Old 06-19-2011, 06:00 PM   #181
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
Originally Posted by Nitro Circus View Post
John, in that last pick the bike does look somehow more balanced. I'm interested to know what were the reasons for changing the shock mount. Was it just the swing arm level, or are we talking a combination like that and shock angle under compression? Chassis pitch?
It's looking better everyday, and I bet it feels that way too.
I was trying to get the swingarm angle in reason, and to get the shock angle in a more reasonable position. being able to touch the ground didn't hurt any either With it setup like the above I have 10" of travel If I move it back to the last position I gain 3/16" more travel and lower the rear of the bike 1/2" Right now I am sitting at 63.25" wheel base. This is a gravel sled that does feel very solid and hooks up extremely well.
The rear shock spring is still too stiff so I need to get a different spring to get a better feel, right now it doesn't use much travel at all and I only get about 2.25" rider sag. the front fork springs seem good, but we are working on damping rates for them. It may take a while as there really isn't anything in production much like this and I am pretty picky.
johnwesley is offline   Reply With Quote
Old 06-19-2011, 06:04 PM   #182
lesman
Live easy, Brake Hard
lesman's Avatar
Oddometer: 703
You were able to weld the new mounts with the swingarm on the bike?
The bike is just beautiful. What was the total cost of your swingarm mods?
Are you still working on the under fender gas tank?Are you totally satisfied with the length of your Ohlins?
Les
Obsessive compulsiveness always trumps good sense.
lesman is offline   Reply With Quote
Old 06-19-2011, 06:14 PM   #183
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
Les
I took the arm off and give it to a pro welder, Rick machined the brackets. I really hate to say on the arm money as I have been given a "deal" on it all the way around as people have been keen on the idea of a harley adv bike.
the tank is done.
I like the Ohlins shocks and the length works out very well, I will say that if you use the mounts like I started with you will not get the swingarm angle workable unless you go shorter and end up with like 7-8" of travel and even then it will be questionable. My shocks are 17.5" long so you'll need to try and stay 16" or less and about 5" stroke maybe less. I have the shortest shock I could get with the most travel.
Old 06-20-2011, 06:37 AM   #184
JimmyTheHog
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 741
That looks like a good angle on the swingarm ! - Looks good.
When you get the different sprockets, the chain should have minimal contact on the chain slider. Looking forward to seeing that.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 06-20-2011, 06:44 AM   #185
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
yea me too! right now with minimal rider sag it doesn't touch under power but does on coast.
before Motocd
after Rick worked his magic
Old 06-20-2011, 12:01 PM   #186
malibu_dan
Adventuring Mystic
malibu_dan's Avatar
Oddometer: 1,580
Now THAT looks like a Sportinator ADV bike to take to the ends of the earth! "Well done" to Rick!
Follow me over here >>> WRRDualSport.com <<<
| Smokies are always on the way Ride Report
malibu_dan is offline   Reply With Quote
Old 06-21-2011, 12:36 AM   #187
raoulserban
vrrummm
raoulserban's Avatar
Oddometer: 100
nice! but for my knowledge...is that swing arm a little bit to thin for the forces that appear on an off road bike
raoulserban is offline   Reply With Quote
Old 06-21-2011, 05:03 AM   #188
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
Thumb
Plenty strong at 3/16" thick and triangulated. Plus you can see the plates that reinforce the stressed area of the arm
Old 06-22-2011, 03:24 PM   #189
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
Thumb
took it for a bit of a ride, trail and dirt road, she is working well flys good lands well. The rear shocks are very nicely vavled and with a spring change will be spot on. Front forks are going good still need to tweak them a bit. Through turns is does good, for hard charging you need to be on the gas to keep the front from tucking. So I still have a little front to rear ride heigth tuning to do.
It gets good traction and the low end tq hits hard when playing on the gravel very fun
Old 06-23-2011, 06:33 AM   #190
JimmyTheHog
Oddometer: 741
Did you ever install the hydraulic clutch lever ? If so, how do you like it ?
The cable clutch on these is a tough pull !
Jim
Old 06-23-2011, 08:31 AM   #191
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
I like the cluch and it does give a light feel. Works as advertised
Old 06-24-2011, 02:27 PM   #192
Quin
Oddometer: 49
Don't mean to hijack your thread but do you have any details about this bike. Would like to do something similiar to my Nightster
Quin is offline   Reply With Quote
Old 06-24-2011, 02:50 PM   #193
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
I don't right off hand but he is a member here. With the details on a thread. Pretty easy buildThat has proved to be a success and handle well.
Edit: members name is rusty spuds
johnwesley screwed with this post 06-24-2011 at 03:03 PM
Old 07-05-2011, 08:33 AM   #194
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
Thumb
I have had it on deals gap and 800 miles of intersate running as well as some dyno time. All in all it working out well and will be the bike I get to take to AK
like a dummy i had my iphone held side ways so the vid is sideways, but it will get you some sound the tires are louder than the exhaust
the dyno numbers are a little low for what I have, that said the d606 tires are most likley the reason, but I am happy with the results as I have 60 lb ft of tq all the way to 5200 rpm and peak tq of 65 is held for 2000 rpms. this translates to instant power in any gear with 2000 rpms. the tq on this bike is very fun on the gravel. when running at a constant 80 mph i get 50 mpg so I am very happy with it.
I now have the bages set up on it and working very well
when I was a kid i played with transformers, still like the movies so When I was working on the exhaust side I have it set up to convert to trail duties with just a change in parts. for trail work the exhaust is like seen in the pics, when touring it mounts under the pannier.
Old 07-09-2011, 02:00 PM   #195
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
packed and ready for Ak
Times are GMT -7.   It's 09:49 AM.
