Old 01-04-2013, 06:10 AM   #91
cahtty
cahtty's Avatar
Oddometer: 2
Originally Posted by dnrobertson View Post
A lot here just wire the high and low beam to work together, that removes the problem of losing light as you go from high/low.
Yep, you are correct, then you at least have low running while high is still warming up. Even though, at least I found it a bit annoying in my previous bike (BMW12GSA) to wait the high to fully start up after it been switched off for a while. It could have been just a slow bulb or similar. Or just me expecting too much...
I got a bit more fancy and fitted 2 x 35W HID and a 6xLED light bar and then found I liked the LED more, so rewired so I can run:
Just the HID low or
the LOW HID and LED "high" OR
the LOW HID and LED "high" and the HIGH HID.
Cool and interesting combo. Even though I was initially looking for a solution where I could replace OEM elements without adding more components, this might be even more tempting modification
Which LED bar you've installed?
cahtty is offline   Reply With Quote
Old 01-04-2013, 10:53 AM   #92
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
I just went out on a limb and bought H1 led bulbs off Amazon, $8 shipped for 2. Didnt work out as the "bulb" portion is bigger than the opening in the housing!
I have been using the ADVMonster led aux lights for 2 yrs?! With great luck, cant even tell my headlight is on when I'm running my 450 lumen, then I turn the 3600 lumen on and roosters crow a mile away, thinking its dawn!
Low594 is offline   Reply With Quote
Old 01-04-2013, 08:06 PM   #93
bmwktmbill
Traveler
Oddometer: 5,218
Low, I thought we had to make a small mod to get the bulbs in?
Anybody?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 01-04-2013, 08:12 PM   #94
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,025
Bill- I spent 10 seconds on the bulb hole with a suitably sized sanding drum on a dremel tool for each housing.
Shop air was used to blow out each housing once the fit was confirmed.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 01-04-2013, 08:37 PM   #95
bmwktmbill
Traveler
Oddometer: 5,218
Dirty
Did the same myself now that you say it, easy, no problems since.
I carry a spare bulb but have never needed it.
bill
Bill Shockley
Old 01-04-2013, 09:07 PM   #96
dirty_sanchez
Dirty_Sanchez
Oddometer: 3,025
I haven't looked at the parts fiche in a good while, but I'd swear the bike uses H-4 bulbs.
But I've been wrong on seven different occasions just today alone.
Dirty
Old 01-04-2013, 09:23 PM   #97
bisbonian
bisbonian's Avatar
Oddometer: 1,055
Dirty
H1 bulbs.
But Low594 is talking about an LED replacement, not HID.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 01-05-2013, 05:52 AM   #98
dirty_sanchez
Dirty_Sanchez
Oddometer: 3,025
Originally Posted by bisbonian View Post
H1 bulbs.
Cha Ching!
Personal Record.
That makes eight times I was wrong in just one day
Dirty
Old 01-05-2013, 09:14 AM   #99
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Anybody?
bill
Hmm! Now that you say that, I remember reading something about that! I will have to look into that, maybe my puchase wasnt a loss after all!
H1 bulbs.
Yes, LED, not HID!
Old 01-05-2013, 09:16 AM   #100
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Dirty
H4s are dual filament and there are a ton of brands, designs, etc. They have to be the most widely used bulb. Would have been nice to have the dual filament and more options!
On another note, I am collecting the needed parts to do away with my Hi beam and replace it with my ADVMonster Spot and will probably just continue to run it full time. Should look real interesting with the 50mm spot. Still considering an attempt to put the Hi/low module inside the ZKW housing.
Low594 screwed with this post 01-05-2013 at 09:39 AM
Old 01-05-2013, 10:42 AM   #101
Droptarotter
Oddometer: 1,301
I could put these up for sale if anyone is interested..........
The pods were mounted on my 640, but I did not want them, and the kit was purchased for the 640 by the PO, but mine does not have dual lights any more.
Hope this doesn't get me in trouble for posting this, but since we are on the subject.....shoot me a pm if interested.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 01-06-2013, 05:57 AM   #102
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
What projectors are the HID capsules installed in?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 01-07-2013, 10:27 PM   #103
Droptarotter
Oddometer: 1,301
The kit is a Martin Fabrications HID kit.
Cheers
Old 11-03-2013, 05:38 AM   #104
alsaasla
Oddometer: 15
so there arent any LED bulbs to replace the h7 halogen ones on the low beam ?
alsaasla is offline   Reply With Quote
Old 11-03-2013, 07:18 AM   #105
meat popsicle
Ignostic
Oddometer: 14,260
Not sure about the 690s, but the 640s had H1 capsules (at least the last half of their century).
I have not heard about a LED "bulb" that would fit any halogen fixture. LEDs have electronics with them (different animal).
Also, just like HID capsules they have a different light "shape", so the halogen projector (reflective surfaces in the lamp that are designed to make a low or high light beam from the bulb) will not work well with other light types, at least according to the DOT.
There are LED fixtures
http://www.hamsar.com/content/en/pro...-lighting/cifo
PART # 71075
PART # 71079
Times are GMT -7.   It's 11:44 PM.
