Old 06-22-2013, 07:46 AM   #9646
IB1
IB1's Avatar
Oddometer: 1,026
I actually prefer the 2 peace seat. It gives me some support against sliding back when accelerating vigorously. And on the Rally seat I can't touch the ground.
IB1 is offline   Reply With Quote
Old 06-22-2013, 08:13 AM   #9647
RichBMW
RichBMW's Avatar
Oddometer: 2,114
Originally Posted by oz97tj View Post
I'm with you on this.
My slightly more objective reaction sitting on one in the dealer for about 15 minutes was it is firmer and narrower as Rich said. Granted, I haven't ridden it, but I can't see it being more comfortable for long stretches. The only real perk I see to pavement riding is the ability to move back and forth a bit which could possibly alleviate any pressure points.
Rich, it looks way better if you remove the rear rack too. Just saying...
I've had a gel insert put in my Enduro seat, and its all day comfortable.
I have thought about removing the rear rack, but my wife wants to come out on the bike, and I can't be bothered to refit it every time she wants to come out!
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 06-22-2013, 08:55 AM   #9648
oz97tj
oz97tj's Avatar
Oddometer: 832
Do you strap her to the rack?
'15 KTM 500 EXC / '13 BMW 1200 GSW / '05 Honda ST1300 / '04 Husqvarna TE510
oz97tj is offline   Reply With Quote
Old 06-22-2013, 01:42 PM   #9649
Imola
Oddometer: 12
Anti-theft alarm (DWA)
In the Riders Manual R1200GS you could read:
If the alarm system is activated,
then the alarm system will be
automatically activated when
the ignition is switched off.
Activation takes approximately
30 seconds to complete.
Turn indicators flash twice.
Confirmation tone sounds
twice (if programmed).
Anti-theft alarm is active.
Is there anyone of you who have gotten Confirmation tone to work?
Imola is offline   Reply With Quote
Old 06-22-2013, 03:05 PM   #9650
atg
Oddometer: 225
I do.
atg is offline   Reply With Quote
Old 06-23-2013, 03:49 AM   #9651
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 828
I agree with the small amount of low back support. Don't have a problem flat footing it though (34" inseam)
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 06-23-2013, 06:26 AM   #9652
Imola
Oddometer: 12
Originally Posted by atg View Post
I do.
Please tell me!!!
Imola screwed with this post 06-23-2013 at 09:21 AM
Old 06-23-2013, 07:39 AM   #9653
paco fernandez
Mexico
paco fernandez's Avatar
Oddometer: 64
Originally Posted by Sete View Post
Hi
I would like to know if there is any conflict installing Touratech's upper crash bars and the BMW's auxiliary headlights.
Do you know if they are compatible?
Sete
Not compatible, they bolt to the same part o f the chassis.
Enviado desde mi iPad con Tapatalk HD
paco fernandez is offline   Reply With Quote
Old 06-23-2013, 08:24 PM   #9654
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Love the white, LED's...
tallguy-09 is offline   Reply With Quote
Old 06-23-2013, 08:41 PM   #9655
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Ya looks great. Someone told me though that in the U.S. you can't have just the LED DRL on, that you have to have the headlight on all the time as well...and when the headlight is on the DRL dims to half brightness. Can anyone confirm?
EJ_92606 is offline   Reply With Quote
Old 06-23-2013, 09:00 PM   #9656
iride4u
iride4u's Avatar
Oddometer: 321
False
The DRL comes on with the ignition and the low beam will automatically turn on as needed.
iride4u is offline   Reply With Quote
Old 06-23-2013, 09:21 PM   #9657
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by iride4u View Post
False
My friend's bike the headlight is on all the time and he says it can't be shut off...so how do you shut it off?
edit: per page 51 of the U.S. manual....The lowbeam headlamp switches on automatically when the engine is switched on.
EJ_92606 screwed with this post 06-23-2013 at 09:28 PM
Old 06-23-2013, 10:57 PM   #9658
atg
Oddometer: 225
Please tell me!!!
As I replied earlier when I switch the ignition off, after some 30 seconds it beeps informing the alarm is on.
If I remember correctly it has to be set through a dealer's computer and you have a choice of 2 different types of sounds.
Once it is set up by the dealer you can switch the alarm on and off through custom activation.
Customize anti-theft alarm system settings
1 Switch on ignition or bring motorcycle to a stop.
2 Repeat pressing button "TRIP" briefly, until in the top line of the display shows SETUP ENTER
3 Press and hold button "TRIP" to start the SETUP menu.
4 Press button "TRIP" briefly to respectively select the DWA menu item.
5 The top line of the display shows DWA.
6 The adjusted value appears in the bottom line of the display
7 Press button "INFO" briefly to change the adjusted value.
The following settings are available:
On: Anti-theft alarm system is activated automatically when the ignition is switched off.
Off: DWA is deactivated
Andre
Old 06-23-2013, 11:53 PM   #9659
Kaj
Gessu
Oddometer: 13
Just finished my two and half weeks trip from Finland down to Gibraltar and back, total a bit over 6.000km.
GS was just perfect.
Kaj is offline   Reply With Quote
Old 06-24-2013, 05:30 AM   #9660
Imola
Oddometer: 12
Im aware that this needs to be set by a BMW garage.
Twice Ive had the bike there for fixing this with the service computer, but as soon as the ignition is turned off it returns to default settings. Do you have any information what to do to make it work on my bike as well? Is it as simple as leaving the EnduroPro plug in?
Times are GMT -7.   It's 03:41 AM.
