Old 03-31-2011, 05:01 AM   #136
kirb
should be out riding
kirb's Avatar
Oddometer: 1,839
Originally Posted by Geek View Post
There's heat shielding on the 950's tanks? Hmmm.. my safari's don't have any shielding and they sit closer to the motor than the stock tanks.
Perhaps I should do some lining on those too?
jay71: I already purchased some matt black etching primer and some semi-gloss black engine paint.. .that'll be the treatment the skid plate is getting and I figure it'll be easy to touch up when I scratch it
My heat shield is only on the right tank around the exhaust pipe where it passes by.
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is offline   Reply With Quote
Old 03-31-2011, 07:32 AM   #137
Chipper
Oddometer: 713
What size Rollie bag is that?
I had a client reschedule this afternoon so I snuck out into the garage for an hour. The new carbon fairings do not come pre-drilled so step one is to disassemble the bike and get the old fairings off so that I can use them as a template for my drill holes. I had to remove my wolfman saddle bags, pelican case, CJ Designs rack, and then the gobi racks so that I could release the rear fairing
Old vs. New
I think the SGMoto windscreen and the rear tail section are going to compliment each other nicely
also matches nicely with the swingarm gaurds and clutch cover protection
...before getting to the drilling I got side tracked. Because of the Safari tanks I can't use my A990 bags at the moment. The A990 bags install in your front crash bars and are a really good place for carrying things like spare tubes, bigger tools, etc.
You can see the bag mounted in my crash bar in this pic:
With the Safari tanks, at least for the time being, I won't have my crash bars on (the bars would require modification to fit), so I'm losing that storage location.
Where to carry my spare tubes & such now?
I got a Wolfman bottle mounting kit (the u-shaped tie points) that I'm going to mount on the top of my pelican case...
Then.. I have one of the new Wolfman Rolie Bags that I'll strap on top of the pelican case using those tie downs.
Here is everything just sitting in place test fitting
This should be PERFECT for carrying spare tubes & the like. The Rolie bag system is stackable.. so depending on the trip I'm head out on I might actually pick up several of the Rolie bags in different sizes so that I can mix & match for my specific luggage needs.
....to be continued.
Chipper is offline   Reply With Quote
Old 03-31-2011, 08:01 AM   #138
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
The pelican case is a 1450 - the Rolie bag is a small.
Old 03-31-2011, 08:31 AM   #139
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,322
I have had my safari's on for nearly 3 years now and have ridden with them in really hot slow temperatures for long periods.
I have only a strip that is opposite the where the front header runs under the tanks. Mimicking the OEM tanks piece.
No problems so far.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 03-31-2011, 06:18 PM   #140
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
So when I left off I was shopping for heat shield.
Turns out the local autoparts store had some self-adhesive stuff in stock.
A 2 foot x 1 foot sheet was under $20
..did some cleaning on the back sides of the carbon with rubbing alcohol...
...some cutting with the scissors and I pealed & stuck...
et Voila.
My new panel is on the left.. stock panel on the right. Should be good
Old 03-31-2011, 06:24 PM   #141
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Then.. on to the left side.
The left side is a little more challenging because you have to figure out what to do with the key-unlock mechanism for the seat.
The stock fairing has the mechanism mounted on the fairing. The new fairing doesn't have the same bosses so the obvious solution is to move the mount from the fairing to the subfairing.
...as you pull the fairing away you can see how the cable is connected
..two screws release it and now you have the unit hanging from the cable
some Husqvarna bolts ( ) and some spacers and I mounted it to the under side.
Here you can see the bosses on the stock lower fairing around the hole. None of the holes are cut out in the carbon fairing.
..a few minutes with a dremel and Voila!
Note: this type of dust is very very toxic. Wear a mask and put a fan blowing the dust away from you. It was a windy day here so I just used a long extension cord and went and did the dremeling (is that a word?) outside.
Rubbed this side down with rubbing alcohol...
... and got the scissors out again and made my heat shield for this side.
Stock fairing left, carbon fairing right.
and complete. Left side mounted
Old 03-31-2011, 06:26 PM   #142
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Out in the sun
Old 03-31-2011, 06:29 PM   #143
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
...now I have to finish the skidplate and the glovebox.
I'm not sure how well this will turn out but we'll see.
For my black dog skid plate I picked up some matt black etching primer and some satin black engine paint.
then I have to bolt the luggage & such back on to get ready for the coming riding season
Old 03-31-2011, 06:30 PM   #144
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Random photo: The top of Webster pass - 12,000 feet.
There is 50+ feet of snow in this location currently
Old 03-31-2011, 06:33 PM   #145
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
South Park County, Colorado.
Where the show "South Park" is named after...
If you have never seen the southpark episode about Harley riders it is a must watch
You can watch it here:
http://www.southparkstudios.com/full...e12-the-f-word
(warning bad language, etc )
Old 04-01-2011, 04:19 AM   #146
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,258
Looking somewhat post-apocalyptic.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 04-01-2011, 12:58 PM   #147
kaia
team F5 ⌘R
kaia's Avatar
Oddometer: 2,574
at some point the stock exhaust pipes will begin to stick out like a sore thumb, and CF-wrapped pipes will be added... then it'll be closer to being done.
bike: 2010 KTM 990R | photos: SmugMug | SmugMug save $5: PeYEyWo3aVaYk
kaia is offline   Reply With Quote
Old 04-01-2011, 01:25 PM   #148
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
The stock exhausts aren't stock; they've been de-cat'd.
Bike runs great, is nice and quiet, and they don't get hot.
They just look stock
In Denver there is a "stock exhaust law". I look like I fit in
Here in Colorado loud pipes cost us public land access.
all that said.. if I can find some quiet carbon cans I'll buy 'em
Old 04-02-2011, 03:51 AM   #149
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,111
Did you see what Flanny did to his cans on his last build
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 04-02-2011, 05:45 AM   #150
rider911
Shortcut Navigator
rider911's Avatar
Oddometer: 515
Originally Posted by kamanya View Post
When/if I get the 990R I am putting these big tanks on it too.
What I am going to do is put a filter between the right tank and the left one. That way as I normally only put fuel into the right tank and then let it equalize I should save the pump filters some work.
I came up with the same idea last week too. (great minds think alike)
I'm just fitting the Safari at the moment. 99% of the time I will only ever have to fill the right tank so all the fuel will get prefiltered before the pump and in theory my pump filters should last twice as long.
911
New RR ~ Across OZ... Corner by Corner
08 KTM 300 exce (small)
12 KTM 500 exc (medium)
07 KTM 990 Adv (large)
rider911 screwed with this post 04-02-2011 at 06:09 AM
rider911 is offline   Reply With Quote
Times are GMT -7.   It's 09:45 PM.
