Old 04-29-2013, 03:16 PM   #8716
Double_U
Double_U's Avatar
Oddometer: 9
Question
Originally Posted by atg View Post
Not only it works perfectly but charges the 660's battery as well !
On my GSW I've swapped the BMW GPS mount for the Zumo 660; not the whole mount just the central part ( with the BMW logo on it ) that that is similar to the one that comes with the Zumo 660.
The Zumo 660 has 2 wired headphones outputs: one is on the left side of the GPS under a rubber cap and the other, on a pig tail connected to the 660's mount. When mounted on the GSW GPS mount the unit's plug is not accessible as its blocked by the BMW's mount.
I did this so I can listen to music and driving informations through wired headphones (attached to the pigtails plug ) as I find bluetooth headphones cumbersome and with low audio quality.
It is fairly easy to do this as the mount is hold with 4 screws and nuts. I had to remove the right the bike's fairings to conect the power wires and to attach the headphone female plug to the bike where I plug the headphones.
Just thought I would share the idea.
Andre
I use my 660 on my previous bike wired too. Do I need to cut cables to switch mounts or can I simply disconnect the wires from the BMW mount? Can you post pictures how you did this? Tnx!
Wouter
Double_U is offline   Reply With Quote
Old 04-29-2013, 07:15 PM   #8717
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,724
Originally Posted by PNWRR View Post
Agreed. I test rode one on Friday out of South Sound BMW. Talk about sh*t eatin' grin. Did about a one hour ride (the shop was slow). For comparison I own a R1100GS, an '03 R1150R and I have ridden a friends 2007 R1200GSA and his 2011 Camhead. The GSW is a departure from the air cooled. I just thought BMW came up with it just to comply with emission standards and that it wouldn't be anything better than the camhead. Not so. It was planted and easy to ride, the torque kicks in right past idle. My advice is to not pour over all the little details and minutia of the bike (there are a lot of mode switch buttons and such). Just ride it with no preconceived notions about what you think it should be and have a good time. As usual, ymmv. Good luck, also, with your current bike.
Just got back from an hour long test ride.
This bike had all the bells and whistles. I liked most of it. My regular ride is an 1150GS first registered on the 29th of April, 2003, I've put 180000km on it since then.
It felt light, powerful and manoeuvrable. Everything worked easily. Because I am used to a tighter throttle and clutch lever, it took me a while to get more used to this, but an hour wasn't enough.
Things I liked:
Ergonomics, so much better, seat on high, nice and narrow.
Power, shit it goes.
Brakes, outstanding
Wind-shield, nice
Sound, much better than the old standard exhaust sound.
Cruise control, loved it.
Suspension
Things I can take or leave:
Gearbox, the way it shifts
Adjustable suspension, have not used the bike on gravel, so not sure.
The water-cooling, completely unobtrusive, didn't bother me at all.
Things I didn't like:
Instruments, it's harder to see what's going on, dials too small
Throttle, takes a while to get used to
Brake leaver, seemed to pull too far in, but was probably adjusted for a shorted fingered midget.
A lot of plastic, still like the over all look , though
Would I buy it? Yes, I would. However, the old bomber is still going strong and I like how it squads down and goes around corners.
R1150GS
R80GS Basic
Kokopelli screwed with this post 04-29-2013 at 11:56 PM
Kokopelli is offline   Reply With Quote
Old 04-29-2013, 09:42 PM   #8718
TommyHolly
Teaparty member
TommyHolly's Avatar
Oddometer: 215
Does anyone know if owning a 2008 BMW R1200GSA counts towards a loyalty discount for a BMW X5? They are advertising both the X5 and the R1200GS on the American website but even BMW call center doesn't know??
"When the debate is lost, slander becomes the tool of the loser." - Socrates
"Everyone is entitled to his own opinion but not his own facts." - Daniel Patrick Moynihan
TommyHolly is offline   Reply With Quote
Old 04-29-2013, 10:05 PM   #8719
Larch
Oddometer: 26
Cool2 Another Test-Ride Reaction
[QUOTE=Kokopelli;21296845]Just got back from an hour long test ride.
Things I liked:
Brakes, outstanding
Wind-shield, nice
Suspension
To add to Kokopelli's post from my own recent two-hour test ride:
I also liked the amazingly smooth final drive to the shaft—no driveline lash whatsoever!
I would move the Gearbox issues to "didn't like" (stiff and obdurate), and I would take the throttle off the "didn't like" list (I'm used to a very twitchy Tiger 1050 throttle, so the GS's throttle seemed fine to me).
Also I didn't like the very noticeable and intrusive high-frequency vibration that starts at about 5k, peaks at about 6k, and disappears by about 6.5k (i.e. at the most torquey/useful part of the range). Was this just a freak thing with this demo bike? (No one else seems to have mentioned it).
And I did not like the pathetic cheap little indicator switch that has virtually no "feel" to it, making you check the dash to see if the indicators are working.
Overall, I was mightily impressed, with the exception of the vibration: that might be a show-stopper for me.
Any other info. regarding high-frequency vibration would be appreciated. I have ridden GSs before, but not for long periods of time on the road.
Larch is offline   Reply With Quote
Old 04-29-2013, 10:29 PM   #8720
atg
atg's Avatar
Oddometer: 241
Wouter
Wouter;
Sorry I cano not post pictures yet... However, I wrote a tutorial on the procedure. Hope it will shine a light on how to do it.
Tutorial on how to switch the BMW Navigator IV for a ZUMO 660/665 on a R 1200 GSW
1 I suggest that before starting a photo is taken of the original GPS mount, with and without the GPS mounted. This way you will have a future reference to its position on the bike. The picture should be taken straight on showing also the bike's dashboard, again for future position reference.
2 Reove the left side fairing to gain access to the GPS connector. Notice that the GPS cable has 2 connectors, however only one is used.
3 Uncrew the 4 screws that hold the mount together. Be careful not to lose that back nuts. For future reference notice that these crews are only lightly tightened as the GPS's mount is rubber mounted.
4 Remove the mount and take to a clean, well lit area.
5 Unscrew all the philips crews that hold the front and back of the mount together.
6 Very carefully open both halves as there are 2 springs inside. One pressurizes the left side lever and the other pressures the top locking tab. Notice the springs positions.
7 To the same to the original ZUMO mount as it is necessary to switch the left side levers. On the BMW mount this lever is longer than on the ZUMO and its necessary to have the longer one to be alble to remove the ZUMO from the BMW mount.
8 Reassamble both mounts and safe keep the BMW original mount now with the short left lever.
9 Mount the modified ZUMO mount on your bike. Notice that if yoy adjust its angle properly it will be unlikelly that it will block the tach. (rpm meter).
10 If possible, instead of the original nuts, use self locking nuts with a nylon insert. As these shouldn't be over tightened the original nuts may come off.
11 You may either connect the ZUMO's wiring straight to the bike's battery or to the original BMW's GPS plug.
The first method has the advantage of leaving the bike's original wiring intact but the GPS will not be switched off by the ignition.
The second method requires that you cut and splice the ZUMO's wiring to the original BMW's wiring ( that was my personnal choice ).
12 Obviously the multi switch on the left handlebar will continue to not work with the ZUMO.
13 If you want to use the wired audio output, in fact the only reason to switch mounts, you may attach it to a convenient location for easy plug in. On my GSW I mounted it on the low black fairing turned down as to prevent rain to infiltrate.
Sorry abou eventual spelling mistakes but English is not my maiden language...
André
atg is offline   Reply With Quote
Old 04-29-2013, 11:03 PM   #8721
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,724
[QUOTE=Larch;21297882]
Yeah, forgot to put that on my most hated list. BMW f'ked up with this one, because of a few whining journos with nothing else to complain about.
R1150GS
R80GS Basic
Old 04-30-2013, 04:34 AM   #8722
Perfpup
Perfpup's Avatar
Oddometer: 24
Originally Posted by IB1 View Post
Discovered another little thing yesterday. Riding at around 40 mph with cruise control handsfree. The steering wheel is oscillating a bit. The wheel keeps going nice and straight, but the handlebars visually osscilate a bit. A bit strange and doesn't inspire confidence to ride handsfree.
Mine does the same thing and seems to be worse when deaccelerating in that same speed range. Wondering if it is the tires mine are the metz next tire?
Perfpup is offline   Reply With Quote
Old 04-30-2013, 05:19 AM   #8723
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,507
Nice yard!
Jim
Old 04-30-2013, 05:51 AM   #8724
IB1
IB1's Avatar
Oddometer: 1,026
Metzlers here to.
IB1 is offline   Reply With Quote
Old 04-30-2013, 07:27 AM   #8725
hammick
hammick's Avatar
Oddometer: 2,085
Metzlers here to.
Same for me with Tourance Next. Very little oscillation. Nothing compared to my '05 LT.
2015 R1200 GSA; 2015 R1200R; 2014 FE501
hammick is offline   Reply With Quote
Old 04-30-2013, 10:04 AM   #8726
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,190
Is this what the journalists whined about in S. Africa?
NLS
My Blog
When the going gets tough, the tough get going...
NLS is online now   Reply With Quote
Old 04-30-2013, 10:07 AM   #8727
emack
Oddometer: 38
Love this bike!
So I went to a local dealer (about an hour away in Lititz, PA) on Friday to ride their demo bike and absolutely loved it! It feels much better/sporty/lighter/comfortable than the Tenere and the Explorer, and I wanted to put $$ down on one as soon as I got back from testing it out. Problem is, that dealer doesn't have any coming in with the options I want (comfort, dynamic, cruise), so called around after I got home and found one that's almost perfect - everything except the color (white instead of Thunder grey). No big deal, so I put money on it right away. It's about and hour and a half away and gets to the dealer in about ten days. I can't wait!
Sorry to see my KLR go, but it's going to a friend so I know it's going to a good home.
emack is offline   Reply With Quote
Old 04-30-2013, 10:12 AM   #8728
Velociraptor
TrackBum
Oddometer: 1,139
Possibly a repost but there was a big comparison test of the WC GS in Bike magazine. Bottom line was the KTM 1190 was more fun but the GS was the better overall bike and won the comparison. I am leaning towards the KTM, but there is a good chance I will pass on getting any big Adventure bike!
Of more interest was their dogged attempt to get the GS to do the dreaded bar swapping speed wobble that happened during the initial test in South Africa. They could not get the bike to do it despite their best efforts.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 04-30-2013, 12:32 PM   #8729
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
so I'm not alone
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 04-30-2013, 12:39 PM   #8730
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
Does the new KTM have cruise control?
Sent from my iPad using Tapatalk HD
PirateJohn is offline   Reply With Quote
Times are GMT -7.   It's 05:27 AM.
