Old 12-14-2011, 04:59 PM   #76
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
It's been a while... Been riding instead of building, but I have been slowly plugging away. Then I got an offer to show the bike at the motorcycle show in Seattle and got off my butt to make it presentable. Just one more day before the show.
I'll take some more pictures at the show.
Here it is almost done! need to clear coat the tank and there are a few more little nits I need to finish.
Life is short, live and enjoy it !!!
05' BMW R1200GS - If you can only afford one bike...
06' VStrom 650 - Fond memories (gone)
06' Suzuki DRZ400 - Wish I could afford two bikes (gone)
S.O. Bikes
07' VStrom 650 ABS (Silver)
05' VStrom 650 (Red) - Sold to get one with ABS
tenorjazz is offline   Reply With Quote
Old 12-15-2011, 01:15 AM   #77
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 867
Very nice Bultaco, very nice indeed.
Just my 0,02€ opinion:
The tank optic looks very different to a Bultaco in my personal view, (big fan of Bultaco I have a Bul too).
If I would do the paint job I would put more Bultaco characteristics on it, like here:
With a one angled stripe with a pointy edge at the rear end, like some models have, the fenders and the tank
match more together or only just one or two logos, (plain version).
(The photoshopping is bad had not much time).
PSchrauber is offline   Reply With Quote
Old 12-15-2011, 05:23 AM   #78
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
A lot of effort into that one for sure. Just some comments for the OP to make the bike work for trials. You need some 50 mm wide footpegs to actually compete on these bikes. Also you need to get a Domino slo-turn throttle and cable for that bike before you compete. That cable will catch on every tree limb you get near like that. Hopefully you left the big dumbbell flywheel weight on the right side of the crank too. If not, put that back on before you ride too. That flywheel (not the Pursangs) is what makes a Sherpa T work so well. The fiberglass gas tanks are a leaking nightmare on Matadors,in fact most Buls. Try to get a 199 plastic tank for comp. Good luck and NO MARKS.
buls4evr is offline   Reply With Quote
Old 12-16-2011, 06:01 AM   #79
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
You also need a 26mm Mikuni carb with that Domino throttle Now you are pretty close...
Old 12-16-2011, 08:33 AM   #80
PSchrauber
PSchrauber's Avatar
Oddometer: 867
No Idea if you want to come near a "racing" conversion to the Matador you have, here are some very different
Sherpas and maybe some Matadors too to view at.
From very early ones up to the 199b model, which is often very nice modded,
also a good ressource for your gas tank coloring:
(199b the last Sherpa with 6 speed gearbox, 340cc, no rear frame loop and as standard with
white frame: the very competitive version, only 1,700 where made).
http://todotrial.mforos.com/65594/48...as-diferentes/
(Spanish trial forum)
Old 12-16-2011, 04:57 PM   #81
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
I understand that the throttle will be an issue so will probably swap that out but the foot pegs are stock and have been told that they won't be a problem.
I've never ridden trials before and never cared to much about competition. I do plan on riding it so figure however it goes it will be fun.
The frame has been modified and swing arm was shortened so the rake and trail are not stock. The previous owner made these changes as well as adding a couple of other little trick features, including a quick release on the seat. Most of this doesn't mean a lot to me, it just happens to be what the bike is. But since I've built this bike for a friend of mine who does compete, after I've played around on it for a season of so, we'll upgrade the parts that aren't working so good and he should have a nice competitive bike to ride.
This is the first bike I've ever built so I also wanted to experiment with finishing processes and besides I really like custom bikes more than stock. The frame, shocks, exhaust and most of the unpolished parts have been powder coated (a real learning process there). I learned how to polish aluminum and steel so it almost looks like chrome and wanted to do something different on the tank, so thought I would try pin stripping. Overall I'm pretty happy with the way it turned out, but like the second side of the tank better than the first, after figuring out a little more about how to handle the paint. I'm going to redo the tank after I get the bike back from the motorcycle show and I have an idea for something completely different, but still nowhere near to stock.
S.O. Bikes
Old 12-17-2011, 05:18 AM   #82
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
EVERYONE widens the pegs to 50mm if they are serious tenorjazz. They are also not long enuf. If you have not ridden trials don't start right out with a huge disadvantage like not being able to weight the pegs correctly. It is a big deal...trust me on this one.
Old 12-17-2011, 08:44 AM   #83
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
BTW... The tank has been sealed and the liner looks like it is well bonded. I plan on using ethanol-free gas so that should help with any gas tank problems.
If I do plan on getting real serious with riding trials, I'll put the widest allowable foot pegs I can. I've ridden enough dirt to know this is a wise decision. It's just that I'm old enough to where I have enough body pains and don't heal very fast if I get broken, so I don't think I will be a serious competitor.
Before I do anything else I need to see how well the engine runs and I can't check that out till next week, when I get it back from the show. In the end this bike goes back to Dave, the guy I built it for. I know he's itching to ride it.
I'm already thinking about the two more bikes waiting for me to build, a 1966 Suzuki Bearcat and another 1965 Bultaco Matador.
S.O. Bikes
Old 01-09-2012, 05:45 PM   #84
jdlothrop
Oddometer: 1
Bultaco Matador 1969
I am still trying to set the timing on my '69 Matador.
The prescription I am following is this:
1. Set the points through the "window" at .016 at the hi point of the cam lobe.
2. Set the timing by rotating the stator, (pulling and reinstalling of flywheel) until the light on my Bultaco box goes on indicating that the points are open at 3mm + - BTDC.
The points are now precisely gapped at .016 at the highest point of the cam lobe. Checking the light indicates that the points are opening 3 and one half revolutions of the dial too early. So lets see - that would be 100 mm per revolution x 3 plus 50 mm = 350mm. Only off by 347 mm. So I need to rotate the stator plate to back the rubbing block off the cam a distance to allow the flywheel to advance enough to not engage the rubbing block 347 mm too early - not going to happen of course.
All right - so set the points so they are opening significantly less than .016 which allows travel of the flywheel to trvael closer to TDC before the light comes on indicating that the points have opened. Now I have minimal point opening but the timing is close. Adjust the stator 1/4" - 1/2" travel to precision 3mm BTDC.
One problem as I see it is that as the rubbing block wears the point gap gets less which means I don't go very far before I need to take everything apart again and reset points because they were set so close to begin with that they are now closed completely. Do the magnets line up because the stator was rotated - I believe by looking up through the window I can see that at the exacy moment the points open the magnets need to travel 1/4" before optimally located.
Any help would be appreciated.
jdlothrop is offline   Reply With Quote
Old 01-10-2012, 09:58 AM   #85
PSchrauber
PSchrauber's Avatar
Oddometer: 867
I never have done an ignition setting by your way with calculation of the TDC, as on newer Bultaco the piston pin sits not in the center of the piston also not recommended, (they changed the piston-pin position on later Bul's to reduce the tilt effect of the ultra short hub engines for the 350cc Sherpa's).
As you wrote I also adjust at first the gap between the points. Then mount back the rotor.
Now I search the TDC, for measuring the TDC i use a gauge, like this:
Its a standard gauge with an extension pin that sits in a nylon shaft that you srew in the cylinder where the plug should be. The inner diameter of the shaft is slightly smaller as the shaft of the gauge so you can adjust the gauge to zero.
(The washer is only for rough adjustment.)
Now I mount a beeper to the ignition wiring, when it beeps I now know where the ignition point actually is, a lamp works too but you can only focus on one thing with your eyes so I like the peeper solution more.
When the timing is wrong / not in the right distance before TDC I now take off the rotor and adjust the stator new.
The beeper, (original Spanish Motoplat), or a standard Multimeter:
Then I mount the rotor back again and do a second test, when it's right it's ok if not I have to readjust the ignition again, there is sadly no better way to adjust the stator. Normally I have to do two adjustments and the ignition timing is spot on, (You have to get used to this procedure, btw. even stated in the Bultaco users manual).
When this is done I check the gap of the points again, if they are still in right spec's the job if done, if not you sadly have to do the hole procedure again, luckily this hasn't happend to me yet.
Your timing specs are very forwarded to the one's I know from my model?
Old 10-04-2012, 11:14 AM   #86
redblk63
TacoDog
Oddometer: 4
JDLothrop,
You say "Checking the light indicates that the points are opening 3 and one half revolutions of the dial too early." I interpret that as the reading on a dial indicator which has been inserted into the spark plug hole.
It looks like you may have misread your dial indicator gage. You say the timing was 350 mm BTDC, but the Bultaco engine has a 60 mm stroke! Any chance you were using an English units dial indicator gage where one revolution corresponds to 0.100"? That would make your reading 0.350", which corresponds to a believable 8.9 mm BTDC.
Larry - Pasadena
redblk63 is offline   Reply With Quote
Times are GMT -7.   It's 07:47 AM.
