Old 02-15-2011, 06:53 PM   #1
1f2frfbf OP
full-time fool
Oddometer: 42
Run... Or run faster? Airhead transmission question
I've been looking for an older airhead to fix and ride and have recently been offered a R60/7 that has, according to its owner, transmission issues.
Apparently it tends to jump out of 2nd gear intermittently. Is this a deal breaker or a pleasant garage garage fix (Ha!!!). I turn to the gurus at ADV to either get me in a lot of trouble or help keep me out.
In less than optimal circumstances,
creativity becomes all the more important.
1f2frfbf is offline   Reply With Quote
Old 02-15-2011, 06:58 PM   #2
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,583
It really depends on how much he wants for the bike. If you could get it for less than $1000 ... and replace the transmission yourself ... you come out ahead.
The R60 was not the most powerful beast out there ... but smooooooth as silk. You can get working transmissions for ~$300 to $500 for something 'garunteed'.
www.ibmwr.org
and flEbay ...
Look into this sites parts pages too ...
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 02-15-2011, 09:14 PM   #3
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,279
That would be an R60/6 I believe, since they were discontinued for the /7 line-up, when the 800 and 1,000 were the only ones available.
There's a slight possibility the transmission is fine and the current owner doesn't know how to shift it properly since a few of the gears have stepped dogs that can feel engaged when they're only part way there. But as I recall, that was in third and maybe fourth. But it could have been second and third.
So if the dogs aren't completely engaged, it can pop out of gear. Otherwise, the trans will have to come apart and they're not an easy fix for the home mechanic requiring special tools and knowledge even to just open them up.
But it is possible to get a good used trans for three to five hundred as Beater mentioned.
If you can pull the trans drain plug (be sure to not pull the engine sump plug) and check out the attached magnet, it'll tell you a lot. Just quickly remove the plug and stop the hole with your thumb. If it's got a soft fuzzy afro, you're fine; slivers and chunks, problems.
Old 02-15-2011, 10:41 PM   #4
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Actually the R60/7 was the last R60, in fact it was the only R60 to have a factory disc brake.
It was available in 1977 and some leftovers (very few) were actually sold as 78 models. Never seen a 78, but have had the fact corroborated by a reputable source.
So, the big question to the O.P. is: Does it have a disc brake or not?
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 02-15-2011, 11:41 PM   #5
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 800
Sounds like a fun little scoot. I'm unemployed right now, so I have time to investigate that bike if you can drive.
baldwithglasses is offline   Reply With Quote
Old 02-16-2011, 05:22 AM   #6
bmwrench
Oddometer: 2,355
Jumping out of 2nd is unusual for a 5-speed. I'd want to hear it run and ride it to assess the general condition of the 'box. Since 2nd is on the output shaft, if it needs that gear, it's a relatively inexpensive repair.
bmwrench is offline   Reply With Quote
Old 02-16-2011, 06:13 AM   #7
1f2frfbf OP
full-time fool
Oddometer: 42
To add to the confusion, I actually haven't seen the bike yet, I've only been told that it's a /7 with transmission issues and the owner is a stand up guy, even if he does have a thing for Fiats, so I'm pretty sure it is what he says it is. I'll ask about the disc brake and will report back more when I know it. thanks for the pointers, guys.
Old 02-16-2011, 06:23 AM   #8
norton73
drinkin'
norton73's Avatar
Oddometer: 8,324
had one pass through my hands many years ago. A friend swapped the top end for a R100 topend, but left R60 markings on it, street sleeper
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 02-16-2011, 09:28 AM   #9
supershaft
because I can
Oddometer: 9,116
If it needs second gear more than likely it needs fourth gear as well. I think the male dogs for second are on fourth. I have seen the shaft itself worn down enough to cause shifting issues too. That and sloppy bearings can be part of it. It can sometimes add up pretty fast.
Old 02-16-2011, 11:44 AM   #10
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Had a 78 R100 that jumped violently out of second, replaced 2cnd and I think fourth and it's fine now.
www.wirewerkes.com
Old 02-16-2011, 11:47 AM   #11
supershaft
because I can
Oddometer: 9,116
That's what I am a sayin. When it comes to popping out of gear. One gear is rarely going to fix it.
Plus, those dogs get worn more than any other as far as I can tell.
Old 02-16-2011, 12:12 PM   #12
sigpe57
Oddometer: 348
There are many used and good transmission for sale for few hundred dollars on ebay. Just replace it. It's not worth to rebuild the transmission.
sigpe57 is offline   Reply With Quote
Old 02-16-2011, 01:18 PM   #13
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
Paying a shop like $80/hour and having them clean and replace everything, a rebuild cost me $700. I know I have a good transmission. Some people do them for $600; maybe less. If you can do it yourself.. even cheaper. Probably a couple hundred.
I haven't seen many transmissions go for less than $500 on ebay. That's not worth the risk of some strangers word that "yeah, it works good!" when you could just have yours rebuilt.
IBMWR may be a better (ie cheaper) choice if you can sift through the scammer emails.
crazydrummerdude is offline   Reply With Quote
Old 02-16-2011, 01:21 PM   #14
The Raven
The Raven's Avatar
Oddometer: 4,811
+1 on CCD.
Anton Largadier told me that most trans leave the shop for about $600. Some more, some less. In the end you have a new trans that will go another 100k+
The Raven is offline   Reply With Quote
Old 02-20-2011, 05:01 PM   #15
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,651
Ooh, here's one:
http://cgi.ebay.com/ebaymotors/1975-...Q5fAccessories
Times are GMT -7.   It's 03:40 AM.
