Old 02-26-2011, 02:32 AM   #91
John Steed OP
Too cheap to buy one
John Steed's Avatar
Oddometer: 223
...But the previous owner had me a little surprise on the cable connections, so I left it there, hanging, until I figure out what has he done with the cables...
------Work in Progress------
Rebuilding an SRX 400, as to be my first bike!!
http://www.advrider.com/forums/showthread.php?t=661797
John Steed is offline   Reply With Quote
Old 02-26-2011, 02:36 AM   #92
John Steed OP
John Steed's Avatar
Oddometer: 223
After that, I thought to remove the rear brake clamp, but noooooo!!!!
Removed the screws but...
Old 02-26-2011, 02:38 AM   #93
John Steed OP
John Steed's Avatar
Oddometer: 223
...It just wouldn't budge!
A hernia later....
Old 02-26-2011, 02:41 AM   #94
John Steed OP
John Steed's Avatar
Oddometer: 223
...nothing!
It must have some kind of a trick...
Well, left it there and moved on to the other side.
Gear lever!
Old 02-26-2011, 02:43 AM   #95
John Steed OP
John Steed's Avatar
Oddometer: 223
Wicked
Easy enough...
Old 02-26-2011, 02:46 AM   #96
John Steed OP
John Steed's Avatar
Oddometer: 223
One last bolt...
Old 02-26-2011, 02:50 AM   #97
John Steed OP
John Steed's Avatar
Oddometer: 223
And the blind goddess left me for good....
Can't seem to get anything right today....
It wont budge, and after the screw accident I was to afraid to try drastic measures...
So, left it there and simply removed the plastic sprocket cover above it....
Old 02-26-2011, 02:51 AM   #98
John Steed OP
John Steed's Avatar
Oddometer: 223
I said to call it a day, so stood up and saw this:
Old 02-26-2011, 03:05 AM   #99
John Steed OP
John Steed's Avatar
Oddometer: 223
The gas switch!
Removed it very easy, only two bolts and two hoses!
And called it a day!
Fiewh!
Today I have invited some fellows over for coffee, raki and souvlakia, so the next days I will be posting some real progress!!
(Or some drung guys pictures, running around naked in a basement.... )
Ah, almost forgot, thats my sweet company down there!!!
Old 02-26-2011, 03:07 AM   #100
WVhillbilly
WVhillbilly's Avatar
Oddometer: 11,542
The pads may just be dragging on the rear rotor. Can you get something between them to push them apart just a bit? Should be easy as the brake system is apart.
The calipers may be stuck, probably want to rebuild them.
Very simple as it is usually just some clean up and new seals.
WVhillbilly is offline   Reply With Quote
Old 02-26-2011, 03:17 AM   #101
John Steed OP
John Steed's Avatar
Oddometer: 223
Got it, thanks, will do tonight!
As for the rebuild on the little things (e.g. the calipers), I'm leaving them for when the whole bike will be on carton boxes and the frame for painting!
Old 02-26-2011, 04:03 PM   #102
John Steed OP
John Steed's Avatar
Oddometer: 223
Cool2
Real progress indeed!
We finished the dismantling about an hour or so, there were five of us and everybody was doing something!
Tomorrow the photos, I'm going to bed now, sooo sleepy.....
Old 02-27-2011, 09:05 AM   #103
picinisco
Scottish Transplant
picinisco's Avatar
Oddometer: 491
Originally Posted by John Steed View Post
Rocol UK only...Good God, don't we have a good penetrating oil here???
Domestica or Retsina
Cheers...John - 2004 BMW R1150GS, 1978 R100 (G/S Frankenbike)
Bikes That have Moved On:
1978 Suzuki GS550E, 1978 Kawasaki KZ1000P, 1982 Honda XL500R, 1995 BMW R1100RSL
picinisco is offline   Reply With Quote
Old 02-27-2011, 09:13 AM   #104
John Steed OP
John Steed's Avatar
Oddometer: 223
Old 02-27-2011, 10:50 AM   #105
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,048
I don't know what you have in Greece, but you will find the best selection of penetrating oil at a marine repair supply place. Those mechanics on boats and ships know everything there is to know about freeing rusted parts and cleaning the rust off metal.
I use Naval Jelly here in the states to clean rust off old metal parts. You probably have the equivalent or better for boat repair in Greece.
The best of luck to you on your bike Odyssey.
Cordless is offline   Reply With Quote
Times are GMT -7.   It's 05:05 AM.
