Old 04-28-2013, 04:38 AM   #8686
specs
specs's Avatar
Oddometer: 7
Originally Posted by jerryj View Post
How does one get the cover off the GPS mount? I've turned the key and pushed both levers .Don't want to break anything. Thanks.......................Jerry
Turn the key
Pull the left lever our
Push the right lever in
Good luck!
specs is offline   Reply With Quote
Old 04-28-2013, 04:54 AM   #8687
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
Guys,
maybe I have a problem... have to test it further.
While UPshifting to the 2nd or 3rd gear, even when I do catefully blip the throtle -- quite an often -- I hear a clear and intensive metal impact. Sometimes I even fear then the teeths are audible (omfg!).
The problem is... that from the short test of my friends other LC, I noticed no such strong sound (=much weaker)... the similar for some other bike tested by members of our CZ forum.
odo: ~3500km to date.
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 04-28-2013, 06:42 AM   #8688
268
268's Avatar
Oddometer: 168
Originally Posted by Hicks View Post
Guys,
Maybe a clutch problem.
With a cold engine, and my clutch lever in the position N°1 (shortest distance from the handlebar) I can't get the bike into gear.
Also, when I engage the clutch lever, 50% of the distance I pull the lever, I have no pressure at all
As I put the lever in position N°2, I can put the bike in gear, but have a real short distance/space for changing gear, and hear this metal clunk as well.
Was at my dealer yesterday, and he asked me to bring the bike in this week, for a check up.
Will keep you informed.
268 is offline   Reply With Quote
Old 04-28-2013, 06:51 AM   #8689
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
and when upshifting to 2 or 3, you hear the same sound as well?
btw: I've done some research over a clutch already:
http://www.advrider.com/forums/showthread.php?t=881708
Old 04-28-2013, 09:11 AM   #8690
268
268's Avatar
Oddometer: 168
Yes, it seems to go decrease a lot, when I put the clutch lever in position 4, but it really never goes away.
Now I've had several bikes and some of them had this 'noise-issue' as well, so I don't make much problems of it. The loss of clutch OTH, I don't like so much..
Old 04-28-2013, 12:18 PM   #8691
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
pls what do you mean with that "lever position 4"?
btw: maybe you hit the solution... my friend (a 1150GS rider) did not pull the brake lever all the way to the handlebars.
Tomorrow I will try just the same... Hicks is used to pull the clutch lever as much as possible towards the grip.
Old 04-28-2013, 12:27 PM   #8692
268
268's Avatar
Oddometer: 168
the lever position : you can adjust your clutch lever (on the left handlebar) froms position 1 to 4.
Normally pos. 1 is when you have smaller hands, so the clutch lever comes closer to the handlebar
N. 4 is when you have big hands
Old 04-28-2013, 12:34 PM   #8693
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
now I got it...
gonna test that "not-fully-pushed" throttle lever on monday, will inform then. Maybe it will help..
I know that wet clutches do not disengage fully... but... not sure if my particular clutch on the LC does this stuff just TOO MUCH...
Old 04-28-2013, 01:04 PM   #8694
PNWRR
not fragile
PNWRR's Avatar
Oddometer: 877
Originally Posted by At adventure View Post
Definately retains the Boxter feel but in a much more powerful and refined way without loosing the character. Vibes about the same but without the hard edges e.g the engine braking is very effective without the harsh feel of the previous model (my previous bike was a 2010 GS).
Agreed. I test rode one on Friday out of South Sound BMW. Talk about sh*t eatin' grin. Did about a one hour ride (the shop was slow). For comparison I own a R1100GS, an '03 R1150R and I have ridden a friends 2007 R1200GSA and his 2011 Camhead. The GSW is a departure from the air cooled. I just thought BMW came up with it just to comply with emission standards and that it wouldn't be anything better than the camhead. Not so. It was planted and easy to ride, the torque kicks in right past idle. My advice is to not pour over all the little details and minutia of the bike (there are a lot of mode switch buttons and such). Just ride it with no preconceived notions about what you think it should be and have a good time. As usual, ymmv. Good luck, also, with your current bike.
PNWRR is offline   Reply With Quote
Old 04-28-2013, 06:45 PM   #8695
madefrtv
madefrtv's Avatar
Oddometer: 427
Ive got 1300 miles now. so far the only complaint I have is a sticky horn. yesterday I honked at a cage to get her a$$ in gear and the horn, not the button, stuck on. I wonder if something is up from the first service reflash.
Its not too bad, the same reflash made the grip heaters warmer
whoa, dude...
madefrtv is offline   Reply With Quote
Old 04-28-2013, 07:02 PM   #8696
hammick
hammick's Avatar
Oddometer: 1,750
My heated grips are not as warm as I would like. What is the software supposed to address?
When I picked mine up on 4/19 the dealer flashed the software to get the Enduro Pro mode working. I think I should have the latest software unless the Enduro Pro was a separate module. They also said they had to flash the ESA module after the Enduro Pro.
2015 R1200 GSA
2014 Moto Guzzi California Custom
2013 KTM 500 XC-W
hammick is offline   Reply With Quote
Old 04-28-2013, 07:29 PM   #8697
madefrtv
madefrtv's Avatar
Oddometer: 427
I don't know the details of the flash, I just noticed that my grips were more suitable than they were prior to the service trip. It was the reflash that encouraged me to cough up for the first service at the dealer instead of my usual DIY.
Has anyone else experienced a sticky horn? This event made me look much angrier than I really am.
whoa, dude...
Old 04-28-2013, 10:46 PM   #8698
cyclingjetpilot
Oddometer: 10
Ignition
I was on a ride yesterday and turned off the bike with kill switch. I forgot to turn the key to the off position, and pulled the whole key cylinder out. I was able to put it right back in and it worked normally. It pulls right out easily in the on position. Can you guys with 2013 GS LC check this, and let me know results?
cyclingjetpilot is offline   Reply With Quote
Old 04-29-2013, 01:35 AM   #8699
IB1
IB1's Avatar
Oddometer: 1,002
I know the 'problem'. When it is cold and I start my bike in first gear is gets a little push forward. And it also has a tendancy to jump ahead a little when shifting it in 1st gear.
IB1 is offline   Reply With Quote
Old 04-29-2013, 01:40 AM   #8700
madefrtv
madefrtv's Avatar
Oddometer: 427
Not really a problem. Every wet clutch shared transmission bike I have ever owned thunks into first and lurches a bit.
whoa, dude...
Times are GMT -7.   It's 01:50 AM.
