02-04-2011, 01:56 PM
#1 |
Oddometer: 4
!979 R100RT more power for side car rig
any ideas for building a high torque engine for a R100 with side car. Would like to cruise at 70 mph, but still have power for passing.
Thanks Richard |
02-04-2011, 02:29 PM
#2 |
because I can
Oddometer: 6,082
Dual plug/higher CR, sport cam, late model clutch/flywheel, higher final drive ratio. You'll be set.
02-04-2011, 02:38 PM
#3 |
Oddometer: 3,978
Unless you're hauling MAJOR mass, you should have no problem cruising at 70 in stock mode at around 5K rpm.
LOOK OUT IT'S COMING THIS WAY! |
02-04-2011, 02:41 PM
#4 |
Lost In Place
Oddometer: 15,983
3.20 gears should work well for sidecar use with a healthy liter motor.
02-04-2011, 02:43 PM
#5 | |
Lost In Place
Oddometer: 15,983
Stock 2.91 gears won't pull 5k at 70 in 5th.
02-05-2011, 09:41 PM
#6 |
Mad Scientist
Oddometer: 2,966
How about a big bore kit Siebenrock 1070cc and a 3:09 final drive from a R90/6. Don't run a 3:20. Way to buzzy at highway speeds.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
02-05-2011, 11:35 PM
#7 |
Oddometer: 3,739
Not sure about the sport cam for hauling a sidecar. My RS has a sport cam and is noticeably down on umph below 3k compared to my bikes with the 308 cam. It goes very well at higher rpm though.
02-05-2011, 11:39 PM
#8 |
Mad Scientist
Oddometer: 2,966
I agree. Stay away from the sport cam. No low end torque.
02-06-2011, 08:02 AM
#9 |
Oddometer: 932
You will definitely have to change your rear end gear ration. Not certain of the one to go to, but the stock 32/11 will just not last and be so slow off the line your hack monkey will be out pushing.
![]() Check with some of the inmates over in the Hack section. I bet they can be all kinds of help. |
02-06-2011, 10:46 AM
#10 |
because I can
Oddometer: 6,082
I think a lot of hackers run a 3.56:1. I would think you would need at least a 3.36:1.
I know I would get some nays on the sport cam. I am surprised that I haven't gotten any on the late model flywheel clutch. Less umph under 3krpm? With my small port I would say under 2500rpm but MMW's bike is a big port. Even then it's barely any less and the payoff in the mid and upper revs are big! Sport cams are not top end cams, they are mid range cams. You shouldn't be working your engine hard below 3k anyway. Especially with a hack! An experienced hacker that I know got all kinds of nays on his sport cam and late model clutch but he loved the setup. Just saying! |
02-06-2011, 11:07 AM
#11 |
Lost In Place
Oddometer: 15,983
Exactly. Gotta wring it above 5k before you'll realise any advantage from a 336 cam. 5k-8k is where they work. It's a high end "timing" cam. Virtually no advantage in valve lift over the stock 308 degree cam. Rather, increased duration.
02-06-2011, 11:09 AM
#12 | |
Lost In Place
Oddometer: 15,983
Thanks. I'll heed your advice on that with my sidecar project. |
02-06-2011, 07:22 PM
#13 | |
because I can
Oddometer: 6,082
Well, at least you didn't say that the sport cam has no more lift than the 308. I have read that on internet forums and popular websites. FACT: It has substantially more lift. Look up the specs. No, it isn't a super high lift cam because it is not that radical of a cam. It does have a comparatively narrow toe to toe angle. Contrary to what you might think, narrow toe angles (overlap) HELP midrange. Many a tuner swear by it including Yunick and Dr Curve. I do agree that they work best from about 5 to 8k rpm. Where would you say a 308 works best at? I would say 4500 to 6500rpm. I would say the advantage definitely starts by at least 3k and by 4k it is substantial. By 5 k the difference is a big one and past 7k they are a night and day difference since the 308 comparatively does not work there. supershaft screwed with this post 02-06-2011 at 07:27 PM |
02-06-2011, 08:25 PM
#14 | |
Lost In Place
Oddometer: 15,983
Q. Where does the stock 308 degree cam work best?
A. Depends how it's degreed. Fact: '77 RS (and every other airhead except the R60/7) used the same cam profile (which determines valve lift and duration) as '79 and all later airheads. BMW degreed (references the cam's orientation to the crankshaft) the cam slightly differently after '78 or '79 (I forget which year the change was introduced) to improve torque/power production in the lower reaches of the rev range. Increased overlap tends to improve higher RPM power production at the expense of lower RPM efficiencies. The differences are pretty easy to identify on an airhead twin. Quote:
My experience with the 336 cam in a '77 RS was pretty forgetable. Andrews cams (now mfg'rd by Mega Cycle) produce more impressive performance gains. |
02-06-2011, 08:47 PM
#15 |
Coyote's Brother
Oddometer: 3,299
Mega Cycle appears not to list any Airhead Cams. You got any inside info?
Hawkdude Hate rots the pocket that carries it. |
