Old 02-19-2011, 08:15 PM   #16
fishkens
Further...
Oddometer: 5,149
Originally Posted by One Less Harley View Post
Maybe I should give the crimp a couple more whacks with a hammer. I've noticed on a couple of the leaking switches that the plastic body rotates in the Al housing. Might be worth a shot, might tighten up the o-ring seal in the body. I'll take one of the bad ones apart to see how it's put together.
I heart science. There's got to be a solution. Maybe.
There's a switch encapsulated in some plasticy stuff that is supposed to seal against the housing. Grind out the existing plastic and replace it with a wonder substance that withstands heat and vibration.
I have a dream that you'll solve this conundrum.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 02-19-2011, 09:40 PM   #17
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,893
DOnt even grind it. Epoxy the entire outside, or dip it in tool dip or something (minus the leads, of course) It doesnt leak through the threads but through the thing itself right?
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 02-19-2011, 09:47 PM   #18
fishkens
Further...
Oddometer: 5,149
Right. So the question is how to seal the inside of the housing that screws into the tranny and the leads, etc. coming out of the center of that housing. There's got to be a solution to this problem.
Old 02-20-2011, 05:58 AM   #19
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,210
It is just a simple on/off switch after all. Perhaps someone could machine a plug with a seal for a little shaft. Then mount a standard mini switch to that. Make it so it's possible to remove without pulling the trans or that cross tube.
After all that, it's gotta be super simple or it'd cost more than the original.
Old 02-20-2011, 09:56 AM   #20
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,755
here's a picture of the nasty beast.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-20-2011, 10:07 AM   #21
fishkens
Further...
Oddometer: 5,149
Nice dissection and pics.
Let's hope that the epoxy cap works.
Old 02-20-2011, 10:08 AM   #22
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Has anyone tried epoxying a new one, BEFORE it gets oiled?
I'm only asking cuz I bought one last year and it's still in the bag.
The epoxy in the link looks pretty bullet proof. And yes, In my opinion that switch is poorly designed and could have fared much better with an o-ring.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 02-20-2011, 10:14 AM   #23
fishkens
Further...
Oddometer: 5,149
The crazy thing is that the oil pressure sender seems to do fine and it's under 15 - 78 psi all the time. Granted, it's a different design but the neutral switch never sees that kind of pressure.
Old 02-20-2011, 10:27 AM   #24
The Raven
The Raven's Avatar
Oddometer: 4,811
The problem with epoxy is that the stuff I have used is not flexible and subject to cracking. We need something like adhesive oil proof silicone
The Raven is offline   Reply With Quote
Old 02-20-2011, 11:14 AM   #25
Wirespokes
Wirespokes's Avatar
Oddometer: 8,210
How about this
Do like OLHarley and cut the crimp off, then cut threads half way down the flats. Make a custom nut to hold the guts instead of the crimp. That way it would be rebuildable with a new o-ring once it starts leaking. And it might just be possible to assemble without removing the cross tube.
Good idea???
Old 02-20-2011, 01:00 PM   #26
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
You can replace them quite easy without pulling the transmission out Someone post a picture of one installed also showing the drain plug area on the motor and I'll write up a How To.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 02-20-2011, 01:21 PM   #27
The Raven
The Raven's Avatar
Oddometer: 4,811
Don't have a photo right now, but I think we all know what that area looks like. Do tell
Old 02-20-2011, 01:49 PM   #28
Boxer Metal
Mad Scientist
Oddometer: 3,521
I'll see if I can explain this so it makes some sort of sence.
1.Bike on the center stand.
2. with a small block of wood and a small jack support the back of the motor at the oil pan.
3. Remove the rear engine through bolt that goes through both sides of the frame.
4. When you look under the transmission and above the oil pan you will see an aluminum tube that the engine through bolt went through. With a small pry bar remove the tube.
This will allow you to get a wrench on the switch.
5. When you replace the switch make sure the thick aluminum spacer/washer is in good shape. As well as spacing the plunger in the switch it is also an oil seal.
6. Re-install the spacer. If it fights you going back in take a file and lightly bevel the edges on it. Once you get it back in fairly close you can use the engine through bolt to center it.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 02-20-2011, 02:07 PM   #29
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
+1 super easy to replace now. The key is getting a good bevel on the spacer so she goes home when you're tired
Old 02-20-2011, 02:27 PM   #30
Harry Backer
Ran when parked!
Harry Backer's Avatar
Oddometer: 373
Mine still has the original one in it, but I broke off a tab puting the trany back in. So I should just leave it since it doesn't leak now?
Motorcycle = Mind eraser
78 R100/7 / 70 CL350 / 71 CB350
94 Duc 900ss / 63 Suzuki 80 K10
Harry Backer is offline   Reply With Quote
Times are GMT -7.   It's 03:07 AM.
