Old 02-20-2011, 03:00 PM   #16
Overdog
'Burghherfer.....
Overdog's Avatar
Oddometer: 242
Originally Posted by bmweuro View Post
The clutch cable and upper choke cable from a 88-95 R100RT might be longer and the same with the throttle cables however you might have to remove some of the outer sheathing on them(throttle cable) to work with the little plastic piece that they go into at the handlebar controls.
So, would the R100RT clutch cable be the longest available factory clutch cable that would fit a R90/6? I put on a set of Flander pullback bars and I'm really happy with the end result but I had to route the clutch cable directly along the front of the gas tank instead of through the gauge mount....I'd like to find a cable with a few more inches in length. All the other cables worked fine.
1983 Goldwing Interstate
1974 R90/6
1971 Honda CL 350 (shed queen)
Overdog is offline   Reply With Quote
Old 02-20-2011, 03:01 PM   #17
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,887
Largiader has a list of available cables and sizes on his site, I believe.
http://largiader.com/articles/cables/
1178mm is the longest one made.
Unintentional psychokinesis.
Stagehand screwed with this post 02-20-2011 at 03:10 PM
Stagehand is online now   Reply With Quote
Old 02-20-2011, 03:33 PM   #18
Overdog
'Burghherfer.....
Overdog's Avatar
Oddometer: 242
1178 is the longest throttle cable....I need a longer CLUTCH cable...looks like there is one 90mm or so longer than the one I have....should be just about right. Thanks for the link!
1974 R90/6
Old 02-20-2011, 04:23 PM   #19
jdmetzger OP
Lone Wolf
jdmetzger's Avatar
Oddometer: 3,384
Originally Posted by nowhereman View Post
You could also try rox risers that change from 7/8" to 1 1/8" bars - then run a protaper CR high or something like that. I've been thinking of doing that myself, but I just can't find the time to futz with the bike right now.
I've had the same achey back / shoulder thing with the stock bars - and that is with 1/2" risers in place. After about 500 miles or so, I have to take a long break - my back just can't take it.
This is starting to sound like a solution - at least one worth exploring. What do I have to lose but a bit of cash and some time, which will all be worth it if it can save my neck and shoulders and keep me from visiting the doctor in search of muscle relaxers (it got that bad last year).
Originally Posted by hardwaregrrl View Post
I have a set of these I'm not using if you're interested
Worked very well with my ST.
PM being sent.
Josh Metzger - Herndon, VA (with occasional stops in Toledo, OH)
1978 R80/7, 2013 R1200GS Adventure "90th Anniversary"
jdmetzger is offline   Reply With Quote
Old 02-20-2011, 07:57 PM   #20
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
Looking into this a little more the RT and the PD use the same clutch cable. They are both 1520mm long. So you best bet is to re-route it.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 02-20-2011, 07:59 PM   #21
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,887
AH yes-- my reading comprehension has only now just caught up.
To the finish! Eventually! :lol
Times are GMT -7.   It's 08:44 AM.
