Old 02-21-2011, 06:09 AM   #31
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 02-21-2011, 01:27 PM   #32
John Steed OP
Too cheap to buy one
John Steed's Avatar
Oddometer: 223
I disconnected the wires of the rear light, unbolted it, and off it went, along with the tail....
------Work in Progress------
Rebuilding an SRX 400, as to be my first bike!!
http://www.advrider.com/forums/showthread.php?t=661797
John Steed screwed with this post 02-22-2011 at 02:30 AM
John Steed is offline   Reply With Quote
Old 02-21-2011, 01:28 PM   #33
John Steed OP
John Steed's Avatar
Oddometer: 223
Old 02-21-2011, 01:29 PM   #34
John Steed OP
John Steed's Avatar
Oddometer: 223
...And now the bike looks something like this....
Old 02-21-2011, 01:36 PM   #35
John Steed OP
John Steed's Avatar
Oddometer: 223
As I have already said, I know nothing about fixing bikes.
So I had to come up with a clever plan so I could re-build the bike without any part or bolt missing...
The first thing is taking photographs! A lot of them!
The next and most important is the method that you will see now.
First, I write a small label with the place of the part I just removed
(e.g. here I write: "The two bolts that bolt the tank underneath the seat")
Old 02-21-2011, 01:38 PM   #36
John Steed OP
John Steed's Avatar
Oddometer: 223
After that, I cut a small piece of transparent food wrapping....
Old 02-21-2011, 01:39 PM   #37
John Steed OP
John Steed's Avatar
Oddometer: 223
I wrap the bolts with the note.....
Old 02-21-2011, 01:40 PM   #38
John Steed OP
John Steed's Avatar
Oddometer: 223
And into the bag!!!!
Old 02-22-2011, 03:38 AM   #39
John Steed OP
John Steed's Avatar
Oddometer: 223
For the cables and the small hoses, i stick small labels with a mini-description of it's place or it's use...
On the cable connections I use numbers, the same number on both ends...
Old 02-22-2011, 03:39 AM   #40
John Steed OP
John Steed's Avatar
Oddometer: 223
Old 02-22-2011, 03:41 AM   #41
John Steed OP
John Steed's Avatar
Oddometer: 223
After dealing with the connections, I removed this thingy-dingy from the side....
Old 02-22-2011, 03:42 AM   #42
John Steed OP
John Steed's Avatar
Oddometer: 223
Old 02-22-2011, 03:48 AM   #43
komatias
Oddometer: 324
Kaimene mou file.....exeis na peraseis polles bradies sto garage, euxomai h gunaika sou na exei upomonh.
Kalh epituxeia
komatias is offline   Reply With Quote
Old 02-22-2011, 03:51 AM   #44
John Steed OP
John Steed's Avatar
Oddometer: 223
Removed the air filter cap and....
...uuummm....
.....nothing inside.....
Old 02-22-2011, 03:56 AM   #45
John Steed OP
John Steed's Avatar
Oddometer: 223
Next was the tank!
It gave me a hard time until I figured it out.
Underneath has a small valve, you can close the flow from there.
Some fluid managed to run out, but it didn't smell like gas...
Closed the gas flow valve and removed the small lines...
Times are GMT -7.   It's 09:43 AM.
