doubtless someone here will correct it.
I can't quite swallow that a 4mm reduction in diameter of the Telelever fork must cause difficulties, as surely they could simply increase wall thickness to maintain stiffness. But perhaps they wanted to avoid the weight penalty. IIRC from the launch material, they cut the diameter so that the fork could clear the radiators.
It is also far from clear that the "stability" issue during testing alluded to in the report is connected with the "tankslapper" phenomena reported by some journalists at the launch event. I'd expect a tankslapper to arise from too much rigidity, not too little. In contrast, excess flex could easily generate high-speed weaves.
Sorting out the S4Rs Ohlins shock: click here.
Moronic is offline   Reply With Quote
Old 03-20-2013, 02:03 AM   #6904
NLS
NLS's Avatar
Oddometer: 3,167
Thanks for the info.
Personally (which means nothing to the forum hehehe) I also feel that the fork diameter reduction was a fault (esp. since the bike actually gained weight and CoG was moved a bit in front).
Of course my "feeling" means null (and should mean null) to expert mechanics in BMW. Yet, there are (strong?) indications that this part needed more thought.
One of the things that makes me happy I won't be in the first wave at all (we all make excuses ).
So candidates for first facelift:
- Thicker tubes (again).
- Color LCD HUD.
- More work for the GPS wheel (stop being just GPS wheel).
- +5 HP (because they actually tune it in carrot-donkey fashion, it is all a mapping thing now).
- ...add your own.
NLS
My Blog
Old 03-20-2013, 02:11 AM   #6905
madefrtv
madefrtv's Avatar
Oddometer: 436
I don't know where you are getting info from, but I was one of those $500 folks and my bike is definitely in production and making its slow progress this way.
Some dealers may do things differently, YMMV
whoa, dude...
madefrtv is offline   Reply With Quote
Old 03-20-2013, 02:29 AM   #6906
oz97tj
oz97tj's Avatar
Oddometer: 819
3 dealers have told me the same thing regarding ordering not being open to the US till this week.
Regarding "your bike" being in production, where are located? I wonder if "your bike" is nothing more than the same type of deal I did today. I put $500 down on deposit to stand in line for a bike that will be showing up at the dealer all on it's own. Its just coming from dealer stock.
'13 BMW 1200 GSW
'05 Honda ST1300
Old 03-20-2013, 02:35 AM   #6907
rednose
ReDnOsE
Oddometer: 63
Originally Posted by Moronic View Post
Came across this curious post while perusing an Italian language Multistrada forum...
Hi there. Meaning of "IN MOTO" can be translated as "something that moves" or "lets go ride a bike" or "on bike" ... I follow BMW Italians forum too. People there say "between the lines" that the fork reduction is the cause of the tankslapping and someone even pushed the idea that fork reduction -> tankslapping -> Kevin Ash accident ... Also the fork punching fact is not paying in favour of BMW's fork diameter reduction solution ...
What I personally don't like is this "shadow" - due to mentioned facts - of a motorbike with structural issues. I also suffer in my "old" 2004 model of the (in)famous flange cracks ... It is like BMW, on pursuing weight reduction (!!! >> 220kg :-( ) fails on keep on reliability ...
Just my .2 cent
r
rednose is offline   Reply With Quote
Old 03-20-2013, 02:50 AM   #6908
268
268's Avatar
Oddometer: 168
Originally Posted by EJ_92606 View Post
I'd like to see that dealer's stock room . I'm sure that number is what BMW Germany has at the distribution center for the whole country. A little bit crazy that Germany would have that level of stock given the bike isn't even available for sale there yet, but places where it is have no stock
Was thinking the same thing as you, and asked him if he really has al these cases in their own stockroom, and he answered : yes of course, well be selling all of them easily in 2013
Keep in mind that this dealer is on of the largest in Germany, so it could be true.
268 is offline   Reply With Quote
Old 03-20-2013, 02:56 AM   #6909
paulW
Oddometer: 143
Akrapovic delivery dates
Originally Posted by RichBMW View Post
Exactly. Can you ask them when the dark screens will arrive as well?
My dealer says mid April for delivery to BMW Germany, then a week to get to the UK
He could not give me any info re availability of tinted screens, sorry.
paulW is offline   Reply With Quote
Old 03-20-2013, 02:57 AM   #6910
NLS
NLS's Avatar
Oddometer: 3,167
When a bike is estimated to sell about 200k in 8 years (which easily translates to 20k first year), I don't think a central dealer in a big country (that is also the manufacturing country of the bike) will have a problem selling 250 cases. :)
NLS
My Blog
Old 03-20-2013, 02:58 AM   #6911
NLS
NLS's Avatar
Oddometer: 3,167
Is there a photo of a new GS with the tinted screen?
NLS
My Blog
Old 03-20-2013, 03:04 AM   #6912
paulW
Oddometer: 143
Not seen one except for the accessories catalogue. Not buying one myself, maybe RichBMW has seen a pic?
Old 03-20-2013, 03:08 AM   #6913
Deans BMW
Granpa Hoon
Oddometer: 3,440
Did you know getting your hands on a set of Vario Cases is almost impossible. Had SF BMW order mine today, said there were none in the US to be had. And they aren't sure when they will be able to get more. ODD!!
San Jose BMW has many sets of the Vario Cases and the Back Boxs on the shelf at the ready. John has fully stocked accessories for the new Water Boxer.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 03-20-2013, 03:33 AM   #6914
IB1
IB1's Avatar
Oddometer: 1,026
Mine were ordered with the bike. Still waiting for both (cases and bike).
IB1 is offline   Reply With Quote
Old 03-20-2013, 03:35 AM   #6915
IB1
IB1's Avatar
Oddometer: 1,026
Germany is also the bigest market for BMW motorcycles. wonder why
Times are GMT -7.   It's 02:39 PM.
