Old 04-10-2013, 12:09 PM   #8281
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,192
Originally Posted by marchyman View Post
How about that "fill when on the sidestand" note in the owners manual? Has anyone filled on the center stand then moved the bike to the side stand to see if they actually could put more fuel in the bike.
Actually the opposite seems safer to try. Fill on side stand then slowly center it to see if fuel seems to go lower or stay at same position or what.
VERY good question (I did ask that like 20 pages ago but seems that mr. Als-what's-his-name is coming to me - hope not).
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 04-10-2013, 12:11 PM   #8282
alec
Oddometer: 13
Vario cases mounts on 1200GS 2013
Anyone knows if the mounts are different 2006 and 2013 GS versions for vario cases?
alec is offline   Reply With Quote
Old 04-10-2013, 12:26 PM   #8283
paulW
Oddometer: 143
That was something I saw in the English PDF version and posted here a while back. I did wonder about the sense in it. Having read the riders manual which came with my bike, that version does state, correctly, to put the bike on the main stand.
paulW is offline   Reply With Quote
Old 04-10-2013, 12:37 PM   #8284
NLS
NLS's Avatar
Oddometer: 3,192
!? How can they make such a mistake?
I mean I would understand not mentioning center stand specifically, but mentioning side stand instead?
I would still like someone to check moving the bike from one position to the other (erm... carefully ) when fuel is topped up.
NLS
My Blog
Old 04-10-2013, 12:37 PM   #8285
nwpa
Generally amused
Oddometer: 499
If the question is "can you use 2006 panniers on the 2013 W/C GS" the answer is "no". Among other things, the exhaust is on the right now.
nwpa screwed with this post 04-10-2013 at 02:22 PM
nwpa is offline   Reply With Quote
Old 04-10-2013, 12:43 PM   #8286
paulW
Oddometer: 143
probably copy & paste from the F800GS manual where it states correctly to use the side stand.
Old 04-10-2013, 01:01 PM   #8287
DMilan
Oddometer: 542
Bluhduh
Not ready to buy a WC in the near future..
I'll get one eventually....
I like what I see and read and the test ride only encouraged me.
Nice bike... still too tall for a 5'9er. Oh well.
Always liked the R1200GSs I've owned... but, for my taste, they needed cruise control. Real cruise control.
2 questions.
1. Anybody CALCULATED mgp yet?
I saw 50ish on the computer @ 60-65 mph.
2. Low suspension is not available with the high zoot ESA, right?
Dmilan
DMilan is offline   Reply With Quote
Old 04-10-2013, 02:12 PM   #8288
mefly2
mefly2's Avatar
Oddometer: 1,228
The gauge is quite accurate on the top half. The bottom half decreases at different rates. Yes, you can fill just a bit more on the center stand.
35-50 mpg around town (CALCULATED 35 * 50 often indicated); 60+ calculated on the highway at 65 mph... it is still too new to have long mileage for comparison to factory specs. If you follow the upshift / econo indicator, it seems like the engine is turning too slowly ...maybe I am just not used to the extra hp and torque over older models, but we shall see.
Yes, this has real cruise control - very nice to not have to set the right hand bar end cruise for me.
I am converting my top box mount from F/GS to function on the 1200GS-water.
mefly2 screwed with this post 04-10-2013 at 02:18 PM
mefly2 is offline   Reply With Quote
Old 04-10-2013, 02:39 PM   #8289
NLS
NLS's Avatar
Oddometer: 3,192
Pics!
NLS
My Blog
Old 04-10-2013, 02:55 PM   #8290
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
2 questions.
Dmilan
low suspension is ONLY available with dynamic ESA
EJ_92606 is offline   Reply With Quote
Old 04-10-2013, 03:27 PM   #8291
DMilan
Oddometer: 542
Thanks for the reply
So, let me get this right...
Low Dynamic ESA is the high zoot suspension, electronically adjustable, just LOWER in height than standard Dynamic ESA.
Meaning, 3 preload settings, and hard, regular, soft for shock damping.
When I buy a WC GS... I really need it lower than the stock suspension version that I test rode.
The WC that I rode had the standard / non ESA suspension. I had it set on minimum pre load, but like prior GSs I've ridden and owned it was just too tall for me to be comfortable.
Last GS I owned was a 2011 GSA. Lowered it 2" with Wilbers WESA.
At that height, wth a Low Sarent Seat, it was just right for me.
d'milan
Old 04-10-2013, 04:01 PM   #8292
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Yeap
Old 04-10-2013, 04:11 PM   #8293
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,496
Dmilan
I'm a lowly 5'7" with a 30" inseam and the standard suspension felt fine for me. Been riding tall adv bikes for a while, guess I am used to only being able to put one foot flat on the ground.
twinrider is offline   Reply With Quote
Old 04-10-2013, 05:16 PM   #8294
Bazgab
Bazgab's Avatar
Oddometer: 202
Yeah I am 5'9"-5'10" with 30" inseam, never had a bike this tall but all the big 1200 adv bikes I have test rode were a piece of cake to handle (other than the Tiger Explorer being top heavy).
Bazgab is online now   Reply With Quote
Old 04-10-2013, 07:41 PM   #8295
bolderboulder
Oddometer: 123
I just checked my manual, now it just says "Make sure ground is level and firm and park motorcycle." without saying which stand to park it with.
bolderboulder is offline   Reply With Quote
Times are GMT -7.   It's 02:15 PM.
