Old 02-14-2011, 10:18 AM   #1
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,363
How to check a coil, Polaris help needed
Got a 2004 Polaris Sportsman 500 HO, think I have a bad coil and I'm not sure how to check it.
Can anyone tell me how?
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man screwed with this post 02-14-2011 at 02:07 PM
Fe Man is offline   Reply With Quote
Old 02-14-2011, 04:00 PM   #2
gvthnks
gvthnks's Avatar
Oddometer: 542
Specs from my FSM are as follows.
primary resistance: .3 ohms
secondary resistance: 6.3K
Primary is the resistance between the electrical connector to ground (which is a mounting tab on the coil)
secondary is between the electrical connector and spark plug cap.
If you get no reading on the secondary side, unscrew the spark plug cap and read it again. Then check to make sure the plug cap is OK by reading through it too. Some plug caps have resistors in them and they can go bad too.
hope this helps
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
wife calls it a sickness. I'm running a M/C rescue
gvthnks is offline   Reply With Quote
Old 02-14-2011, 04:06 PM   #3
Range Motorsport
Junk collector
Range Motorsport's Avatar
Oddometer: 1,652
what are your symptoms? I have never seen a bad coil on a 500 Sportsman but the ignition box was known to cause some issues on certain years but I believe that was 2005 models. The wire tends to get disconnected from the cap often as well.
I have fixed many no spark issues by simply moving the kill switch to the run position.
2007 KTM Superduke
SNL Will Ferrell Yoga, google it.
www.adventuremine.com
www.upoverland.org
Range Motorsport is offline   Reply With Quote
Old 02-14-2011, 05:35 PM   #4
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
I've got a service manual out in the garage, I'll go look in a minute. The speed limiter in reverse works by interupting the spark. I bought the very first year Sporty 500 (1996) and still have it. The engine always has sounded like a coffee can full of bolts, but still runs well.
Old 02-14-2011, 06:29 PM   #5
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
From the Poolaris FACTORY service manual: Primary winding resistance should be .3 to .5 ohm, the secondary should be 6300 ohm (+/- 10%) WITHOUT the resistor cap. The resistor plug cap should be 5000 ohms. Good luck!
Old 02-15-2011, 06:49 AM   #6
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,363
Thanks all!
The coil measurements are "within" spec; the measurements to the cap are within spec but I get no reading through the cap...
The symptom was cutting out Horribly under load. Sitting it would rev normally, put it in gear and it wouldn't move out of it's own tracks.
At first I thought was fuel delivery, contamination or carb issues. I took the carb apart, cleaned, replaced fuel filter, still a problem.
Old 02-15-2011, 06:53 AM   #7
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,363
I figured that one out years ago!
Old 02-15-2011, 09:17 AM   #8
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,260
ha ha
Sidestand switch?
(I had to)
SilkMoneyLove is offline   Reply With Quote
Old 02-15-2011, 09:45 AM   #9
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
so try rolling it over without the cap on the wire. You should get a good spark jump off the end of the plug wire
Old 02-15-2011, 09:48 AM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
troubleshooting flow chart says: disconnect the black wire at the CDI module to isolate the ignition system from the kill system.
Spark? Yes? Test the ignition switch, kill switch and speed limiter for shorts to ground. Also check terminal board for moisture or corrosion.
Old 02-15-2011, 10:22 AM   #11
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,363
I would like to buy a service manual, preferably the factory service manual but upon searching the web, you see all of these "download" houses that offer but seem to not actually have the books.
Where can I buy a copy online?
Old 02-15-2011, 11:23 AM   #12
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,363
So as I am broke I'm trying to get my shit to run by working on it myself.
Now my fucking battery appears to be dead and need replacing!
Old 02-15-2011, 12:58 PM   #13
Range Motorsport
Junk collector
Oddometer: 1,652
http://www.ohiolemonlaw.com/mll-site...is-recalls.htm
Dead battery is a sign of the ECM shorting out and draining it. Those things were scary when they went bad.
2007 KTM Superduke
www.upoverland.org
Old 02-15-2011, 01:25 PM   #14
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,363
No, just a dead battery...
I got it started; runs like shit and the exhaust pipe is smoking with the distinct smell of burning oil but nothing has been spilled on it!
Fe Man screwed with this post 02-16-2011 at 06:24 AM
Old 02-15-2011, 02:02 PM   #15
gvthnks
gvthnks's Avatar
Oddometer: 542
thought I was the only one.....
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Times are GMT -7.   It's 04:19 AM.
