Old 03-31-2013, 05:32 PM   #7786
oz97tj
oz97tj's Avatar
Oddometer: 819
Originally Posted by oldspice1972 View Post
I'm surprised Touratech or Wunderlich haven't come up with a guard for this area yet - kinda like the oil cooler guards for the pre-WC boxers. Looks like it would scoop a lot of road crap up in there. Is there anything important behind that area that could get damaged?
No not really.
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 03-31-2013, 05:54 PM   #7787
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,084
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 03-31-2013, 05:57 PM   #7788
Japanviking
Oddometer: 94
Thinking about adding some lights to the bike. I really like how the OEM aux light controls and bracket integrates with the bike, would like to use the BMW harness, switch and bracket with other lights.
Anyone know the specs on the OEM Aux LED lights?
I also wonder how the BMW lights are powered, through the Canbus with possible issues of adding lights with a different power draw?
If the Canbus doesn't use any feedback signals from the lights I guess the best way is to just add a relay with a power cable from the battery and trig it from the BMW harness.
BMW S1000RR -12
BMW R1200GS -13
Japanviking is offline   Reply With Quote
Old 03-31-2013, 07:03 PM   #7789
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 826
Thumb tall riders: windscreen options?
Hi all,
At 6'4" w/34" inseam, the OEM screen provides clean air but it's really loud. Has anyone tried something that works to reduce noise for tall riders? If you post about this please note your height and inseam. Thanks.
(I may try taking the screen off entirely as it seems that one either needs a barn door or nothing at all to keep the noise to a minimum.)
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 03-31-2013, 07:05 PM   #7790
kindofblue
kindofblue's Avatar
Oddometer: 826
I did this and it made the clutch and brake function like my previous GSs. I'll tell my BMW dealer about this in their setup.
Originally Posted by kindofblue View Post
Thanks for the tip! Mine's the same and I hadn't thought of that yet. And nice pic. I see you have the fastest color, red
Originally Posted by Serp
I noticed the clutch and brake have rotary lever adjustment settings from 1 to 4. The clutch was set at 4 and I found it wouldn't engage until it was near the end of releasing (the lever). I set it to 1 and now it's perfect for me - the clutch engages as I start to release the lever.
Doc Reid
Old 03-31-2013, 07:07 PM   #7791
kindofblue
kindofblue's Avatar
Oddometer: 826
Thumb
I got the Wolfman attached today like the Touratech bag instructions.
Thanks, I'll take a look at that. After posting about this I checked out the Touratech bags for the LC GS and saw how they wrap their straps around the support for the front of the seat. That might work too but I haven't had a chance to check it out.
With all the other farkling there is to do, I'd be happy to stick with my Wolfman bag...
Originally Posted by maximo de la maximus
I just modified my 'held' tank bag which also has 2 straps. Pick one of two pairs of screws available (the 2 directly toward 6 oclock and the two more lateral but still under the seat) and cut the straps to length. Melt a very small hole in the nylon, add a small washer, and screw 'em down permanent like. Mine are pretty thick rubber so didn't have to use a washer; just screwed them thru the existing buckle hole. When I take the tank bag off I can just tuck the straps and velcro between the seat and tank- easy peasy, low profile, uber secure, and very clean This is of course if you don't want to replace your wolfman (or get another with 2 straps). IF you need a reason to upgrade, well, I completely understand and I'm sure there's something designed to fit in that little catch area between teh 6oclock screws I referenced.
Doc Reid
Old 03-31-2013, 07:36 PM   #7792
Dr. Greg
Tryin' to get home..
Dr. Greg's Avatar
Oddometer: 1,193
Omigosh that is a beautiful picture...way more mechanical presence than my MTS1200S. Just MHO y'unnerstand...
--Doc
Isa. 58:14 (KJV)
2013 BMW GSW (traveler)
1992 Ducati 900SS (looker)
1991 Honda Hawk NT650 (commuter)
Dr. Greg is offline   Reply With Quote
Old 04-01-2013, 12:23 AM   #7793
paulW
Oddometer: 143
Originally Posted by MaxReving View Post
I will go for the '13 1200GS LC. Why?
You have to choose the dynamic ESA for the new 1200GS LC in order to harvest the true upgrade to dynamics and versatility. The engine is upgraded in many ways as you already know but I think that you can sum it all up to: smooth, powerful and more torque through out.
Max :-)
Totally agree with you Max but would also add the Ride Modes and ASC are essential to gain all the benefits. The new GS is the SUM of ALL these parts
paul
paulW is offline   Reply With Quote
Old 04-01-2013, 12:57 AM   #7794
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,168
paul
Exactly the point.
Someone that plans to go for all new toys (new D-ESA, ride modes, LED) makes perfect sense to go for new bike. People looking for a more "conservative" setup, then the 04-12 looks fine. Remember the GS was the top bike of it's kind for the total of the years it is out (or most). A newer bike doesn't make the previous version cr*p.
(exceptions exist... like MS12 vs MT10)
NLS
My Blog
When the going gets tough, the tough get going...
NLS is online now   Reply With Quote
Old 04-01-2013, 01:05 AM   #7795
RichBMW
RichBMW's Avatar
Oddometer: 2,088
Originally Posted by Andylaser View Post
Ooh, I like the look of that
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 04-01-2013, 01:37 AM   #7796
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,430
A friend has a similar guard on his GSA's headlight. He's complained that it blocks a considerable amount of light, enough to cast that same pattern on the road at night.
twinrider is offline   Reply With Quote
Old 04-01-2013, 01:41 AM   #7797
NLS
NLS's Avatar
Oddometer: 3,168
These things are normally for off-road and have quick-release mechanisms when you don't need them.
Of course most are used by wannabe offroaders.
NLS
My Blog
Old 04-01-2013, 02:03 AM   #7798
paulW
Oddometer: 143
Makes me think of an Apache attack helicopter - very apt for the GS, in yer face, go anywhere bike
. . . not that I would do anything other than VERY light offroad on my own
Old 04-01-2013, 02:20 AM   #7799
GSMarc
GSMarc's Avatar
Oddometer: 1,103
Weight mesured : 247.2 kg ready to go. (545 lbs)
Back to the R1150GS weight
http://www.moto-station.com/moto-sta...ive.php?id=737
Perhaps, some weight could be saved in welding quality (see HP2 models)
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 04-01-2013, 02:34 AM   #7800
NLS
NLS's Avatar
Oddometer: 3,168
More videos...
(maybe posted before?)
(you don't get to see much actually )
(ok this guy has a weird sense of what a video is)
NLS
My Blog
Times are GMT -7.   It's 11:26 AM.
