Old 10-16-2013, 02:07 PM   #10966
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Originally Posted by IndyTiger800 View Post
I guess what I'm also asking is when I get the bike is there a manual setting to start with so the ESA will have a starting point with me on it. Or is that point the same no matter who sits on it.
Not manual - you choose the appropriate setting with the button according to what you're loading on the bike (you, you with luggage, or you + pillion + with or without luggage). The ESA sorts out everything else based on information the computer receives from the various sensors.
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 10-16-2013, 02:12 PM   #10967
larryscustomcycles
Oddometer: 156
The baseline is the same no matter who sits on it. No matter if you are 50kg or 150kg.
larryscustomcycles is offline   Reply With Quote
Old 10-16-2013, 02:15 PM   #10968
IndyTiger800
Oddometer: 167
OK Thanks.
I got that part. I was wondering if there was an initial set up for an individual rider. I guess not. It looks like it is all in the ESA.
Thanks for all of the replies.
IndyTiger800 is offline   Reply With Quote
Old 10-16-2013, 02:19 PM   #10969
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Yes - a baseline is just that, a constant. The ESA will then adjust +/- a predetermined range to compensate for variances in weight within each setting. The baseline is 90kg for the single rider setting, if I remember correctly. If a 50kg rider sits on the bike the height sensor will then report to the computer that the bike is too high and it will adjust within the range for the setting. But if a 200kg rider sits, the bike would not be able to compensate sufficiently in the single rider setting and the rider would need to choose a firmer setting such as the 2-up + luggage setting.
Old 10-16-2013, 03:06 PM   #10970
IndyTiger800
Oddometer: 167
So to change the baseline you have to change the spring?
I'm 205 lb so I will be a little on the heavy side.
Time to get the mountain bike out.
Old 10-16-2013, 05:54 PM   #10971
nadredrum
Oddometer: 170
Actually that's about the baseline for on up.
nadredrum is offline   Reply With Quote
Old 10-16-2013, 07:33 PM   #10972
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,611
I'm curious as to where you obtained your information from, i was not aware that the preload was adjusted by anything but the rider settings (no automation beyond that), specifically the part about the bike's preload being automatically adjusted for differences in weight, even if only within a "predetermined range." I'm not speaking about the suspension's automated damping capabilities but the preload adjustments that you mention above. Thanks!
The excerpt below was taken from an article found at Ash on Bikes, the link is also supplied,
"The spring rate adjustment is not a part of the semi-active element of DDC, this is adjusted as in ESA II according to the base setting chosen by the rider. It isn't possible using existing technology to adjust the spring rate quickly enough for a semi-active system."
http://www.ashonbikes.com/content/bm...suspension-ddc
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 10-17-2013, 05:00 AM   #10973
TuonoBiker
Oddometer: 808
Thanks for pointing that out, Oalvarez. I was following the explanations above and nobody was pointing out that the new ESA settings were still split between the spring and then compression/rebound damping.
The Rider, Rider+Luggage and 2 Riders settings are all Preload settings cranked into the Springs....none of that can happen on the fly. Since Preload and Rebound go hand in hand, there could be some adjustments to rebound when you change the Rider/luggage settings. However, that may be primarily on the old ESA like my 2012.
The new system would change all damping settings on the fly...as its moving and reacting, valving is being opened/closed to speed up or slow down damping.
At least that is my understand. IMO, it sounds awesome and is getting great rider reports and reviews from everybody, it also sounds like there is too much fiddling. Can I just get on and ride? :)
I'm a fan of ESA - love adjusting preload for me or the wife and me, etc. The damping rates work quite well for my weight and wife's weight. Guess I'm lucky there.
'12 R1200GS Adventure
'06 Ducati 999S
'11 Harley Street Glide - gone and mostly forgotten
'07 Tuono Factory - gone but not forgotten
TuonoBiker is offline   Reply With Quote
Old 10-17-2013, 06:07 AM   #10974
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,305
Where is the Tire Pressure Monitor "brain" located on our bikes?
Old 10-17-2013, 07:55 AM   #10975
Random-Water
Oddometer: 141
Under the passenger seat. About 3.5" long and 2" wide held in place by 2 screws.
Random-Water is offline   Reply With Quote
Old 10-17-2013, 08:03 AM   #10976
Random-Water
Oddometer: 141
The ESA DOES change the spring PRE-LOAD. Obviously, it' CAN NOT change the spring rate itself. Just like with any bike/suspension, you can only adjust so much pre-load into a spring before you run out of adjustment. the ESA has broken the pre-load adjustments into 3 Categories. Light, medium and heavy. (1 up, 1 up + Luggage, and 2 up).
In addition, you can adjust DAMPENING/RESPONSE via the "Soft/Medium/Hard" option.
I'm 6'2" and 245 without gear. If I can find a comfy setup for off road and a firm setup for canyon carving, you should have no problem either.
Old 10-17-2013, 08:38 AM   #10977
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,305
Old 10-17-2013, 09:11 AM   #10978
IndyTiger800
Oddometer: 167
Old 10-17-2013, 10:24 AM   #10979
Paulvt1
Paulvt1's Avatar
Oddometer: 3,566
Is the ESA a worthwhile addition to the bike for the cost? Just curious - not trolling...
Paulvt1 is offline   Reply With Quote
Old 10-17-2013, 10:32 AM   #10980
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,305
Obviously, this is a personal decision. However, I am very much enjoying being able to adjust the damping to soft or normal (I don't usually use "hard") on the fly as I ride and the roads change. I also like setting the preload by touching buttons when I am loaded down for a tour as opposed to bopping around locally, instead of crawling around and doing it manually. I bought the ESA more or less as an experiment, just to see, and I have been glad I did, so far. I know that it will be expensive to replace should that become necessary, but I went with it and will see how it goes. I won't cry about it unless it goes bad sooner than it should.
Times are GMT -7.   It's 06:41 PM.
