Old 04-08-2013, 03:58 AM   #736
Bryster
Bryster's Avatar
Oddometer: 97
Laugh
Originally Posted by shizzle View Post
Bought a used 2012 F800R this Wednesday. Registered it on Thursday and put a whooping 1000km on it the last two days. Awesome ride, just way too cold at about 0 degree centigrade.
Reds' really nice! Congrats.. Now... farkling
'12 Crosstourer
Bryster is offline   Reply With Quote
Old 05-06-2013, 04:52 PM   #737
flkovacs
flkovacs's Avatar
Oddometer: 191
hey nice color combo - great choice!
enjoy,
ferenc
ps it's at home out in the west:
http://s1078.photobucket.com/user/fl...d4426.jpg.html
flkovacs screwed with this post 05-06-2013 at 05:24 PM
flkovacs is offline   Reply With Quote
Old 05-06-2013, 05:19 PM   #738
flkovacs
flkovacs's Avatar
Oddometer: 191
what's missing in this photo?
the one casualty of my recent road trip:
http://s1078.photobucket.com/user/fl...ed418.jpg.html
so, what is the missing piece (note that the tie wrap held for 2k miles home ...
ferenc
Old 05-07-2013, 02:31 AM   #739
Bryster
Bryster's Avatar
Oddometer: 97
Question
ferenc
There' no bolt in that panel, it's like a rubber locater where you've got the cable tie.. The bolt hole in front of it's bare on mine as well, think it's for something else, maybe carried across from the ST, or the original R's design.
'12 Crosstourer
Old 05-07-2013, 10:46 PM   #740
ADVBMR
Polygamotorcyclist
ADVBMR's Avatar
Oddometer: 892
GF diggin' the 800R
Spring has finally arrived! A little trip through the two mile tunnel to Whittier for the annual opening of the Sweetwater Café for fresh striped shrimp, halibut and cod. An avalanche cut loose in front of us shortly after this pic.
IBA #47244
2007 R1200GS; 2006 DL650 V-Strom; 2011 F800R (sold); 2013 CRF250L (sold); 1995 R1100GS (sold); 2006 Ducati Multistrada 620 dark (sold); 2013 F800GS (woot!)
ADVBMR is offline   Reply With Quote
Old 05-08-2013, 04:28 PM   #741
flkovacs
flkovacs's Avatar
Oddometer: 191
does it seem that much sweeter, having a relatively short riding season?
enjoy,
ferenc
Old 05-16-2013, 10:48 PM   #742
ADVBMR
Polygamotorcyclist
ADVBMR's Avatar
Oddometer: 892
enjoy,
ferenc
No, it totally sucks. We rode north last weekend and had a good time riding into Denali National Park before the season starts and the park opens, but this weekend it's a no-go. Snow predicted Saturday which means even if it's not sticking in town, the passes are fooked. This is a really late spring, not unlike the upper Midwest and the West, but our summers yield only a day or two of 70 degree weather.
But I did put a PR3 on the front to make things better and it is a good improvement. I'd like to know more about the Dunlop DT616 which came out this year and fits this bike. Looks like a Metzler Tourance sort of. Anybody try this tire?
IBA #47244
Old 05-21-2013, 10:07 AM   #743
flkovacs
flkovacs's Avatar
Oddometer: 191
Sorry to hear that. We are spoiled in California, except for the lack of ideal road conditions and some traffic.
Perhaps you should come down to the lower 48 ... for a change of scenery and centigrades.
Conversely, friends from here keep dreaming about riding up through Alaska - a friend of mine is even trying to talk me into riding pole to pole - or at least from the Artic Circle down to Tierra del Fuego.
Enjoy it while you can,
Ferenc
Old 05-22-2013, 08:07 PM   #744
flkovacs
flkovacs's Avatar
Oddometer: 191
6k mile service?
ii am about due for the 6k mile service and a local dealer says that they also check the valve clearances, since they open up the engine, but, do they need to?
here is what i understand is on the to-do list at 6K:
Performing vehicle test with BMW Motorrad diagnostic system
11 00 611 Oil change, engine, with filter
Checking coolant level
Checking/adjusting clutch play
Checking freedom of movement of throttle cable and checking for kinks and chafing
Checking front brake pads and brake discs for wear
Checking rear brake pads and brake disc for wear
Visual inspection of the brake pipes, brake hoses and connections
Check tyre pressures and tread depth
Checking and lubricating chain drive
34 00 504 Change brake fluid in entire system
Checking steering-head bearing
Checking ease of movement of side stand Checking lights and signalling equipment Function test,
engine start suppression
Final inspection and check of roadworthiness
Setting service-due date and service countdown distance
Next service due on 5/7/2014
or in 6.220 Miles
Odometer reading 12.230 Miles
Checking battery charge state
Confirming BMW Service in on-board documentation
Old 05-28-2013, 11:26 AM   #745
eljaye925
eljaye925's Avatar
Oddometer: 51
Does anyone know which direction the left outside wheel spacer (#9 in the picture) fits?
There is a small lip on one side of the spacer which I'm assuming is the outside...but it will fit either way.
L.J.
eljaye925 is offline   Reply With Quote
Old 05-29-2013, 06:57 AM   #746
flkovacs
flkovacs's Avatar
Oddometer: 191
L.J.
hey, to answer your question, i really don't know, but having just replaced the rear tyre, followed my intuition and put it so that the smaller diameter fit better on the inside, as perhaps a guide. perhaps someone out there really knows, though ...
enjoy, and ride safe,
ferenc
flkovacs screwed with this post 05-29-2013 at 09:02 PM
Old 05-29-2013, 01:40 PM   #747
eljaye925
eljaye925's Avatar
Oddometer: 51
hey, to answer your question, i really don't know, but having just replaced the rear tyre, followed my intuition and put it so that the smaller diameter fit better on the inside, as perhaps a guide. perhaps someone out there really knows, though ...enjoy, and ride safe,
ferenc
Thanks for the reply. When I took my wheel off, the spacer had the shoulder on the inside. My intuition, like yours, told me that the shoulder belongs on the outside...hence my post. I was thinking perhaps I had inadvertently reversed it previously.
I decided to call my local BMW service departments and so far I have received contrary info. The first dealership referenced their repair manual and told me the shoulder belongs on the inside...the other dealer referencing a parts fiche told me the opposite...I guess i'll make a couple more calls
FFR I found a better picture. Looks like the shoulder belongs on the inside.
eljaye925 screwed with this post 05-29-2013 at 02:08 PM Reason: more info
Old 05-29-2013, 09:05 PM   #748
flkovacs
flkovacs's Avatar
Oddometer: 191
great - photo looks correct. hard to find a reliable source for information these days - local dealer i trusted had another turnover ...
enjoy,
ferenc
ps service manual on my other (put together and running :-) bike also has a similar spacer in the final drive assy. backwards ...
Old 06-17-2013, 04:43 PM   #749
ontrip
ontrip's Avatar
Oddometer: 66
New F800R owner
Hello from Toronto, hopefully, should have my new to me F8R in a few days, 2011 Alpine White. Have been riding an FZ1 for 60 000 kms and looking forwrad to it.
ontrip screwed with this post 06-17-2013 at 04:51 PM
ontrip is offline   Reply With Quote
Old 06-18-2013, 01:21 AM   #750
Bryster
Bryster's Avatar
Oddometer: 97
Question
Welcome to the fray... <- see, emoticon looks like headlights!
What made you switch from a 4 to the 800R?
'12 Crosstourer
Times are GMT -7.   It's 08:57 PM.
