Old 03-14-2011, 05:44 PM   #76
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,839
update: different vendor
HAMSAR LIGHTING
http://www.hamsar.com/Content/EN/Pro...tType=Lighting
An offroad racing group was touting this mfg - MADE IN CANADA
90mm Low Beam projector
in case you were wondering, the 640a uses 90mm lamps so these might be direct replacements BUT this lamp uses less than ONE AMP.
DOT approved. They also pimp other lamps such as HIDs in the 90mm housing:
Interestingly they don't offer a high beam HID; all their high beams are halogen (H9s). Anyone know why?
Just another alternative.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-14-2011, 11:37 PM   #77
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,013
Send a message via Skype™ to Low594
HMMMMM! One of the tabs on my Low beam is broken, this could be just the fix! LED even! Ouch $399 for 1 LED low beam!
I did buy a pair of the ADVMonster aux LED lights, oh my god bright and there are new models, even brighter just released!
'99 KTM 640 Adventure R
East Bay Weekly Coffee
Support your local creep! CREEPS MC
Low594 screwed with this post 03-15-2011 at 05:08 AM
Low594 is offline   Reply With Quote
Old 03-15-2011, 06:17 AM   #78
meat popsicle
Ignostic
Oddometer: 13,839
Yeah, good lamps are not cheap; the stock ZKWs are... well let me look... hey, less that $200 from Munn Racing. So you would pay a premium for an LED low beam.
It uses about 1A, and the halogens are using 4-5 amps (out of 9-14A available from the charging system). The only good reasons I can see are (a) if you really needed amps for something else (heated gear, etc.) or (b) you'd like to not change a bulb for some time (as the LEDs last alot longer than halogens or HID capsules).
Old 03-15-2011, 08:04 PM   #79
bmwktmbill
Traveler
Oddometer: 4,002
Originally Posted by wrk2surf View Post
Dont just use the high ... thats all I have on my faring setup until I get a 90mm flood and without a flood, sharp mtn cornering sucks bad... its ok on straight roads but man do I have a hard time between that and the reflection without the dash cover ... I had to put a temporary visor made of a plastic jug the top 3/4of light (think baseball cap) to keep it from flashing up the faring
W2S,
Are you running both hi and lo beams together?
Been using that system down here in C. America on the hell for curvey roads with switchbacks from hell. Seems to work pretty good for me. I have 35W HIDs on both sides.
Heck of a lot of light with both fired up and no dead time shifting beams going from low to hi. Run 1 on lo, 2 on hi, 2 into the corners.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 08-02-2011, 06:16 AM   #80
IamTRooPeR
TRooPER from Belgium
IamTRooPeR's Avatar
Oddometer: 106
I am going to try one of these
http://www.adventure-spec.com/shop/i...ewCat&catId=79
you can have them in 2 different lenses
bought one 2ndhand for 50euro, good to try one
IamTRooPeR is offline   Reply With Quote
Old 08-06-2011, 02:34 PM   #81
bmwktmbill
Traveler
Oddometer: 4,002
Originally Posted by bmwktmbill View Post
W2S,
Been using that system down here in C. America on the hell for curvy roads with switchbacks from hell. Seems to work pretty good for me. I have 35W HIDs on both sides.
bill
Just rode from Wisconsin to Northern Idaho, 1700 miles, then around 500 miles off road in Idaho, gravel and dirt...rough going at times.
Chinese HID continue to perform very well.
I continue to believe they are the best bang for the buck.
Tough install with dual relays and ballasts, plus re switching and wiring so that the standard switches activate the relays but well worth the effort.
So far they are indestructible using the stock lighting capsules.
bill
Bill Shockley
Old 08-06-2011, 07:01 PM   #82
SCsurfer
surfing explorer
Oddometer: 171
bill
Hey Bill ,
Where did you get your HID's from ? I did the Eastern Beaver upgrade a couple of years ago and it was a big improvement , but I am still wanting more light .
Paul
'07 640 Adventure
SCsurfer is offline   Reply With Quote
Old 08-08-2011, 10:34 PM   #83
bmwktmbill
Traveler
Oddometer: 4,002
Originally Posted by SCsurfer View Post
Hey Bill ,
Paul
Paul,
I am traveling and am in the boonies.
Do an advanced search on my name, the company is listed in my old posts.
Several have used it successfully.
There are several long threads.
bill
Bill Shockley
Old 06-24-2012, 04:35 PM   #84
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,013
Has anyone tried to split open the Low Beam housing??
I picked up one of these
Morimoto Bi-Zenon Projectors from a craigslist ad, thinking it would be a direct swap. But its not, I need to open the stock housing, remove the projector guts and swap the new one in. This should give me a better light profile, from what I have read, and also a Hi & Low beam in one housing!
There seems to be 3 pieces to the factory housing, a plastic projector lens holder, a plastic spacer and a metal cone, with silicone sealer between the pieces. I removed as much of the silicone between the metal cone and the plastic space, but still doesn't want to separate!
Anyone have any first hand advice? Or a spare housing, just in case I really screw it up?
Old 06-24-2012, 04:45 PM   #85
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,013
Here's the comparison, you'll see that the bulb and projector lens is open to the elements, not great for our bikes and how they get used! The lip at the widest point is where I removed the silicone from. I really don't want to break out the Dremel tool, but it's looking like that is the course of action I need to take!
Top view, throws things off. The 2 projector lenses are actually the same size.
Old 06-25-2012, 01:58 PM   #86
meat popsicle
Ignostic
Oddometer: 13,839
I guess you don't have a DOT stamp, but at least the projector is designed for the HID element and should work better than stuffing a HID capsule in the stock halogen lens.
Old 01-02-2013, 11:02 AM   #87
cahtty
cahtty's Avatar
Oddometer: 2
Eh?
Anyone tried out these Hamsar (led) products? Couldn't find much on the net on they products, which isn't the best recommendation to any product...
Currently they seem to have also high beam on led for 90mm (71079), which is more interesting based on my past experiences with HID lights on motorbikes. HID and high beam don't really work well together as it takes way too long to brighten up, if it has been switched off due to upcoming traffic for a while. As we know, in the most (?) cars they use this moving shutter, hence there is no delay when swicthing on and off. But as we also know, thumbers are not the optimal companion for such a delicate instrument.
Obviously their low beam led would also match my need quite nicely, just trying to find low cost solution, and then low beam HID (aftermarket) + high beam LED combo might be reasonable option.
-cahtty-
cahtty is offline   Reply With Quote
Old 01-02-2013, 04:44 PM   #88
dnrobertson
Big Bike, Slow Rider
Oddometer: 491
-cahtty-
A lot here just wire the high and low beam to work together, that removes the problem of losing light as you go from high/low. If you replace the std 55W globes with 35W HID, you are only using 15-20W more running both together.
I got a bit more fancy and fitted 2 x 35W HID and a 6xLED light bar and then found I liked the LED more, so rewired so I can run:
Just the HID low or
the LOW HID and LED "high" OR
the LOW HID and LED "high" and the HIGH HID.
It's amazing what you can do with a few diodes and relays.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 01-02-2013, 10:52 PM   #89
bmwktmbill
Traveler
Oddometer: 4,002
David,
How about some pictures?
Sounds like a cool system.
bill
Bill Shockley
Old 01-03-2013, 03:26 AM   #90
dnrobertson
Oddometer: 491
David,
bill
Bill,
I'll get some details together.
The wiring will take me some time to figure out. It all made sense when I put it together, but now ???
David
2005 KTM 640A
2008 Wee-Strom
Times are GMT -7.   It's 10:52 AM.
