Old 05-13-2013, 04:20 AM   #8896
ararat
Dr. BMW and Mr KTM
ararat's Avatar
Oddometer: 1,971
And i thought i found a bike, SYDADVGS one seemed soooo cool...
Well, i may not buy a bike after all.
"Ask nasty questions!" gerard t'hooft
ararat is offline   Reply With Quote
Old 05-13-2013, 04:24 AM   #8897
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,518
Originally Posted by Andylaser
If someone made some nice lightweight ally panniers that fitted the Varios mounting points and didnt require an extra frame, they would be on to a winner.
Originally Posted by monoi View Post
I totally agree! Triumph has the same type of fitting as BMW, surely it cannot be out of the realm of the possible to have aftermarket luggage manufacturer to make similar mountings?
I'm sure it is possible, but why would anyone use the cheap plastic mounts as a base when they could use the GS Adv metal ones much easier, or make and sell their own?
Jim
JimVonBaden is online now   Reply With Quote
Old 05-13-2013, 04:36 AM   #8898
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,102
I thought the mounts were metal??
I might be wrong though, I havent seen them. A "small" ally pannier around 30 litres would be excellent and better/narrower than the varios. Also quickly removed without having the frame left behind.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 05-13-2013, 04:41 AM   #8899
JimVonBaden
"Cool" Aid!
Oddometer: 54,518
I may be wrong, the old R1200GS mounts were plastic.
Jim
Old 05-13-2013, 05:21 AM   #8900
monoi
Oddometer: 117
The mounts on the BMW and triumph are metal alloy of some kind.
Normally I don't mind a frame, but it was then and it is now. The OE solution is more elegant.
monoi is offline   Reply With Quote
Old 05-13-2013, 06:55 AM   #8901
Hambonee
Hambonee's Avatar
Oddometer: 178
This!
Not only would the lack of frame keep the bike smaller in the but but I think it would imrove handeling.
I don't need side cases I can haul everything in my house around..I'm a functional guy..this would be my cup of tea
Hambonee is offline   Reply With Quote
Old 05-13-2013, 07:37 AM   #8902
gr8ridn
gr8ridn's Avatar
Oddometer: 419
Originally Posted by marchyman View Post
For those in the US... where did BMW hide the evaporative canister?
I can't find it on the realoem parts breakdown.
I haven't been able to find it either.
I am waiting for the RepRom to be available so I can really understand this bike. I had a tough enough time finding the clutch slave cylinder. I think it needs to be bleed. Too much drag during 1-2 and 2-3 shifts causing gear clash. I have the clutch lever on position 4 and it doesn't help. 900 miles on the bike so far. I have a F800GS so I think I know how a wet clutch should work.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 05-13-2013, 09:46 AM   #8903
gr8ridn
gr8ridn's Avatar
Oddometer: 419
Found it listed in the MAX BMW parts site. Where it is I don't know, but now I know the bike has one.
part number 16 13 7 727 387
2014 R1200GSAW
Old 05-13-2013, 12:05 PM   #8904
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 829
Hi Kevin,
Any update on when we can expect to get these crash bars?
Originally Posted by twistedthrottle View Post
Thanks for the order Doc! You may have just ordered the first set of SW-MOTECH crashbars for a water cooled GS in all of North America! I hope you will post pictures and impressions once you get them.
Kev
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 05-14-2013, 11:19 AM   #8905
Stinez
Rhymes with Heinz :D
Stinez's Avatar
Oddometer: 49,738
Originally Posted by tshelver View Post
Hard bags look nice, are more convenient and give a bit more security, but so far I've found quality soft bags to be more crash resistant and wear better on really bad roads, and just as waterproof.
Which soft bags are you using?
How are they mounted?
I ask because the only time I run the hard bags on my ADV style bike is on longer trips so spending $$$ on trick hard bags doesn't sound like it'd be worth it to me.
So soft and functional side bags my be the best compromise.
The GOP puts the "Con" in Conservative.
Stinez is offline   Reply With Quote
Old 05-14-2013, 01:38 PM   #8906
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 3,071
Because I'm to lazy to read though 500+ pages I'll just ask the question.
You 13 owners have Anakee 3's on your bikes from the factory.
Any general consensus on how they are holding up?
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 05-14-2013, 06:21 PM   #8907
HalB
HalB's Avatar
Oddometer: 52
Originally Posted by NLS View Post
British KTM forum about Kevin Ash related article:
http://www.ktmforum.co.uk/adventure/...gs-faulty.html
British GS forum about Kevin Ash related article:
http://advrider.com/forums/newreply....e=1&p=21395934
Interesting thread, thanks for the link.
HalB is offline   Reply With Quote
Old 05-14-2013, 07:43 PM   #8908
cyclingjetpilot
Oddometer: 10
Originally Posted by At adventure View Post
Mmmm makes you wonder? My bike (1800km with spoked rims) has developed a bit of a front end wobble in a straight line above 80km. Probably just needs a wheel balance but surprising given I have not taken it off road yet. I will get it checked out and report back. AB
I've had the same issue since mile 6. Its a out of round Michelin Tourance Next (front tire). They are not avail. So I ordered a Set of Conti trail attack 2. There not released till the 15th. They checked, and everything else was good to go. Put your bike on the center stand weight the back end. Spin the front tire,put something close to it for reference to see if there's any high spots.Mine has an obvious high spot. I also have spoked rims. Mines got a solid shimmy, can feel at all speeds. Very pronounced 50, to 65, and on deceleration. More pronounced with my wife on back.
cyclingjetpilot is offline   Reply With Quote
Old 05-14-2013, 07:51 PM   #8909
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,566
I think it is in the front under the tank.
On a side note, a friend said it is in the gas tank....
Cheers!
Dave
Racegun is offline   Reply With Quote
Old 05-14-2013, 09:28 PM   #8910
Voz
Voz's Avatar
Oddometer: 502
Day 1 2013 GSW
Ok, so after waiting 4 months I finally took delivery of my red GSW yesterday. I ticked all the options boxes including LED, spoke wheels, Cruise, ESA, etc. I also kitted the bike out with SW Motech lower & upper crashbars, rear panniers, ALU Rack and Trax pannier boxes.
AUSSIE MADE RADGUARD RADIATOR GUARDS.
For daily commuting usage I then fitted a Givi 55L top box and BMW Large Tankbag.
This is my first big bike having just come off my learner/provisional license over the last year. To say I was apprehensive about riding this thing for the first time is a massive understatement. I was pretty much shitting bricks, especially when it was raining on the pickup day, lol!
Ok, so I started her up and took off. My initial impressions:
- Did not feel much heavier than my previous Kawasaki Versys 650
- Same seat height as my Versys 650, the BMW was configured for 1 rider + luggage
- The feel on this bike is very solid, kind of like sitting in an S Class merc compared to a small 4 Cyl car.
- The BM is nimble and fairly easy to manouvere at low speed.
- The clutch lever is not as light as some have suggested, my left wrist got quite tired holding the clutch lever in when waiting in traffic.
- The gear box is extremely smooth when gear changing, the gear changes just snick into the next gear, no effort, no clunks or thuds (1st gear selection when taking off does have a very slight surge but it is not alarming).
- The horn switch does not stick out as much as other bikes, your thumb has to hunt for it.
- The indicator switch is quite small and a little unnaturally far awa from the thumb, there is no clunk as you select a direction and you wonder if you have quite engaged it.
- I found the handlebars a little low for my liking, to stand I am hunched over. I am 6ft 1" short legs long body.
- The mirrors are excellent compared to my previous Kwaka, they can see so much and have a ball adjustment where they meet the top of the arm to allow for almost infinite adjustment.
- The power, oh the power! I started off in Rain mode which was cool, then put it in Road mode which was a little more urgent but still restrained, I have not tried Dynamic yet, will ride a few more days in Road mode first.
- The suspension comfort is just sublime, I have not yet taken it out of Soft, it soaks up the inner city bumps and road irregularities with ease. Just so incredibly comfortable.
- I think the LCD display and analogue speed & RPM meter are a bit of a let down. A lot of info is written in small LCD lettering. The speedo numbers are almost impossible to read. The LCD in daylight is just hard to view, at nite is it fine.
- You really start to feel the size and weight of the bike when you are moving it around the car park, it has a momentum that it just wants to keep rolling, you have to be mindful to pull it up.
So, after 150klm on day one I am now fairly comfortable with the bike and somewhat acclimatised to the bike. My biggest problem really is getting the RPM correct and clutch release correct when taking off particulalry on a slight or steep hill. I just can not find the sweet spot. I seem to be over revving it as I am not confident taking off around 2000 rpm as I think it might stall but it probably wont.
I left my work car park yesterday which is a steep ramp from LG to L1 and it was a disaster, all my work mates were there cheering me on and I fluffed it. Too much RPM, tooo little RPM, clutch all over the place, abandoned the launch, pulled the clutch in and rolled backwards down to level ground. Then relaunched 3-4000 RPM and made it up with heart beating at the top.
Anyway, much too early yet to report anything else, will go on a bit of a ride tonite then a club ride tomorrow nite so hopefully more useful info after that.
Anyone who has any clutch/launch advise is welcome to reply, I need as much input in this area as possible, cheers!
Voz screwed with this post 05-14-2013 at 09:34 PM
Voz is offline   Reply With Quote
Times are GMT -7.   It's 02:33 PM.
