Old 02-23-2011, 06:23 PM   #76
rodsram
rodsram's Avatar
Oddometer: 337
john steed ,
you have your hands full, good for you. I really enjoy reading this type of adventure.
This bike will be a bike you will keep for a very long time. There is nothing quite as rewarding as the first time she fires up and takes you for a ride.
All the best and good luck.
Rod.
'07 R 1200 GS.
'96 KLX 650 R.
Keep It Real!
rodsram is offline   Reply With Quote
Old 02-23-2011, 07:13 PM   #77
KaceCoyote
Pass the queer more beer
KaceCoyote's Avatar
Oddometer: 5,614
Send a message via AIM to KaceCoyote
Wish you the very best of luck!
Two things I would highly suggest looking for?
PB blaster, its a penetrating oil. It will help loosen up rusted bolts to keep them from breaking off.
and
Pinesol. The same stuff you use to clean around the house, or any other pine oil cleaner knockoff. It cleans metal parts very very well when soaked. Some people here have used it with incredible succcess for things like stripped carbs, heads, ect ect.
When the smoke clear, you can see the sky again
There will be the chopped off heads of leviathan
My friend, they call 'em strangers
Everybody talk to them end up in some danger
-MF Doom, Strange ways
KaceCoyote is offline   Reply With Quote
Old 02-24-2011, 04:24 AM   #78
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 2,589
you might look into converting to points ignition...
no rectifier, ignition module, battery = less money & simple to maintain.
best of luck, a lovely project. i'd love to have one of these thumpers
plugeye is offline   Reply With Quote
Old 02-25-2011, 02:34 AM   #79
John Steed OP
Too cheap to buy one
John Steed's Avatar
Oddometer: 223
and
PB Blaster, not in Europe, and cans don't travel by plane, so I will have to work with the WD-40
Pinesol, as I have seen, only in the US too
Ok, I need more data, even though I know what you mean, I have no idea as how this can be done...
So, feed me please!!!!
Thanks again for the nice things you say and for all the good advice!!!
------Work in Progress------
Rebuilding an SRX 400, as to be my first bike!!
http://www.advrider.com/forums/showthread.php?t=661797
John Steed is offline   Reply With Quote
Old 02-25-2011, 05:08 AM   #80
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 2,589
1st thing, research if you can down-grade to points ignition.
thats the key to simplicity
Old 02-25-2011, 06:46 AM   #81
Icehole
HOOLIGANZ
Icehole's Avatar
Oddometer: 64
Fun project. Good luck. I agree, you'll love this bike more than anything you'll ever buy (new or in running condition).
old(er) XT600
Icehole is offline   Reply With Quote
Old 02-25-2011, 11:25 PM   #82
John Steed OP
John Steed's Avatar
Oddometer: 223
After the broken head of the bolt, I started to remove some minor things around the bike, my hands still numb and afraid not to repeat this stupidity....
I removed the rear hose from the brake pump so that the break fluid could run out....
Old 02-25-2011, 11:26 PM   #83
John Steed OP
John Steed's Avatar
Oddometer: 223
...What's left of it, anyway...
Old 02-26-2011, 12:07 AM   #84
WVhillbilly
WVhillbilly's Avatar
Oddometer: 4,566
WD-40 is not a penetrating oil like Deep Creep or PB Blaster. Not nearly as effective. I know there are similar products for sale there, I just don't know the name of them.
WVhillbilly is offline   Reply With Quote
Old 02-26-2011, 12:25 AM   #85
KaceCoyote
KaceCoyote's Avatar
Oddometer: 5,614
Rocol was the one name I can recall from Europe. PB blaster and deep creep are sort've like the nuclear option, and I have no idea how Rocol's penetrating oil compares.
Just the same, you will likely be served well in the longterm by a number of different penetrating oils.
Old 02-26-2011, 02:22 AM   #86
John Steed OP
John Steed's Avatar
Oddometer: 223
Oh, now I get it, I will go to a shop and ask, Rocol UK only...
Good God, don't we have a good penetrating oil here???
Thank you both for your time, I will post what I found and bought from the shop!
Old 02-26-2011, 02:24 AM   #87
John Steed OP
John Steed's Avatar
Oddometer: 223
Removed the safety from the rear break lever....
Old 02-26-2011, 02:26 AM   #88
John Steed OP
John Steed's Avatar
Oddometer: 223
...Removed the springs, the bolts from the fluid pump, and the hose leading to the rear clamp....
Old 02-26-2011, 02:27 AM   #89
John Steed OP
John Steed's Avatar
Oddometer: 223
...And here it is!
Old 02-26-2011, 02:30 AM   #90
John Steed OP
John Steed's Avatar
Oddometer: 223
After that, I removed the small little switch for the rear brake light...
Times are GMT -7.   It's 10:22 PM.
