Old 02-07-2011, 06:06 PM   #1
Low Brow OP
Inappropriate...
Low Brow's Avatar
Oddometer: 111
How to remove old gaskets?
Hey does anyone have some good tips for removing old gaskets?
I am struggling to remove the old clutch cover gasket from my 2006 DR650. 2 hours of scraping with a razor blade and still only halfway there....
Low Brow is offline   Reply With Quote
Old 02-07-2011, 06:14 PM   #2
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,844
I always used a dull chisel, I gouged the case less.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is online now   Reply With Quote
Old 02-07-2011, 06:15 PM   #3
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,540
http://www.amazon.com/dp/B000FW61EM/ref=asc_df_B000FW61EM1423509?smid=ATVPDKIKX0DER&tag=pg-95-95-20&linkCode=asn&creative=395093&creativeASIN=B000FW61EM
Sorry, previous was a bad link.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin screwed with this post 02-08-2011 at 05:46 PM
vtwin is offline   Reply With Quote
Old 02-07-2011, 06:29 PM   #4
anotherguy
anotherguy's Avatar
Oddometer: 6,631
I use paint stripper applied by acid brush. Be very careful as it's nasty,nasty stuff. Have some water close by and wear gloves, eye protection. Apply and let sit for 15-30 minutes and scrape with razor blade. Tough old gaskets may require 2 or 3 tries.
you don't see luggage racks on a hearse..........act accordingly
Old 02-07-2011, 06:32 PM   #5
Low Brow OP
Inappropriate...
Low Brow's Avatar
Oddometer: 111
Cheers, How did you stop the paint stripper from removing the paint on the case cover? Or is it easiest just to do a quick repaint afterwards....
Old 02-07-2011, 06:34 PM   #6
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Careful application.
Old 02-07-2011, 06:43 PM   #7
dirtconnector
erythematic nucha
dirtconnector's Avatar
Oddometer: 769
Goo Gone it for two hours or so then scrape it with a putty knife.
I'm a low brow but I rock a little know how - Red Hot Chili Peppers
dirtconnector is offline   Reply With Quote
Old 02-07-2011, 07:10 PM   #8
Sasquatch
Sasquatch's Avatar
Oddometer: 4,770
Wrenching for over 25 years. Bought one of these heads for my small air powered angle die grinder. Where was this thing for the last 25 years? Bought it off of the Matco truck for around $25, and it would be a bargain at $100. Eats right through gaskets and then buffs the surface spotless without eating into the aluminum.
Sasquatch is offline   Reply With Quote
Old 02-07-2011, 07:18 PM   #9
Low Brow OP
Inappropriate...
Low Brow's Avatar
Oddometer: 111
That looks pretty useful! What is it made out of.... rubber?
Old 02-07-2011, 07:44 PM   #10
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,663
I bought Loctite spray on dedicated gasket remover that worked good on some pretty stubborn gaskets, sometimes I had to respray a few times but was pretty painless.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 02-07-2011, 07:48 PM   #11
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,218
That's a 3M Roloc Bristle Disc.
It's made of a rubberish plasticish stuff with embedded abrasives.
It is indeed the cat's ass for removing gaskets without damaging aluminum. The only way to fly.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 02-07-2011, 07:52 PM   #12
technician172
Ich reise alleine
Oddometer: 61
plastic with ceramic aluminum oxide, I prefer yellow for aluminum.
technician172 is offline   Reply With Quote
Old 02-07-2011, 07:53 PM   #13
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,601
and a putty knife
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 02-07-2011, 07:57 PM   #14
Sasquatch
Sasquatch's Avatar
Oddometer: 4,770
I only have the green one. But it is the shiznit. Leaves gasket surfaces like new. I will never scrape again with a blade.
Old 02-07-2011, 08:10 PM   #15
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
Originally Posted by wibby View Post
and a putty knife
oh that stuff works, and damned good too!
Just DO NOT let it get on anything you don't want paint falling off of.
Ever seen that crap Easy Off Oven Cleaner.....that is what it will do to paint.
I buy more of that stuff for stripping finishes off of parts than as a gasket remover
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Times are GMT -7.   It's 06:38 PM.
